Don’t why, but it stopped working…
i was on a 4.0 and was running quite good, but after last update it is not starting.
2023-05-13 21:12:00.619 [ERROR] [ternal.service.BootFeaturesInstaller] - Error installing boot features
java.lang.IllegalStateException: Resource has no uri
at org.apache.karaf.features.internal.service.Deployer.getBundleInputStream(Deployer.java:1631) ~[?:?]
at org.apache.karaf.features.internal.service.Deployer.deploy(Deployer.java:904) ~[?:?]
at org.apache.karaf.features.internal.service.FeaturesServiceImpl.doProvision(FeaturesServiceImpl.java:1069) ~[?:?]
at org.apache.karaf.features.internal.service.FeaturesServiceImpl.lambda$doProvisionInThread$13(FeaturesServiceImpl.java:1004) ~[?:?]
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1136) ~[?:?]
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:635) ~[?:?]
at java.lang.Thread.run(Thread.java:833) ~[?:?]
pi@raspberrypi:~ $ cat /etc/os-release
PRETTY_NAME=“Raspbian GNU/Linux 11 (bullseye)”
NAME=“Raspbian GNU/Linux”
VERSION_ID=“11”
VERSION=“11 (bullseye)”
VERSION_CODENAME=bullseye
ID=raspbian
ID_LIKE=debian
HOME_URL=“http://www.raspbian.org/”
SUPPORT_URL=“http://www.raspbian.org/RaspbianForums”
BUG_REPORT_URL=“http://www.raspbian.org/RaspbianBugs”
openjdk 17.0.6 2023-01-17
OpenJDK Runtime Environment (build 17.0.6+10-Raspbian-1deb11u1rpt1)
OpenJDK Client VM (build 17.0.6+10-Raspbian-1deb11u1rpt1, mixed mode, emulated-client)
pi@raspberrypi:~ $ openhab-cli info
Version: 4.0.0.M2 (Build)
User: openhab (Active Process 12605)
pi@raspberrypi:~ $ sudo systemctl status openhab
- openhab.service - openHAB - empowering the smart home
Loaded: loaded (/lib/systemd/system/openhab.service; enabled; vendor preset: enabled)
Active: active (running) since Sat 2023-05-13 21:11:48 CEST; 6min ago
Docs: Introduction | openHAB
https://community.openhab.org
Main PID: 12605 (java)
Tasks: 32 (limit: 3933)
CPU: 16.556s
CGroup: /system.slice/openhab.service
`-12605 /usr/bin/java -XX:-UsePerfData -Dopenhab.home=/usr/share/openhab -Dopenhab.conf=/etc/openhab -Dopenhab.runtime=/usr/share/openhab/runtime -Dopenha>
maj 13 21:11:48 raspberrypi systemd[1]: Started openHAB - empowering the smart home.
maj 13 21:12:00 raspberrypi karaf[12605]: java.lang.IllegalStateException: Resource has no uri
maj 13 21:12:00 raspberrypi karaf[12605]: at org.apache.karaf.features.internal.service.Deployer.getBundleInputStream(Deployer.java:1631)
maj 13 21:12:00 raspberrypi karaf[12605]: at org.apache.karaf.features.internal.service.Deployer.deploy(Deployer.java:904)
maj 13 21:12:00 raspberrypi karaf[12605]: at org.apache.karaf.features.internal.service.FeaturesServiceImpl.doProvision(FeaturesServiceImpl.java:1069)
maj 13 21:12:00 raspberrypi karaf[12605]: at org.apache.karaf.features.internal.service.FeaturesServiceImpl.lambda$doProvisionInThread$13(FeaturesServiceImpl.j>
maj 13 21:12:00 raspberrypi karaf[12605]: at java.base/java.util.concurrent.FutureTask.run(FutureTask.java:264)
maj 13 21:12:00 raspberrypi karaf[12605]: at java.base/java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1136)
maj 13 21:12:00 raspberrypi karaf[12605]: at java.base/java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:635)
maj 13 21:12:00 raspberrypi karaf[12605]: at java.base/java.lang.Thread.run(Thread.java:833)
