I have problems getting to the root cause for a problem, I experience with the OpenHab Alexa Smart Home skill
Please see the description of my problem below - do you have any ideas how I should analyse this behaviour any further - or even better: do you recognize it an know what’s causing it?
Cheers
Bastian
Setup
- OH 3.2 running in Docker image, connected to OH cloud
- OpenHab Alexa Smart Home Skill & multiple Alexas at home
Symptoms
- when telling Alexa to do something (switch on, off, etc.) with an OH-controlled device, Alexa responds “The hub controlling this device is not answering, try restarting the Hub.” (these are not the exact words but a rough translation, my setup is German).
- the addressed device is not responding to the command
- in the OH
openhab.logI can see that some time prior to this occuring, the CloudClient had to do a reconnect. I do not know (nor am I interested), why the connection was disconnected in the first place: the setup should be robust enough to handle a reconnect without this kind of problem.
2022-10-24 14:02:11.843 [INFO ] [io.openhabcloud.internal.CloudClient] - Disconnected from the openHAB Cloud service (UUID = xxxxx-xxxxx, base URL = http://localhost:80)
2022-10-24 14:04:27.011 [INFO ] [io.openhabcloud.internal.CloudClient] - Connected to the openHAB Cloud service (UUID = xxxxx-xxxxx, base URL = http://localhost:80)
- this happens maybe once every few weeks
Workaround
The following will make Alexa commands on OH devices work again. Still, I don’t want switch on my PC to restart the CloudConnector every time, neither do I want to setup an automated restart of CloudConnector like discussed here), without at least trying to understand what is causing this.
In the OpenHab Karaf shell:
openhab> restart org.openhab.io.openhabcloud
leading to these log-messages:
2022-10-24 20:32:12.426 [INFO ] [io.openhabcloud.internal.CloudClient] - Shutting down openHAB Cloud service connection
2022-10-24 20:32:12.427 [INFO ] [io.openhabcloud.internal.CloudClient] - Disconnected from the openHAB Cloud service (UUID = xxxxx-xxxxx, base URL = http://localhost:80)
2022-10-24 20:32:12.762 [INFO ] [io.openhabcloud.internal.CloudClient] - Connected to the openHAB Cloud service (UUID = xxxxx-xxxxx, base URL = http://localhost:80)
