I’m still on the 4.0 milestone, so I haven’t encountered this yet. The PR you’ve found is almost certainly the proximal cause. From the screen shots, it just looks like your items are now in a container with slightly different settings than before. Use the dev tools to check out the structure of the cell and see if there are flex options or display options that need to be adjusted to get your previous arrangement back.
If you still can’t get the format you want back, open up a new thread and the issue can get worked out there.
You should also probably file an issue citing that PR, the discussion there indicates that some downstream issues are expected from this, so you should make the devs aware.
Loaded snapshot #3392 to fix memory leak. All good there
However, can not seem to edit the overview page (settings → pages) Trying to force the issue by adding /layout/overview yields a blank screen. This morning I get no error messages, but last night the top lines of the error messages (while trying to get to the edit) are;
2023-04-01 19:53:33.510 [WARN ] [ache.cxf.phase.PhaseInterceptorChain] - Interceptor for {http://internal.karaf.core.openhab.org/}LoggerResource has thrown exception, unwinding now
org.apache.cxf.interceptor.Fault: Could not send Message.
at org.apache.cxf.interceptor.MessageSenderInterceptor$MessageSenderEndingInterceptor.handleMessage(MessageSenderInterceptor.java:67) ~[bundleFile:3.4.5]
at org.apache.cxf.phase.PhaseInterceptorChain.doIntercept(PhaseInterceptorChain.java:308) ~[bundleFile:3.4.5]
at org.apache.cxf.interceptor.OutgoingChainInterceptor.handleMessage(OutgoingChainInterceptor.java:90) ~[bundleFile:3.4.5]
and
2023-04-01 19:53:33.530 [WARN ] [ache.cxf.phase.PhaseInterceptorChain] - Interceptor for {http://internal.karaf.core.openhab.org/}LoggerResource has thrown exception, unwinding now
org.apache.cxf.interceptor.Fault: XML_WRITE_EXC
at org.apache.cxf.jaxrs.interceptor.JAXRSDefaultFaultOutInterceptor.handleMessage(JAXRSDefaultFaultOutInterceptor.java:106) ~[bundleFile:3.4.5]
at org.apache.cxf.interceptor.AbstractFaultChainInitiatorObserver.onMessage(AbstractFaultChainInitiatorObserver.java:112) ~[bundleFile:3.4.5]
at org.apache.cxf.phase.PhaseInterceptorChain.wrapExceptionAsFault(PhaseInterceptorChain.java:374) ~[bundleFile:3.4.5]
Two other minor snapshot observations
I have a custom Zwave binding in the addons folder. Normally this is loaded late (> 200) now it is loaded first? The problem I had was that after the clean-cache from loading the snapshot I normally get a message about openhab-transport-serial, but with the early loading the state went to RESOLVED and no error message in openhab log. After installing the “transport” feature, I needed to do a bundle:restart. Normally (with a later loading queue) it starts up on its own. (hope this makes sense)
I get this these new messages on startup. Appears to be no lasting effect since the binding works.
2023-04-01 18:15:10.351 [WARN ] [core.thing.internal.ThingManagerImpl] - A thing handler factory claims to support 'systeminfo:computer-openhab' for thing 'systeminfo:computer:openhab' for more than 120s, but the thing type can't be found in the registry. This should be fixed in the binding.
2023-04-01 18:15:10.428 [WARN ] [core.thing.internal.ThingManagerImpl] - Could not normalize configuration for 'systeminfo:computer:openhab' because the thing type was not found in registry.
If you drop the binding after the initial startup, it get’s a high number (and is loaded late), if you have it in the folder when the cache is clean, then it’ll get loaded very early. On my systems this has always been the case.
This one is probably minor. I’m on #3395 and I noticed that the new ItemStateUpdateEvent is being logged to events.log. I would expect it to not be logged since the ItemStateEvent isn’t logged by default either.
to log4j2.xml suppresses this event. I’ll see if I can find which repo the “real” log4j2.xml file is and submit a PR. But for those who need a work around now, there you have it.
There won’t be a merge but I’m not positive if it’s overwritten or if you are given the option to overwrite it for apt/yum. In Docker I believe it just gets overwritten (though a complete backup of everything is made first). Manual installs are up to you to preserve your changes.
I’m having an issue with the newer snapshots relating to changes to files not being detected. The only way I can currently get OH to detect the change is by deleting/moving the file out and back in. This is happening across things/items/rules as well as addon jars (which I have to manually uninstall/install in karaf). jars seem to be worse than the config files, deleting/moving/copying in new versions don’t trigger the update like normal. I’m running OH inside of a docker on my Synology and updated to the newest snapshot today (3395). This isn’t an issue on my non-docker install that I run on my ubuntu dev box so I’m concerned that it’s something specific with how we watch files and what docker does and does not report to the container. To note, this is obviously all files that are located inside of a mapped mount point so that it survives reset.
This is all pulled in from the official docker image so I’d assume the java version is what it needs to be. My non-docker version seems fine. My concern is that something in the way a native OS versus a container report/monitor for file changes is just slightly different enough that we’re not catching it.
EDIT: I did some more tests. I’ll change my original statement to be “It won’t track files that have been created since OH started”. I went back and updated a few old files and it updated them immediately.
