Openhab Panel Network Device Status?
Hey guys.
I want to poll my Network Devices to see if they are online and display this on a OpenHab Panel maybe a chart or timeline.
does anyone have any suggestions on how to go about this?
Thanks?
This is the binding you want to look at: http://docs.openhab.org/addons/bindings/network/readme.html
Any ideas on how to integrate that with the Panel Display?
When the network binding determines your device is up/down (ie. like a switch), it will set the iterm property to ON/OFF. In the habpanel setup, in the simplest example, is add a switch widget to your panel and associate it to the item you defined for your network device.
The network binding can use a couple methods to determine if a network devices is ON of OFF, but from a panel display perspective, its essentially a switch.. its either up (ON) or down (OFF)
For HABPanel you could use the “Timeline” Widget to display the values.
Timeline Widget
Right, I did it that way some time ago.
Could look like this:
grafik
Your PS4 is obviously not ON enough! :smile:
