yesterday, i have upgraded from M6 to M8 and now i have the same Problems. How can i help to analyse the Problem?
Interessting update on my side. Retestet this morning and the problem is (nearly) gone.
What happend:
Today I tried the Milestone 8 Build, but openhab always reports the following errors during startup. I used the update script to update from Milestone 7, which runs without any issue. I tried starting openHAB M8 several times.
Java runtime is “OpenJDK Runtime Environment (Zulu 8.31.0.1-macosx) (build 1.8.0_181-b02)”
Is there any way to increase the number of threads?
2018-12-14 20:29:43.534 [ERROR] [org.jupnp.transport.spi.StreamClient] - Failed to instantiate HTTP client
java.lang.IllegalStateException: Insufficient configured threads: required=5 < max=5 for QueuedThreadPool[jupnp-jetty-client]@4ac409ae{STARTED,5<=5<=5,i=5,q=0}[ReservedThreadExecutor@9f29d6a{s=0/1,p=0}]
at org.eclipse.jetty.util.thread.ThreadPoolBudget.check(ThreadPoolBudget.java:149) ~[87:org.eclipse.jetty.util:9.4.11.v20180605]
at org.eclipse.jetty.util.thread.ThreadPoolBudget.leaseTo(ThreadPoolBudget.java:130) ~[87:org.eclipse.jetty.util:9.4.11.v20180605]
at org.eclipse.jetty.util.thread.ThreadPoolBudget.leaseFrom(ThreadPoolBudget.java:175) ~[87:org.eclipse.jetty.util:9.4.11.v20180605]
at org.eclipse.jetty.io.SelectorManager.doStart(SelectorManager.java:251) ~[?:?]
at org.eclipse.jetty.util.component.AbstractLifeCycle.start(AbstractLifeCycle.java:68) ~[87:org.eclipse.jetty.util:9.4.11.v20180605]
at org.eclipse.jetty.util.component.ContainerLifeCycle.start(ContainerLifeCycle.java:138) ~[87:org.eclipse.jetty.util:9.4.11.v20180605]
at org.eclipse.jetty.util.component.ContainerLifeCycle.doStart(ContainerLifeCycle.java:117) ~[87:org.eclipse.jetty.util:9.4.11.v20180605]
at org.eclipse.jetty.client.AbstractConnectorHttpClientTransport.doStart(AbstractConnectorHttpClientTransport.java:64) ~[?:?]
at org.eclipse.jetty.client.HttpClient.doStart(HttpClient.java:241) ~[?:?]
at org.jupnp.transport.impl.jetty.JettyStreamClientImpl.<init>(JettyStreamClientImpl.java:79) [241:org.jupnp:2.5.0]
at org.jupnp.transport.impl.jetty.JettyTransportConfiguration.createStreamClient(JettyTransportConfiguration.java:23) [241:org.jupnp:2.5.0]
at org.jupnp.OSGiUpnpServiceConfiguration.createStreamClient(OSGiUpnpServiceConfiguration.java:196) [241:org.jupnp:2.5.0]
at org.jupnp.transport.RouterImpl.enable(RouterImpl.java:135) [241:org.jupnp:2.5.0]
at org.jupnp.UpnpServiceImpl.startup(UpnpServiceImpl.java:258) [241:org.jupnp:2.5.0]
at org.jupnp.UpnpServiceImpl.activate(UpnpServiceImpl.java:287) [241:org.jupnp:2.5.0]
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) ~[?:?]
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62) ~[?:?]
at org.apache.felix.scr.impl.inject.methods.BaseMethod.invokeMethod(BaseMethod.java:228) [39:org.apache.felix.scr:2.1.2]
at org.apache.felix.scr.impl.inject.methods.BaseMethod.access$500(BaseMethod.java:41) [39:org.apache.felix.scr:2.1.2]
at org.apache.felix.scr.impl.inject.methods.BaseMethod$Resolved.invoke(BaseMethod.java:664) [39:org.apache.felix.scr:2.1.2]
at org.apache.felix.scr.impl.inject.methods.BaseMethod.invoke(BaseMethod.java:510) [39:org.apache.felix.scr:2.1.2]
at org.apache.felix.scr.impl.inject.methods.ActivateMethod.invoke(ActivateMethod.java:317) [39:org.apache.felix.scr:2.1.2]
at org.apache.felix.scr.impl.inject.methods.ActivateMethod.invoke(ActivateMethod.java:307) [39:org.apache.felix.scr:2.1.2]
at org.apache.felix.scr.impl.manager.SingleComponentManager.createImplementationObject(SingleComponentManager.java:334) [39:org.apache.felix.scr:2.1.2]
at org.apache.felix.scr.impl.manager.SingleComponentManager.createComponent(SingleComponentManager.java:114) [39:org.apache.felix.scr:2.1.2]
at org.apache.felix.scr.impl.manager.SingleComponentManager.getService(SingleComponentManager.java:947) [39:org.apache.felix.scr:2.1.2]
at org.apache.felix.scr.impl.manager.SingleComponentManager.getServiceInternal(SingleComponentManager.java:919) [39:org.apache.felix.scr:2.1.2]
at org.apache.felix.scr.impl.manager.SingleComponentManager.getService(SingleComponentManager.java:863) [39:org.apache.felix.scr:2.1.2]
at org.eclipse.osgi.internal.serviceregistry.ServiceFactoryUse$1.run(ServiceFactoryUse.java:212) [?:?]
at java.security.AccessController.doPrivileged(Native Method) ~[?:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceFactoryUse.factoryGetService(ServiceFactoryUse.java:210) [?:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceFactoryUse.getService(ServiceFactoryUse.java:111) [?:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceConsumer$2.getService(ServiceConsumer.java:45) [?:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistrationImpl.getService(ServiceRegistrationImpl.java:508) [?:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.getService(ServiceRegistry.java:461) [?:?]
at org.eclipse.osgi.internal.framework.BundleContextImpl.getService(BundleContextImpl.java:624) [?:?]
at com.eclipsesource.jaxrs.publisher.internal.ResourceTracker.addingService(ResourceTracker.java:39) [20:com.eclipsesource.jaxrs.publisher:5.3.1.201602281253]
at org.osgi.util.tracker.ServiceTracker$Tracked.customizerAdding(ServiceTracker.java:941) [?:?]
at org.osgi.util.tracker.ServiceTracker$Tracked.customizerAdding(ServiceTracker.java:870) [?:?]
at org.osgi.util.tracker.AbstractTracked.trackAdding(AbstractTracked.java:256) [?:?]
at org.osgi.util.tracker.AbstractTracked.track(AbstractTracked.java:229) [?:?]
at org.osgi.util.tracker.ServiceTracker$Tracked.serviceChanged(ServiceTracker.java:901) [?:?]
at org.eclipse.osgi.internal.serviceregistry.FilteredServiceListener.serviceChanged(FilteredServiceListener.java:109) [?:?]
at org.eclipse.osgi.internal.framework.BundleContextImpl.dispatchEvent(BundleContextImpl.java:920) [?:?]
at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230) [?:?]
at org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEventSynchronous(ListenerQueue.java:148) [?:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.publishServiceEventPrivileged(ServiceRegistry.java:862) [?:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.publishServiceEvent(ServiceRegistry.java:801) [?:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistrationImpl.register(ServiceRegistrationImpl.java:127) [?:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.registerService(ServiceRegistry.java:225) [?:?]
at org.eclipse.osgi.internal.framework.BundleContextImpl.registerService(BundleContextImpl.java:469) [?:?]
at org.apache.felix.scr.impl.manager.AbstractComponentManager$3.register(AbstractComponentManager.java:891) [39:org.apache.felix.scr:2.1.2]
at org.apache.felix.scr.impl.manager.AbstractComponentManager$3.register(AbstractComponentManager.java:877) [39:org.apache.felix.scr:2.1.2]
at org.apache.felix.scr.impl.manager.RegistrationManager.changeRegistration(RegistrationManager.java:128) [39:org.apache.felix.scr:2.1.2]
at org.apache.felix.scr.impl.manager.AbstractComponentManager.registerService(AbstractComponentManager.java:944) [39:org.apache.felix.scr:2.1.2]
at org.apache.felix.scr.impl.manager.AbstractComponentManager.activateInternal(AbstractComponentManager.java:727) [39:org.apache.felix.scr:2.1.2]
at org.apache.felix.scr.impl.manager.AbstractComponentManager.enableInternal(AbstractComponentManager.java:661) [39:org.apache.felix.scr:2.1.2]
at org.apache.felix.scr.impl.manager.AbstractComponentManager.enable(AbstractComponentManager.java:427) [39:org.apache.felix.scr:2.1.2]
at org.apache.felix.scr.impl.manager.ConfigurableComponentHolder.enableComponents(ConfigurableComponentHolder.java:665) [39:org.apache.felix.scr:2.1.2]
at org.apache.felix.scr.impl.BundleComponentActivator.initialEnable(BundleComponentActivator.java:339) [39:org.apache.felix.scr:2.1.2]
at org.apache.felix.scr.impl.Activator.loadComponents(Activator.java:381) [39:org.apache.felix.scr:2.1.2]
at org.apache.felix.scr.impl.Activator.access$200(Activator.java:49) [39:org.apache.felix.scr:2.1.2]
at org.apache.felix.scr.impl.Activator$ScrExtension.start(Activator.java:263) [39:org.apache.felix.scr:2.1.2]
at org.apache.felix.scr.impl.AbstractExtender.createExtension(AbstractExtender.java:196) [39:org.apache.felix.scr:2.1.2]
at org.apache.felix.scr.impl.AbstractExtender.modifiedBundle(AbstractExtender.java:169) [39:org.apache.felix.scr:2.1.2]
at org.apache.felix.scr.impl.AbstractExtender.modifiedBundle(AbstractExtender.java:49) [39:org.apache.felix.scr:2.1.2]
at org.osgi.util.tracker.BundleTracker$Tracked.customizerModified(BundleTracker.java:482) [?:?]
at org.osgi.util.tracker.BundleTracker$Tracked.customizerModified(BundleTracker.java:415) [?:?]
at org.osgi.util.tracker.AbstractTracked.track(AbstractTracked.java:232) [?:?]
at org.osgi.util.tracker.BundleTracker$Tracked.bundleChanged(BundleTracker.java:444) [?:?]
at org.eclipse.osgi.internal.framework.BundleContextImpl.dispatchEvent(BundleContextImpl.java:908) [?:?]
at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEventPrivileged(EquinoxEventPublisher.java:213) [?:?]
at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEvent(EquinoxEventPublisher.java:120) [?:?]
at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEvent(EquinoxEventPublisher.java:112) [?:?]
at org.eclipse.osgi.internal.framework.EquinoxContainerAdaptor.publishModuleEvent(EquinoxContainerAdaptor.java:168) [?:?]
at org.eclipse.osgi.container.Module.publishEvent(Module.java:476) [?:?]
at org.eclipse.osgi.container.Module.start(Module.java:467) [?:?]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1634) [?:?]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1614) [?:?]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.doContainerStartLevel(ModuleContainer.java:1585) [?:?]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1528) [?:?]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1) [?:?]
at org.eclipse.osgi.framework.eventmgr.EventManager$EventThread.run(EventManager.java:340) [?:?]
and
2018-12-14 20:29:43.546 [ERROR] [org.jupnp.transport.Router ] - Unable to initialize network router: org.jupnp.transport.spi.InitializationException: Failed to instantiate HTTP client
and
2018-12-14 20:29:43.547 [ERROR] [org.jupnp.transport.Router ] - Cause: java.lang.IllegalStateException: Insufficient configured threads: required=5 < max=5 for QueuedThreadPool[jupnp-jetty-client]@4ac409ae{STARTED,5<=5<=5,i=5,q=0}[ReservedThreadExecutor@9f29d6a{s=0/1,p=0}]
Issue should be solved here
Search function?
Sorry!
I do not use the Sonos binding so I skipped this report.
2.4.0RC1 is out.
Does that still count as a milestone ? At least I noticed it appeared in the ‘testing’ repo.
Yes, this qualifies as a milestone - the “RC” label simply shows that it is planned to be the last one before the release.
Ahm, I just updated from M8 to RC1 and hell broke loose. Feature install failed completely and some errors on Smarthome binding some error about ‘sse’ . We might want to check if this a problem for major release. Will post all the errors once I’m back home. Sonos upnp issue seems to be fixed but now new errors popping up there as well.
@marcelser Please report in this thread. I doubt that there’s an issue between M8 and RC1, it sounds more like some temporary problem, which might be resolved after a simple restart.
Here is the changelog for RC1 (in comparison to M8):
Eclipse SmartHome:
openHAB Core:
openHAB 2 Add-ons:
Zigbee Binding:
HABPanel:
HABot:
openHAB Distro:
you’re right. after 2 restarts most problems are resolved. The remaining stuff I will check and if necessary post in testing thread.
Updated to RC1. Still no problems. Would consider this as closed.
Is the Docker Image already out? I cant find a 2.4 RC1 Tag.
Does stable releases will be released in the testing repo (like after RC1)?
I have switched to the testing repo because I had a few bugs in the beginning, now most of them are solved and I don’t want to mess with non-stable releases. How should I switch back?
Switch back to the stable release and do an upgrade when 2.4 is out?
Thanks!
Using ThingAction to get the online/offline status of a Thing seems to be broken in RC1. Or perhaps the syntax has changed?
The following line:
var status = ThingAction.getThingStatusInfo("zwave:serial_zstick:zstick").getStatus()
Was working fine until I upgraded to RC1 this morning. Now I get:
2018-12-16 14:01:40.003 [ERROR] [ntime.internal.engine.ExecuteRuleJob] - Error during the execution of rule 'Hourly check of critical items': The name 'ThingAction' cannot be resolved to an item or type; line 52, column 16, length 11
Would be grateful for any help anyone can give with this.
thanks
Dan
Afaik, you do not need to put ThingAction.
in front - it should work without it. Could you try?
that works perfectly - thank you.
I upgraded to 2.4 M5 a while ago. Just now I try to upgrade to RC1, but I got this error:
Ign:6 https://dl.bintray.com/openhab/apt-repo2 testing InRelease
Get:7 https://dl.bintray.com/openhab/apt-repo2 testing Release [6,053 B]
Hit:7 https://dl.bintray.com/openhab/apt-repo2 testing Release
Ign:8 https://dl.bintray.com/openhab/apt-repo2 testing Release.gpg
Reading package lists... Done
W: The repository 'https://dl.bintray.com/openhab/apt-repo2 testing Release' is not signed.
N: Data from such a repository can't be authenticated and is therefore potentially dangerous to use.
N: See apt-secure(8) manpage for repository creation and user configuration details.
Does anyone know what could have caused this? It was just fine couple weeks ago.
Thanks,
