Openhab2 and EnOcean binding-problem
Hello community,
I have successfully installed OPENHAB2 on my pi.
Now I want to perform enocean binding. If I install this, it says that it is installed. However, I cannot find EnOcean at the inbox. Others like Z-Wave… EnOcean is the only one with a 1.12 version available…
Please help :slight_smile:
Some of the 1.x bindings wont appear in the inbox. Similar to the mqtt binding, you will need to configure everything from your items and services file located at /ect/openhab2. See the documentation examples to get setup https://www.openhab.org/addons/bindings/enocean1/#prerequisites
Hi Jerg (@Jerg_Marian),
try using the new Enocean-Binding: New openHab2 EnOcean binding
Best regards,
Alex
Hi Alex,
thanks a lot for your advice. It works great.
:slight_smile:
Hi Together,
Installation of OpenOcean worked so i want to connect an switch and an actor with OpenHab2. For the switch i’ve chosen the correct device and entered the id printed on the back site. For the actor i’ve chosen the device, activated teach in mode of the Actor and then pressed teach in at the device in OpenHab - but Nothing happens. If I press the switch, I see an LED flashing short on USB 300 Dongle. Nothing happens in OpenHab.
It would be very creatfull if anybody could help me to get it working.
Thanks a lot.
Marian
