OpenHab2 and Linear NGD00Z-4 Garage Door Controller
Ok I downloaded the zWave OH2 with Security Binding from (OH2 Z-Wave refactoring and testing... and SECURITY)
I reset my controller, deleted the original OH2 binding and then added the binding from above.
I then turned on Secure Mode for All Devices.
Then tried to Include the Linear NGD00Z Garage Door to the network.
Habmin reported that Secure Inclusion failed. I then tried Secure Inclusion from PaperUI and switched to Habmin to check the status. This time Habmin reported that Secure Inclusion succeeded.
The UI also shows Security is On.
However, I still see only 1 channel (BARRIER_POSITION). There is no channel to Control the Garage Door.
Attached below is my log file for secure inclusion.
@Chris - Any advice ? Is the Database complete for this device ? If not could we please add this to the database ?
GarageDoor-Log.xml (825.7 KB)
Seems from the logs that Security was successful. So not sure why I see only 1 channel for Door Position.
As per this post (Anybody interested in BARRIER_OPERATOR Zwave Command Class? - #36 by djarvis8), the 2nd channel should be: BARRIER_OPERATOR zWave Command Class and it has been available in OH2 for a long time. Then why do I not see the BARRIER_OPERATOR channel ?
@Chris - Any thoughts ?
Issue #2:
PS: Also after using the Secure Binding, I am no longer able to control my dimmers. They show unknown even though the device exists in the database (Reference ID: 556, Manufacturer: 001d. Type: 3201:0001). I was able to get the dimmers working with the latest snapshot binding.
@Chris - Could you please update the Secure zWave Binding to include the latest Database changes ?
