I have a running setup with openHab and KNX working. Now I’m adding some Shelly and tring to understand the “right” (as in “less workaround”…) way to get those two results:
Send an action from KNX (i.e. a GA get an ON command) > receive output on Shelly (i.e. a Shelly2.5 switch O1)
Send an action from Shelly (i.e. click with a button connected to SW2, in detached mode) > switch on a light connected to a KNX actuator
I can get it using rules, but I’m sure there is a “better” way.
I‘d prefer rules as they are more flexible and you can add other actions later on.
If you really do not want to use rules, have look here: follow profile
switch-control channels are received as command and the item will pass the command to the shelly channel. furthermore, if the shelly channel received a status update, the switch-sontrol channel will transmit this status update to knx.
In question of point 2, I’m not 100% sure, as I’m not using a shelly you can try the profile (set the link to the knx channel to profile="follow")
I have also implemented it like this. But unfortunately, the status is not displayed in KNX when the switch on the Shelly is pressed. It also doesn’t work with the [profile="follow"].
