i‘m using OH3 with an Raspberry4 everything works well, only logviewer is empty !
Why?
tail -f /var/log/openhab/openhab.log
Why?
Which OH3 version ?
Was it migrated or a fresh OH3 install ?
it was a fresh install
ideas ?
your headline states that frontail is not showing any log entry.
/var/log/poenhab/openhab.log is empty as well ?
Even no entry when openhab service is restarted ?
What is the content of the file /var/lib/openhab/etc/org.ops4j.pax.logging.cfg and what is the content of the file /var/lib/openhab/etc/log4j2.xml ?
openhab.log is not empty
I have restartet several times
org.ops4j.pax.logging.log4j2.config.file=${karaf.etc}/log4j2.xml
<?xml version="1.0" encoding="UTF-8" standalone="no"?><Appenders>
<!-- Console appender not used by default (see Root logger AppenderRefs) -->
<Console name="STDOUT">
<PatternLayout pattern="%d{HH:mm:ss.SSS} [%-5.5p] [%-36.36c] - %m%n"/>
</Console>
<!-- Rolling file appender -->
<RollingFile fileName="${sys:openhab.logdir}/openhab.log" filePattern="${sys:openhab.logdir}/openhab.log.%i" name="LOGFILE">
<PatternLayout pattern="%d{yyyy-MM-dd HH:mm:ss.SSS} [%-5.5p] [%-36.36c] - %m%n"/>
<Policies>
<OnStartupTriggeringPolicy/>
<SizeBasedTriggeringPolicy size="16 MB"/>
</Policies>
</RollingFile>
<!-- Event log appender -->
<RollingRandomAccessFile fileName="${sys:openhab.logdir}/events.log" filePattern="${sys:openhab.logdir}/events.log.%i" name="EVENT">
<Policies>
</Policies>
</RollingRandomAccessFile>
<!-- Audit file appender -->
<RollingRandomAccessFile fileName="${sys:openhab.logdir}/audit.log" filePattern="${sys:openhab.logdir}/audit.log.%i" name="AUDIT">
<Policies>
<SizeBasedTriggeringPolicy size="8 MB"/>
</Policies>
<!-- OSGi appender -->
<PaxOsgi filter="*" name="OSGI"/>
</Appenders>
<Loggers>
<!-- Root logger configuration -->
<Root level="WARN">
<AppenderRef ref="LOGFILE"/>
<AppenderRef ref="OSGI"/>
</Root>
<!-- Karaf Shell logger -->
<Logger level="OFF" name="org.apache.karaf.shell.support">
<AppenderRef ref="STDOUT"/>
</Logger>
<!-- Security audit logger -->
<Logger additivity="false" level="INFO" name="org.apache.karaf.jaas.modules.audit">
<AppenderRef ref="AUDIT"/>
</Logger>
<!-- openHAB specific logger configuration -->
<Logger level="INFO" name="org.openhab"/>
<Logger level="ERROR" name="openhab.event.ItemStateEvent"/>
<Logger level="ERROR" name="openhab.event.ItemAddedEvent"/>
<Logger level="ERROR" name="openhab.event.ItemRemovedEvent"/>
<Logger level="ERROR" name="openhab.event.ItemChannelLinkAddedEvent"/>
<Logger level="ERROR" name="openhab.event.ItemChannelLinkRemovedEvent"/>
<Logger level="ERROR" name="openhab.event.ThingStatusInfoEvent"/>
<Logger level="ERROR" name="openhab.event.ThingAddedEvent"/>
<Logger level="ERROR" name="openhab.event.ThingUpdatedEvent"/>
<Logger level="ERROR" name="openhab.event.ThingRemovedEvent"/>
<Logger level="ERROR" name="openhab.event.InboxUpdatedEvent"/>
<Logger level="ERROR" name="openhab.event.RuleStatusInfoEvent"/>
<Logger level="ERROR" name="openhab.event.RuleAddedEvent"/>
<Logger level="ERROR" name="openhab.event.RuleRemovedEvent"/>
<Logger level="ERROR" name="openhab.event.StartlevelEvent"/>
<Logger level="ERROR" name="openhab.event.AddonEvent"/>
<Logger additivity="false" level="INFO" name="openhab.event">
<AppenderRef ref="EVENT"/>
</Logger>
<Logger level="ERROR" name="javax.jmdns"/>
<Logger level="ERROR" name="org.jupnp"/>
<!-- This suppresses all Maven download issues from the log when doing feature installations -->
<!-- as we are logging errors ourselves in a nicer way anyhow. -->
<Logger level="ERROR" name="org.ops4j.pax.url.mvn.internal.AetherBasedResolver"/>
<!-- Filters known issues of pax-web (issue link to be added here). -->
<!-- Can be removed once the issues are resolved in an upcoming version. -->
<Logger level="OFF" name="org.ops4j.pax.web.pax-web-runtime"/>
<!-- Filters known issues of lsp4j, see -->
<!-- https://github.com/eclipse/smarthome/issues/4639 -->
<!-- https://github.com/eclipse/smarthome/issues/4629 -->
<!-- https://github.com/eclipse/smarthome/issues/4643 -->
<Logger level="OFF" name="org.eclipse.lsp4j"/>
<!-- Filters warnings for events that could not be delivered to a disconnected client. -->
<Logger level="ERROR" name="org.apache.cxf.jaxrs.sse.SseEventSinkImpl"/>
<!-- Filters known issues of KarServiceImpl, see -->
<!-- https://github.com/openhab/openhab-distro/issues/519#issuecomment-351944506 -->
<Logger level="ERROR" name="org.apache.karaf.kar.internal.KarServiceImpl"/>
<!-- Filters warnings about unavailable ciphers when JCE is not installed, see -->
<!-- https://github.com/openhab/openhab-distro/issues/999 -->
<Logger level="ERROR" name="org.apache.karaf.shell.ssh.SshUtils"/>
<!-- Filters known issues of javax.mail, see -->
<!-- https://github.com/openhab/openhab-addons/issues/5530 -->
<Logger level="ERROR" name="javax.mail"/>
<!-- Filters disconnection warnings of the ChromeCast Java API, see -->
<!-- https://github.com/openhab/openhab-addons/issues/3770 -->
<Logger level="ERROR" name="su.litvak.chromecast.api.v2.Channel"/>
<!-- Added by Karaf to prevent debug logging loops, see -->
<!-- https://issues.apache.org/jira/browse/KARAF-5559 -->
<Logger level="WARN" name="org.apache.sshd"/>
</Loggers>
</Configuration
Content of both files look ok.
frontail is running ( of course it must otherwise you can’t connect with your browser ) ?
sudo systemctl status openhab
What is the output of
grep openhab /etc/systemd/system/frontail.service
openhab.service - openHAB - empowering the smart home
Loaded: loaded (/lib/systemd/system/openhab.service; enabled; vendor preset: enabled)
Active: active (running) since Sat 2021-01-30 20:08:29 CET; 14h ago
Docs: Introduction | openHAB
https://community.openhab.org
Main PID: 691 (java)
Tasks: 667 (limit: 4915)
CGroup: /system.slice/openhab.service
└─691 /usr/bin/java -XX:-UsePerfData -Dopenhab.home=/usr/share/openhab -Dopenhab.conf=/etc/openhab -Dopenhab.runtime=/usr
After=openhab.service
PartOf=openhab.service
ExecStart=/usr/lib/node_modules/frontail/bin/frontail --ui-highlight --ui-highlight-preset /usr/lib/node_modules/frontail/preset/openhab_dark.json -t openhab_dark -l 2000 -n 200 /var/log/openhab/openhab.log /var/log/openhab/events.log
Group=openhab
I had a similar problem.
this post helped me get it sorted,
Also looks ok so far.
One more check
sudo systemctl status frontail
Frontail was installed via openhabian-config ? When ? Could you try a reinstall of frontail via openhabian-config ( in case you use openhabian-config ).
frontail.service - Frontail openHAB instance, reachable at http://openHABianDevice:9001
Loaded: loaded (/etc/systemd/system/frontail.service; enabled; vendor preset: enabled)
Active: active (running) since Sun 2021-01-31 11:24:14 CET; 2h 35min ago
Docs: GitHub - mthenw/frontail: 📝 streaming logs to the browser
Main PID: 26007 (node)
Tasks: 12 (limit: 4915)
CGroup: /system.slice/frontail.service
├─26007 node /usr/lib/node_modules/frontail/bin/frontail --ui-highlight --ui-highlight-preset /usr/lib/node_modules/front
└─26015 tail -n 200 -F /var/log/openhab/openhab.log /var/log/openhab/events.log
how can I reinstall frontail ?
Yes I use openhabian…
menu entry 21 in openhabian-config
sudo openhabian-config
I have tried, same problem…
Which browser do you use ?
In case it is firefox or chrome is there any error message in the web console ?
iPad = safari
PC = Mozilla
any error or warning message in it’s webconsole ?
Could you also check this:
cd /lib/node_modules/frontail
npm list | grep socket.io
