We should discuss the details somewhere else, but from what I’ve found, virtual threads would be a bad fit here. They have too many caveats. That said, you don’t need virtual threads to solve this, you only need a thread pool that is dynamic. When using virtual threads you also use an “unlimited dynamic pool”, you just don’t see it because it’s maintained by the JVM.
I could probably do the conflict resolution, but I would be unable to test/verify anything, since GraalJS doesn’t work at all for me outside of Karaf.
Indeed. There are two ways that bindings could block OH core. Namely a) making calls on the OH core common HTTP client without setting a request timeout, and b) blocking the OH core thread pool.
Of course one could certainly imagine adding another monitor thread in OH core that checks the running time of other threads passed to bindings, and kills them if they take too long. It would add overhead to OH core when all bindings are performing properly, but would eliminate the overhead when they are not. Also it would probably leave the respective binding in a trashed state, and perhaps therefore also trash OH core too.
now to something different… Coming from OH 4.3.6 / JRE 17, I installed Java 21 over openhabian-config and did the upgrade to OH 5.0.1. OpenHABIan on Raspberry Pi 4.
Only little stumble, but stuff went through. System is up and running.
Anyhow, there’s one thing I found in the logs:
2025-08-21 09:59:51.850 [ERROR] [ipt.internal.ScriptEngineManagerImpl] - ScriptEngine for language ‘application/javascript’ could not be found for identifier:61d46f6f-5fe2-4a7e-b655-e9af3a422cac
2025-08-21 09:59:51.880 [ERROR] [ipt.internal.ScriptEngineManagerImpl] - ScriptEngine for language ‘application/javascript’ could not be found for identifier:3505f058-c488-4a29-8430-33700f7fef96
It appears during OH startup, rather early - it’s there on every restart, but each of then exactly only once. There is nothing similar appearing afterwards.
I tried to find the UIDs in my Things, Items, Rules - nothing. I also did not notice any malfunctions yet. So it seems like something internal which is called in the startup phase seems still to be unhappy with Java 21. Any idea how to find it? Or can it be ignored?
Does anyone have problems with saving sitemap. I cannot save changes to sitemap, there is no warning or errors only information on exiting sitemap editor
“Changes have not been saved
Do you want to leave this page without saving?”
Openhab 5.01, ubuntu 22.04.5 LTS, Raspberry Pi 4. Browser Chrome on Windows 11.
I’ve noticed that when editing .things files, the following error occasionally appears in the logs:
[ERROR] [ore.thing.internal.ThingRegistryImpl] - Could not inform the ThingTracker 'org.openhab.core.thing.internal.ThingManagerImpl' about the 'THING_UPDATED' event!
java.lang.reflect.UndeclaredThrowableException
Caused by: java.lang.InterruptedException
Description:
The error happens sporadically, usually when saving Thing files.
OpenHAB tries to propagate the changes to the Thing handlers, but the process gets interrupted.
The log shows UndeclaredThrowableException and InterruptedException.
I thought I was upgrading to the latest 4.3 version of OpenHAB but eventually 5.0.1 was installed.
I faced several problems after the upgrade. The major problem is the running of the rules. I got the following error when a rule (DSL) is executed:
2025-08-22 15:35:16.177 [ERROR] [e.automation.internal.RuleEngineImpl] - Failed to execute rule ‘dabef6d032’: Failed to execute action: 2(Cannot invoke “com.google.inject.Injector.getInstance(java.lang.Class)” because the return value of “org.openhab.core.model.script.ScriptStandaloneSetup.getInjector()” is null)
and:
2025-08-22 16:15:31.375 [ERROR] [e.automation.internal.RuleEngineImpl] - Failed to execute rule ‘dabef6d032’: Failed to execute action: 2(null)
Note that the above code skips rules that are already disabled and ti skips the rule it’s running from. Rules that are triggered by a system started/start level reached trigger will be triggered again when the rule is reenabled.
I only minimally tested the above code. There may be edge cases I’ve not thought of.
Thanks a lot for this JS code. I would be very happy to master OpenHAB like you
I should also thank you twice because your JS code found that some rules were obsolete with some missing items to trigger them. So the upgrade is a good occasion to clean my OpenHAB settings.
Now, OpenHAB 5.0.1 seems to run fine but I will continue to closely monitor the log file to see whether there are still some other problems (or if there are complains from my family members ;-))
OpenHAB mentioned 10 Semantic Model Configuration Conflicts but I will have a look on it later. I was aware of this when I read the OpenHAB 5.0 announcement.
Unfortunatelly for sitemaps is not working from code view also. I checked it on “old” and new just created sitemap. For new was working only during creation. Then for next editing stop working.
As discussed in the milestone discussions, I also get at startup those warnings:
[WARN ] [ore.common.registry.AbstractRegistry] - Cannot add “GroupItem” with key “gGlobal”. It exists already from provider “GenericItemProvider”! Failed to add a second with the same UID from provider “ManagedItemProvider”!
All my items are defined in *.items files. The warning arises when the file with the definition of the GroupItem is loaded.
As far as I can see, the mentioned GroupItem is used in the definition of other items, defined in files loaded before. Obviously the GroupItem is also created when used, not only when defined.
The order of loading the .items files looks quite random. Is there a possibility to force a certain file to be loaded first?
