OpenHab - GoControl CECOMINOD016164 HUSBZB-1 USB Hub communication error
  • Platform information:
    • Hardware: CPUArchitecture/RAM/storage i5-8250U - 2 gb ram 50 gb storage (gigabyte Brix)
    • OS: what OS is used and which version Debian 9 running openhabian installed via ESXI 6.7
    • Java Runtime Environment: which java platform is used and what version Zulu 8
    • openHAB version: Latest as of 4/20/2019
  • Issue of the topic: please be detailed explaining your issue Unable to get Zigbee ,Z-wave bindings to communicate with USB Stick manually or automatically (Amazon.com: GoControl CECOMINOD016164 HUSBZB-1 USB Hub : Electronics)
I have found ttyusb0 and ttyusb1 but each time i attempt to get it to work is gets a communication error
Check via dmesg -T | grep tty on which port your stick is connected.
CP210x converter now attached to ttyUSB0 was the response
You may find a lot of information here:
