d_valchev
(Dimitar)
September 9, 2023, 4:41pm
1
Hi all,
I connected Shelly Plus Add-On to Shelly Plus i4 DC (FW: 1.0.0-gaec0744).
The device has been discovered by the binding but no Add-On channels, like sensors, configured to the thing (i4DC’s ones are OK). However, OH Shelly Binding docs completely missing this scenario - attaching Shelly Plus Add-On to Shelly Plus i4 DC. So, my question is if this is something that could be easily added as supported binding feature? Also, how can I create manually the channels … if possible at all or this could be supported via binding only?
I’m new to the Shelly items and apologise if my questions are stupid.
10x
Edited: I’m running OH v 4.0.2
Oliver2
(Oliver)
September 9, 2023, 9:28pm
2
You better ask this question in this thread
I started to develop a binding for Shelly products. I have a Shelly1 and a Shelly2. These will be implemented and tested for the time being, the rest of the product family I will implement as well as possible, but can not test. Is there any interest in having the binding published in due course?
I’m only doing it because I wanted to work on programming bindings and I’m not really a fan of MQTT
You can just contact me and let me know if someone is interested or not.
This is where the maintainer answers questions
d_valchev
(Dimitar)
September 10, 2023, 7:38am
3
Thanks @Oliver2 , as recommended I created new post.
Hi, have you solved the problem with the temperature probes on ADDON? because I also have the same problem…thank you
@Riccardo1979 ,
After waiting couple of months for the binding to get supported the i4DC I decided to use http binding to retrieve the values out of the addon.
http.items
Number DS18B20_Temp1 "Temp [%.1f °]" <temperature> (gTempSensors) ["Measurement", "Temperature"] {
channel="http:url:<id>:http101"
Number Power_Supply "Power Supply [%.1f V]" <energy> (Sensors) ["Measurement", "Voltage"] {
channel="http:url:<id>:http100"
http thing sample (configured via UI)
UID: http:url:<id>
label: Shelly AddOn HTTP
thingTypeUID: http:url
configuration:
authMode: DIGEST
ignoreSSLErrors: true
baseURL: http://<shelly_ip>
password: '<your_shelly_password>'
delay: 5
stateMethod: GET
refresh: 60
commandMethod: GET
contentType: text/plain
timeout: 9000
bufferSize: 2048
username: <shelly_login_user>
channels:
- id: http101
channelTypeUID: http:number
label: AddOn Channel 101
description: http:shelly:sensor:temperature:101
configuration:
mode: READONLY
stateExtension: /rpc/Temperature.GetStatus?id=101
stateTransformation: REGEX:.*\"tC\":(\d*.\d*).*
- id: http100
label: AddOn Channel 100
description: Get Shelly Voltage via HTTP
configuration:
mode: READONLY
stateExtension: /rpc/Voltmeter.GetStatus?id=100
stateTransformation: REGEX:.*\"voltage\":(\d*.\d*).*
Not sure but I think the shelly binding still doesn’t support i4dc with addon.
Hello Dimitar,
I have been using several temperature sensors via Shelly 1 add-ons for several years. All integrated without any problems via the Shelly Binding. With the new Shelly Plus1 PM with addon, I don’t see any temperature values either. I spended hours to test and update and finally I coppied your code to the http thing and I was ready within 5 Minutes.
Looking out of the box can be quite helpful.
Thanks for your solution!
UID: http:url:test
label: Shelly temp http
configuration:
authMode: DIGEST
baseURL: http://xxx.yyy.zzz.iii
delay: 5
stateMethod: GET
refresh: 60
commandMethod: GET
timeout: 9000
bufferSize: 2048
channels:
- id: http101
configuration:
mode: READONLY
- id: http102
label: AddOn Channel 102
description: http:shelly:sensor:temperature:102
configuration:
mode: READONLY
stateExtension: /rpc/Temperature.GetStatus?id=102
- id: http103
label: AddOn Channel 103
description: http:shelly:sensor:temperature:103
configuration:
mode: READONLY
stateExtension: /rpc/Temperature.GetStatus?id=103
- id: http100
description: http:shelly:sensor:temperature:100
configuration:
mode: READONLY
stateExtension: /rpc/Temperature.GetStatus?id=100
