I have a LINN DS player on my LAN, it has proper spotfiy connect intergration but only shows in HABPanel when i click play or use it in the Official App
Did you sort this out?
Ideally I should get a list of devices I can choose but I dont
I tried to keep lists as json in String item. It working well, but only when I open page first time. After refresh they vanish. May be it’s related to ng-init. It’s hard to say for me, because I am almost not familiar with Angular. What can be wrong?
I had some issues with the devices and playlists not updating. My current setup works well but it’s a branch and I think the way devices is different to the main branch so you may need to adapt it. There is a refresh button which updates devices, and then I make sure the interface has the latest set of devices with a mouseover function.
Note: The way devices works may be different in the main branch.
<div class="widget" ng-init="devices=$eval(itemValue('spotify_devices')).devices">
<div class="icon off" ng-click="sendCmd('spotify_device_update', 'ON'); devices=$eval(itemValue('spotify_devices')).devices"><svg viewBox="0 0 48 48"><use xlink:href="/static/matrix-theme/squidink.svg#double-arrow"></use></svg></div>
<div class="nameGroup"><div class="name">Devices</div></div>
<div class="btn-group" dropdown-append-to-body="true" uib-dropdown >
<button id="single-button" type="button" class="btn btn-primary" uib-dropdown-toggle ng-click="devices=$eval(itemValue('spotify_devices')).devices" ng-mouseover="devices=$eval(itemValue('spotify_devices')).devices">
{{itemValue('spotify_current_device')}} <span class="caret"></span>
</button>
<ul class="mydropdown-menu" uib-dropdown-menu role="menu" style="overflow: auto; max-height:300px; overflow-x:hidden" aria-labelledby="single-button" >
<div ng-repeat="dev in devices" ng-if="dev.state!='NULL'" >
<li role="menuitem"><a ng-click='sendCmd("spotify_action", "play \"" + dev.id + "\"")'>{{dev.name}}</a></li>
</div>
</ul>
</div>
</div>
Just for mention. https://api.spotify.com/v1/me/player/ can return 204 with empty body. It will lead to exception on r.json() and error “Failure: <type ‘exceptions.ValueError’>” in log.
I switched off my receiver thats used for spotify and all of a sudden when I reauth, which works fine, I see the logs showing token issues.
Nothing had changed. Looking in influx, I cant see it storing the token either.
I recreated the app in Spotify Dev console, entered in the new secret/client id and auth works. But the token part is failing and ive no idea why. This worked fine before.
Successfully got state from OpenHab: spotify_client_secret
Successfully got state from OpenHab: spotify_access_token
Successfully got state from OpenHab: spotify_refresh_token
Successfully got state from OpenHab: spotify_token_issued
Successfully got state from OpenHab: spotify_token_expiry
– Calling Token Refresh Service
{‘client_secret’: ‘XXXXXXXX’, ‘redirect_uri’: ‘http://192.168.0.3:8080/static/spotify-auth.html’, ‘client_id’: ‘CCCCC518’, ‘refresh_token’: ‘NULL’, ‘grant_type’: ‘refresh_token’}
{‘Content-Length’: ‘69’, ‘Keep-Alive’: ‘timeout=600’, ‘Server’: ‘nginx’, ‘Connection’: ‘keep-alive’, ‘Date’: ‘Thu, 05 Jul 2018 00:31:34 GMT’, ‘Content-Type’: ‘application/json’}
{u’error_description’: u’Invalid refresh token’, u’error’: u’invalid_grant’}
Successfully got state from OpenHab: spotify_auth_code
– Calling Token Service for the first time
{‘Content-Length’: ‘68’, ‘Keep-Alive’: ‘timeout=600’, ‘Server’: ‘nginx’, ‘Connection’: ‘keep-alive’, ‘Date’: ‘Thu, 05 Jul 2018 00:31:34 GMT’, ‘Content-Type’: ‘application/json’}
{u’error_description’: u’Invalid redirect URI’, u’error’: u’invalid_grant’}
– Calling Service: Play
Successfully got state from OpenHab: spotify_current_device_id
401
– Calling Service: Update
{u’error’: {u’status’: 401, u’message’: u’Invalid access token’}}
-> Item node missing from response
– Calling Service: Get Devices
-> Device List Failure: <type ‘exceptions.KeyError’>
– Calling Service: Get Playlists
-> Playlist List Failure: <type ‘exceptions.KeyError’>
Successfully posted state to OpenHab: spotify_lastConnectionDateTime = 2018-07-05T00:31:36.000+0000
Done in 3.3187558651 seconds
What do you mean reauth? The way it should work is you auth once, then the script will handle all the authorisation and getting new keys in the background.
Make sure you go through the instructions thoroughly and it should work.
If you are still struggling you can try a widget to made, it should cover the main instruction on setting up authorisation.
Remember to change the clientid, secret, openhab name/ip:port then you should be good to go.
<div class="section" ng-init="new_client_id='clientid';new_client_secret='secret'">
<widget>
<div class="title">Spotify Creds</div>
<div class="name"> Sign up to spotify to develop your own app to get a client ID and client secret <a href="https://developers.spotify.com/my-application/">developers.spotify.com/my-application/</a> then add http://openhabian:8080/static/spotify-auth.html to the redirect uri and save changes. Complete id and secret below and click buttons to update them. then click authenticate link and authenticate</div>
<div class="name">Current ID: {{itemValue('spotify_client_id')}} </div> <div class="name"> Enter new spotify_client_id <input style="color: black;" ng-model="new_client_id" size="35" />
<button ng-click="sendCmd('spotify_client_id', new_client_id)">Update Client ID</button></div>
<div class="name">Current secret: {{itemValue('spotify_client_secret')}}</div> <div class="name"> Enter new spotify_client_secret <input style="color: black;" ng-model="new_client_secret" size="35" />
<button ng-click="sendCmd('spotify_client_secret', new_client_secret)">Update Client Secret</button></div>
<div class="title"> <a href="http://openhabian:8080/static/spotify-auth.html" target="_blank">Click open authenication link!</a></div>
<div class="controlGroup">
<div class="heading"> Blow clears other creds credential- DANGEROUS</div>
<div class="name" ng-init="display=0">Click below to see and reset auth codes</div>
<div class="name" ng-click="display=1">ENABLE RESET - DANGER</div>
<div class="nameGroup" ng-if="display==1">
<button ng-click="sendCmd('spotify_auth_code','NULL')">Reset</button><div> {{itemValue('spotify_auth_code')}}</div>
<button ng-click="sendCmd('spotify_access_token','NULL')">Reset</button><div> {{itemValue('spotify_access_token')}}</div>
<button ng-click="sendCmd('spotify_refresh_token','NULL')">Reset</button><div> {{itemValue('spotify_refresh_token')}}</div>
<button ng-click="sendCmd('spotify_token_expiry','NULL')">Reset</button><div> {{itemValue('spotify_token_expiry')}}</div>
</div>
</div>
</widget>
</div>
There is nothing wrong with the widget, as mentioned this was working fine before.
I use the widget to enter the client id and secret, it authenticates correctly. But when I go back into the Open Auth link, it seems its not authenticated.
I also cannot see the token and so on being stored in Influx DB
The static/spotify-auth.html page will not be clear that it has been authorised. But once you done it once you should never need to do it again. Here mine is fully authorised and work and this is what the auth link looks like.
I fixed the issue, found an article on Stackoverflow.
Your URI must match in the spotify script and the Web Dev console. I had my private, internal IP address in the script but my external dns name in the Web dev.
