Vetted MyQ, sonos and ambient weather, systeminfo. Still struggling with the Samsung TV binding. Chipping away here. Thanks again to all. Ya’ll are an amazing group of people!![]()
After update on M2 I get the following error message:
2019-08-10 19:35:59.118 [ERROR] [core.karaf.internal.FeatureInstaller] - Failed installing 'openhab-misc-restdocs's
Besides, my Zigbee things are not going online
What can I do?
That Zigbee things keep offline happened to me when I updated the binding. I just had to reset the devices and rejoin them and then everything worked flawlessly
Hi, about the rest API. It has been moved from misc to UI
[openHAB] Listing important changes for version 2.5.0:
Warning: senseBox Binding: The senseBox binding is now using Units of Measurements, and the channel name for Illuminance has changed. The Items must be reconfigured.
Warning: Vitotronic Binding: The following channels have been renamed: 'outsite_temp' to 'outside_temp', 'pelletburner:power' to 'pelletburner:powerlevel', 'party_temp' to 'party_temp_setpoint' and 'save_temp' to 'save_temp_setpoint'
Warning: OneWire Binding: Some thing types have changed and need to be updated in textual configurations. See documentation for further information.
Warning: REST Docs: This add-on is now part of the UIs. When installing it using textual configuration, update 'services/addons.cfg' by removing 'restdocs' from 'misc' and add it to 'ui' instead.
Warning: EnOcean Binding: Channel 'receivingState' has been removed, because this was a string containing many information. For this, there are three new channels: 'rssi', 'repeatCount' and 'lastReceived'.
Warning: Mail Action: The mail action has been replaced by a new mail binding.
Warning: Homekit: Some tags have been renamed. Old names will not be supported in future versions. Please check documentation.
Warning: Pushbullet Action: The pushbullet action has been replaced by a new pushbullet binding.
Warning: DarkSky Binding: The item type of `rain` and `snow` channels have been changed to `Number:Speed`.
Fix it the same place I fixed my problem ;
I updated all of the UI jar files from the Jenkins link. Now I can’t connect to my OH server. I never shut down fronttail and it is still running on my windows7 laptop. 0 error’s show up through the fronttail log. I have an ipad still connected to paper UI and if I try to refresh that it gives me a “Error 503 - Jersey not ready yet”. In addition prior to my reboot, but after installing all of the M2 UI’s everything on my OH welcome screen was duplicated. I suppose I could go in and remove all of the freshly added M2 UI’s but I would rather not. I would much prefer to keep the updated ones and remove the M1 UI’s. Can anyone with a much bigger brain then mine provide me with a suggestion? I did not import any M2 persistence files. Is this possibly where I went wrong? Also I can still connect to my openhabianpi from VSC. Thanks in advance for any help provided. We are Openhab Strong ![]()
in my addons.cfg there is no such ENTIRE
Hi @ollis112
Did you install the rest API thru the UI? (I haven’t used the UI for along time) ![]()
Maybe you can find it it somewhere here?
/var/lib/openhab2/config/org/openhab/addons.config
/etc/openhab2/services/runtime.cfg
/etc/openhab2/services/addons.cfg
A comma-separated list of miscellaneous services to install (e.g. “misc = myopenhab”)
misc =
all entries are preceded by a “#”
Ok, what about the other files?
Else you may habe better luck fixing it with openhab-cli
You can get list of installed bundles with bundle:list | grep -i rest
Here are my list from my M1 installation
openhab> bundle:list | grep -i rest
119 │ Active │ 80 │ 0.11.0.oh250M1 │ Eclipse SmartHome REST Interface Bundle
120 │ Active │ 80 │ 0.11.0.oh250M1 │ Eclipse SmartHome Core REST API
121 │ Active │ 80 │ 0.11.0.oh250M1 │ Eclipse SmartHome REST mDNS Announcer
122 │ Active │ 80 │ 0.11.0.oh250M1 │ Eclipse SmartHome REST Interface JAX-RS optimization Bundle
123 │ Active │ 80 │ 0.11.0.oh250M1 │ Eclipse SmartHome Sitemap REST API
124 │ Resolved │ 80 │ 0.11.0.oh250M1 │ Eclipse SmartHome SSE REST API
125 │ Active │ 80 │ 0.11.0.oh250M1 │ Eclipse SmartHome Voice REST API
243 │ Active │ 80 │ 2.5.0.M1 │ openHAB REST Documentation
And from my M2 installation:
151 │ Active │ 80 │ 2.5.0.M2 │ openHAB Core :: Bundles :: REST Interface
152 │ Active │ 80 │ 2.5.0.M2 │ openHAB Core :: Bundles :: REST Interface :: Core
153 │ Active │ 80 │ 2.5.0.M2 │ openHAB Core :: Bundles :: REST mDNS Announcer
154 │ Active │ 80 │ 2.5.0.M2 │ openHAB Core :: Bundles :: REST JAX-RS Optimizations
155 │ Active │ 80 │ 2.5.0.M2 │ openHAB Core :: Bundles :: Sitemap REST Interface
157 │ Active │ 80 │ 2.5.0.M2 │ openHAB Core :: Bundles :: Voice REST Interface
281 │ Active │ 80 │ 2.5.0.M2 │ openHAB UI :: Bundles :: openHAB REST API Documentation
You could try to uninstall it with
bundle:uninstall <ID>
My List is the same like your list
And now??
I’m sure there are something some where that has not been cleaned up.
Did you try to clear your cache?
I made a script to make it easy here: My point of view of Openhab2, stability and a few good to know stuff
Have you checked in
userdata/config/org/openhab/addons.config ?
My Cache is clear
Ok, could you post the content of the 3 files: ?
I had also installed the rest docs via paperui and had the same error message. You need to edit userdata/config/org/openhab/addons.config, as others have said, and remove restdocs from the misc=-line.
Then you can reinstall it through paperui.
Hi ![]()
I made a sum up of my findings here: My point of view of Openhab2, stability and a few good to know stuff - #7 by thorsen
Thank you first for your help. But after my system had crashed completely, I have to set it up anew.
Here is a question:
Can I restore the backup from 2.5M1 to M2?
If not, where can I get the M1 version to import the backup?
Many thanks
Hi @ollis112
You are welcome. Happy to help ![]()
You should be able to download 2.5M1 at the old repo by hand here: https://dl.bintray.com/openhab/apt-repo2/pool/main/2.5.0~M1/
OK, it will be installed this evening. Thank you
