OK the only bit im not understanding is how does track_spotify change state in the first place?
It’s just a phantom switch to disable / enable the rule.
Map it to your home/away alert or just get rid of it entirely.
Initially I disabled and re-enabled it when I was testing the rule, but now it’s always on
Sorry it took a while to respond with the forum being down.
I also noticed this problem with the API, a simple workaround is to open Spotify (e.g. on your phone) and click on devices. That somehow refreshes the list in the backend. If you call the API again, all devices show up.
Hope this helps!
Sound cool, I do have multiple spotify connect players in the house and would like to use Alexa for playing stuff on the various locations. I understand, presently we’re using python scripts to do the magic, so my question:
- is it hard to make a binding out of this?
I can imagine there are many OH-users out there using spotify and alexa/google home and spotify for playing music?
@pmpkk Thanks for your reply!
However I tried your solution in the meantime and it doesn’t work for me unfortunately. When I play on one of my Sonos speakers through the official Sonos app on my phone it does show the track being played on my Sonos player in the widget but it doesn’t add the Sonos player to the list of devices (apparently it has device_id ‘NULL’).
I know this is a problem with the API, but I would assume more people are experiencing this problem or maybe found a fix or workaround? I will continue to trouble shoot and see if maybe the Spotify Web Client will work (with regard to your proposed workaround)
Edit: To clarify, I just played on all of my Sonos speakers through the Spotify app (which also correctly shows my devices). When I query the API endpoint for my devices I only get to see my webplayer.
"devices" : [ {
"id" : "13b1c36edd377e1c1920c35ae061df685316c313",
"is_active" : false,
"is_restricted" : false,
"name" : "Web Player (Chrome)",
"type" : "Computer",
"volume_percent" : 100
I also raised an issue with the Spotify web API on GitHub hoping that they might find a solution. (Cannot retrieve spotify devices with /v1/me/player/devices · Issue #671 · spotify/web-api · GitHub)
This is the response I got on the GitHub for the Spotify API.
Certain devices, particularly third party speakers and Sonos units, are not currently controllable through the Web API Connect endpoints. The /v1/me/player/devices endpoint will only return information for devices which are both active and controllable.
I thought I saw in one of your screenshots that you had a (Sonos?) Playbar connected through the Spotify widget, which is why I assumed it would work for Sonos devices. Does this mean no one has been able to control other devices through the Spotify widget other than their web clients?
I control my LG SoundBar and my Amazon Echo through the API and it works fine. I don’t understand why Sonos doesn’t support it (maybe a licensing issue).
Sorry! I hope they will support it soon.
Thanks unparagoned,
I have been using your version of the Spotify.py script, since my Amazon echo device keeps changing ID - and therefore I had to remap the device_id each time.
Since python is a new dark art to me, I decided to debug as much as I can.
Your code has one minor bug though.
When attempting to using …/spotify.py play devicename
it bugs out if there are devices on the spotify network that have special chars
In other words, I was trying spotify.py play Speakers (and various variations thereon) but whenever my iPhone or wife’s iphone was online, it would bug out…since the default identifier is something like this
“Bob’s iPhone”
My lazy bodge for now was to rename my iPhone, but this will not help when someone else is on my household network with an iPhone, running Spotify.
Here’s the capture:
Match : Speakers or None index: -1
Speakers
"Speakers"
1 Device : SOCKMONKEY id : daa6bbe58a66fa94a6b61431aaad3489a339e1a6
2 Device : Amazon FireTV Stick id : 35c7b98e202a04dddddef3e59f224df6233623dc
3 Device : -> Failure: <type 'exceptions.UnicodeEncodeError'>
-- Calling Service: Play device
When parsing the JSON, I could see that device 3 was:
{“name”: “Alan\u2019s iPhone”, “volume_percent”: null, “is_active”: false, “is_restricted”: false, “type”: “Smartphone”, “id”: “65176c3f445fa6ee9a2102c75555554001ca9f8”},
If you do update this at any point, please post the update.
So should the detection of a song playing happen without any refresh to then fire the rule?
Hi! I followed your tutorial on github and i got everything done. now i don’t know how to change values (for example just play/pause).
in the tut you write that this is done with the python script. can you please explain that a little bit for me? i can see the items in the habpanel but i created a button and mapped play/pause spotify current playing to it (seems like it’s only a read variable) so it does not work.
what do i to do need if i want to control things?
thanks a lot!
addition:
i successfully created a dummy label that shows me the current track.
it does show the last track played when i did run the python script in the terminal.
how can i execute the script from a rule? is that the way it should be working? ![]()
and at last of course: how can i actually control stuff. Thanks! ![]()
So it looks like there is no detection of when Spotify starts playing - are people just running the script every 10 seconds to capture changes in state?
I’m having the same issue. When I play from a device, the label and the title shows up fine on my HabPanel. I can see which track is playing, and also the progress bar. Only: I cannot control thingsfrom Habpanel. For example:
- When I change my volume from 100 to 50 in habpanel nothing happens
- However when I change the volume in spotify itself for example from 100 to 50 and then press update in HabPane, then the volume is updated from 100 to 50.
→ So it retrieves the information correctly from spotify, but I cannot control or send actions from HabPanel
To find the problem, try:
- Call the spotify.py command from the shell:
e.g. on Raspberry Pi:
/usr/bin/python /etc/openhab2/scripts/spotify.py play
- Did you wire up the rule to pass the spotify action item into the python command?
rule "Spotify Action"
Item spotify_action received update
val resp = executeCommandLine("/usr/bin/python /etc/openhab2/scripts/spotify.py " + spotify_action.state.toString, 5000)
logInfo("Spotify", resp)
Hey @pmpkk,
Thank you very much for your great work. Most the things I am currently missing are issues on spotify’s table (real time updates e.g. via websockets or webhooks and the possibility to control all devices that are available in the apps e.g. Chromecast).
One thing however that is not working for me is the persistence. I installed influxdb (together with grafana) and it’s working. But since I didn’t want to track every single item update I wanted to now which items actually have to be saved (and restored after a reboot?).
This is how my influxdb.persist currently looks like:
Strategies {
everyMinute : "0 * * * * ?"
everyHour : "0 0 * * * ?"
everyDay : "0 0 0 * * ?"
Items {
spotify_auth_code : strategy = everyUpdate
spotify_client_id : strategy = everyUpdate, restoreOnStartup
spotify_client_secret : strategy = everyUpdate, restoreOnStartup
spotify_access_token : strategy = everyChange
spotify_refresh_token : strategy = everyChange
spotify_token_expiry : strategy = everyChange
spotify_token_issued : strategy = everyChange
But since I have to do the auth dance (http://openhabianpi.local:8080/static/spotify-auth.html) every time after a reboot I think it’s not working correctly. What does your persist file look like?
Regards,
Florian
Cool!
I persist all items on everyChange, everyDay and restoreOnStartUp.
I’ve been running for a year now and generate 100MB a month worth of log data, which is totally fine for me.
Did you try to change it to this just to see if it works:
Items {
* : strategy = everyChange, everyDay, restoreOnStartup
[SOLVED] Now it works. This is how it looks now:
Items {
spotify_auth_code : strategy = everyUpdate, restoreOnStartup
spotify_access_token : strategy = everyUpdate, restoreOnStartup
spotify_refresh_token : strategy = everyUpdate, restoreOnStartup
spotify_token_expiry : strategy = everyUpdate, restoreOnStartup
spotify_token_issued : strategy = everyUpdate, restoreOnStartup
I tried the python.py play command. Here is what I get:
Successfully got state from OpenHab: spotify_client_id
Successfully got state from OpenHab: spotify_client_secret
Successfully got state from OpenHab: spotify_access_token
Successfully got state from OpenHab: spotify_refresh_token
Successfully got state from OpenHab: spotify_token_issued
Successfully got state from OpenHab: spotify_token_expiry
– Calling Service: Play
Successfully got state from OpenHab: spotify_current_device_id
403
– Calling Service: Update
{u’progress_ms’: 32130, u’timestamp’: 1507109776031L, u’repeat_state’: u’off’, u’shuffle_state’: False, u’item’: {u’album’: {u’album_type’: u’single’, u’name’: u’Together’, u’external_urls’: {u’spotify’: u’Spotify – Web Player’}, u’uri’: u’spotify:album:2WPc1NxJDtzVLk0StBEbMz’, u’href’: u’https://api.spotify.com/v1/albums/2WPc1NxJDtzVLk0StBEbMz’, u’artists’: [{u’name’: u’Klaas’, u’external_urls’: {u’spotify’: u’Spotify – Web Player’}, u’uri’: u’spotify:artist:25sJFKMqDENdsTF7zRXoif’, u’href’: u’https://api.spotify.com/v1/artists/25sJFKMqDENdsTF7zRXoif’, u’type’: u’artist’, u’id’: u’25sJFKMqDENdsTF7zRXoif’}], u’images’: [{u’url’: u’https://i.scdn.co/image/7894006d2c2c8c3e29d0ab498c959fadd8722f44’, u’width’: 600, u’height’: 600}, {u’url’: u’https://i.scdn.co/image/62dda60ccc3ae36a3bd63248d1dbdfc779eb9923’, u’width’: 300, u’height’: 300}, {u’url’: u’https://i.scdn.co/image/f4a985352a5852d05ea234a911b5cc07f0e14d2b’, u’width’: 64, u’height’: 64}], u’type’: u’album’, u’id’: u’2WPc1NxJDtzVLk0StBEbMz’, u’available_markets’: }, u’name’: u’Together - Chris Gold Edit’, u’uri’: u’spotify:track:1pgWrCu36Rd221g0u4GTWo’, u’external_urls’: {u’spotify’: u’Spotify – Web Player’}, u’popularity’: 57, u’explicit’: False, u’preview_url’: None, u’track_number’: 2, u’disc_number’: 1, u’href’: u’https://api.spotify.com/v1/tracks/1pgWrCu36Rd221g0u4GTWo’, u’artists’: [{u’name’: u’Klaas’, u’external_urls’: {u’spotify’: u’Spotify – Web Player’}, u’uri’: u’spotify:artist:25sJFKMqDENdsTF7zRXoif’, u’href’: u’https://api.spotify.com/v1/artists/25sJFKMqDENdsTF7zRXoif’, u’type’: u’artist’, u’id’: u’25sJFKMqDENdsTF7zRXoif’}, {u’name’: u’Chris Gold’, u’external_urls’: {u’spotify’: u’Spotify – Web Player’}, u’uri’: u’spotify:artist:3k2ntYCRYwchneYCxhOZFN’, u’href’: u’https://api.spotify.com/v1/artists/3k2ntYCRYwchneYCxhOZFN’, u’type’: u’artist’, u’id’: u’3k2ntYCRYwchneYCxhOZFN’}], u’duration_ms’: 178064, u’external_ids’: {u’isrc’: u’DEMA61700402’}, u’type’: u’track’, u’id’: u’1pgWrCu36Rd221g0u4GTWo’, u’available_markets’: }, u’context’: {u’href’: u’https://api.spotify.com/v1/users/spotify/playlists/37i9dQZF1DXcZDD7cfEKhW’, u’type’: u’playlist’, u’uri’: u’spotify:user:spotify:playlist:37i9dQZF1DXcZDD7cfEKhW’, u’external_urls’: {u’spotify’: u’Spotify – Web Player’}}, u’device’: {u’name’: u’L5415’, u’volume_percent’: 78, u’is_active’: True, u’is_restricted’: False, u’type’: u’Computer’, u’id’: u’e7ffcf8ac5247647604d61a0ec759a0643ecfe4e’}, u’is_playing’: False}
Successfully posted state to OpenHab: spotify_current_track = Together - Chris Gold Edit
Successfully posted state to OpenHab: spotify_current_artist = Klaas
Successfully posted state to OpenHab: spotify_current_cover = https://i.scdn.co/image/62dda60ccc3ae36a3bd63248d1dbdfc779eb9923
Successfully posted state to OpenHab: spotify_current_duration = 178064
Successfully posted state to OpenHab: spotify_current_progress = 32130
Successfully posted state to OpenHab: spotify_current_playing = OFF
Successfully posted state to OpenHab: spotify_current_device = L5415
Successfully posted state to OpenHab: spotify_current_volume = 78
Successfully posted state to OpenHab: spotify_current_context_uri = spotify:user:spotify:playlist:37i9dQZF1DXcZDD7cfEKhW
Successfully posted state to OpenHab: spotify_current_device_id = e7ffcf8ac5247647604d61a0ec759a0643ecfe4e
Successfully posted state to OpenHab: spotify_current_progress_percent = 18.04
→ Success
Successfully posted state to OpenHab: spotify_lastConnectionDateTime = 2017-10-04T09:36:59+0000
Done in 0.796753883362 seconds
Everything is successful… but spotify doens’t start playing.
I have the spotify.rules in the rules folder
The only thing I should mention is my setup: I’m running on a synology NAS. Only thing I had to change was the directory from /etc/openhab2/scripts/spotify.py to /volume1/@appstore/openHAB2/conf/scripts.spotify.py
I’ve changed this in the spotify.rules file
If I look at above log, seems I get a 403 error, which I believe is a ‘forbidden’ error. I guess I’m not having the correct rights to execute the commands?
Can anyone tell me if I need to be running the script continuously to get the state change of Spotify starting to play? I’m guessing so but would like to hear from people successfully running
Yes, @Andrew_Pawelski, spotify states are only updated through spotify.py. So you will constantly have to trigger the script. You can do this within your spotify.rules with a cron expression. I am currently only pulling twice a minute 0/30 * * ? * * * and hitting the update button when I want to get the current state (this could also archived with Page Visibility API dont’t you think @pmpkk? )
I am waiting for spotify to release a webook or some kind of aparatus that sends realtime updates to the client.
P.S.: This is what my spotify.rules currently looks like:
rule "Spotify run script"
Time cron "0/30 * * * * ? *" or
Item spotify_forceupadte received update
val resp = executeCommandLine("/usr/bin/python /etc/openhab2/scripts/spotify.py", 5000)
how much data does that use every 30 seconds?
