Now, I need to query the content of a post and map it to the switch, because the motion could be enabled/disabled from the IP-CAM interface as well. From cli, I can query the cam as follow:
Hostname was NOT found in DNS cache
* Trying <CAM-IP>...
* Connected to <CAM-IP> port 80 (#0)
* Server auth using Basic with user 'admin'
> POST /web/cgi-bin/hi3510/param.cgi HTTP/1.1
> Authorization: Basic MY-KEY
> User-Agent: curl/7.38.0
> Host: <CAM-IP>
> Accept: */*
> Content-Length: 13
> Content-Type: application/x-www-form-urlencoded
* upload completely sent off: 13 out of 13 bytes
< HTTP/1.1 200 OK
* Server Hipcam is not blacklisted
< Server: Hipcam
< Cache-Control: no-cache
< Content-Type:text/html
< Connection: close
< Content-Length: 544
var m1_enable="0";
var m1_x="0";
var m1_y="50";
var m1_w="1280";
var m1_h="670";
var m1_sensitivity="50";
var m1_threshold="0";
var m2_enable="0";
var m2_x="1120";
var m2_y="0";
var m2_w="160";
var m2_h="160";
var m2_sensitivity="50";
var m2_threshold="0";
var m3_enable="0";
var m3_x="0";
var m3_y="560";
var m3_w="160";
var m3_h="160";
var m3_sensitivity="50";
var m3_threshold="0";
var m4_enable="0";
var m4_x="1120";
var m4_y="560";
var m4_w="160";
var m4_h="160";
var m4_sensitivity="50";
var m4_threshold="0";
* Closing connection 0
What I need to get and MAP is the valie of m1_enable. If it’s m1_enable=0 the switch should be OFF, otherwise if m1_enable=1 then the switch should be ON.
Hello @Udo_Hartmann , thanks for the answer.
BTW I’m getting this error:
2017-08-07 17:19:16.045 [INFO ] [.internal.RegExTransformationService] - the given regular expression '^.*m1_enable=.(?).*$' doesn't contain a group. No content will be extracted and returned!
Then, I’ve noticed that I need to make a POST HTTP to get the values, I’ve tried this way, but seems not to work:
Sorry @Udo_Hartmann, I’ve made some step further.
I’ve used tcpdump to check if http requests are at least sent out to get the value status. The status is a different URL (getmdattr instead of setmdattr), so I can look if the URL is at least called.
Those are sent out well, also the syntax as written by you is ok (I’ve corrected only a little error I’ve made).
BTW I cannot get the values into the Item. The REGEX should be ok as well (AFAYK).
Maybe it’s a MAP issue, but I would like to debug the incoming answer to understand why it’s not mapped correctly to the item.
Any idea?
Thanks!
Simon
Well @Udo_Hartmann I think I’m really near to the solution.
I’m not able to use map.
I was able to tcpdump the requests and DEBUG from the console the log.
From the logs I get the http response and the error:
2017-08-08 16:01:03.147 [DEBUG] [he.commons.httpclient.HttpMethodBase] - Should close connection in response to directive: close
2017-08-08 16:01:03.151 [DEBUG] [he.commons.httpclient.HttpConnection] - Releasing connection back to connection manager.
2017-08-08 16:01:03.158 [DEBUG] [ab.binding.http.internal.HttpBinding] - transformed response is '1'
2017-08-08 16:01:03.163 [DEBUG] [ab.binding.http.internal.HttpBinding] - Couldn't create state for item 'IPCam02_MDetect' from string '1'
I’ve tried defining the Item as follow, but the map doesn’t work:
Again thank you @Udo_Hartmann for the help.
It seems there is an error on the script, but javascript is something not familiar for me as well.
Here the output:
2017-08-09 10:04:40.358 [ERROR] [ab.binding.http.internal.HttpBinding] - Transformation 'JS(getOnOff.js)' threw an exception. [response=var m1_enable="1";
var m1_x="0";
var m1_y="50";
var m1_w="1280";
var m1_h="670";
var m2_enable="0";
var m2_x="1120";
var m2_y="0";
var m2_w="160";
var m2_h="160";
var m3_enable="0";
var m3_x="0";
var m3_y="560";
var m3_w="160";
var m3_h="160";
var m4_enable="0";
var m4_x="1120";
var m4_y="560";
var m4_w="160";
var m4_h="160";
org.openhab.core.transform.TransformationException: An error occurred while loading script.
at org.openhab.core.transform.TransformationHelper$TransformationServiceDelegate.transform(TransformationHelper.java:62)[176:org.openhab.core.compat1x:2.2.0.201707122217]
at org.openhab.binding.http.internal.HttpBinding.execute(HttpBinding.java:189)[202:org.openhab.binding.http:1.11.0.201708050109]
at org.openhab.core.binding.AbstractActiveBinding$BindingActiveService.execute(AbstractActiveBinding.java:157)[176:org.openhab.core.compat1x:2.2.0.201707122217]
at org.openhab.core.service.AbstractActiveService$RefreshThread.run(AbstractActiveService.java:169)[176:org.openhab.core.compat1x:2.2.0.201707122217]
2017-08-09 10:04:40.361 [DEBUG] [ab.binding.http.internal.HttpBinding] - transformed response is 'var m1_enable="1";
var m1_x="0";
var m1_y="50";
var m1_w="1280";
var m1_h="670";
var m2_enable="0";
var m2_x="1120";
var m2_y="0";
var m2_w="160";
var m2_h="160";
var m3_enable="0";
var m3_x="0";
var m3_y="560";
var m3_w="160";
var m3_h="160";
var m4_enable="0";
var m4_x="1120";
var m4_y="560";
var m4_w="160";
var m4_h="160";
2017-08-09 10:04:40.362 [DEBUG] [ab.binding.http.internal.HttpBinding] - Couldn't create state for item 'IPCam02_MDetect' from string 'var m1_enable="1";
var m1_x="0";
var m1_y="50";
var m1_w="1280";
var m1_h="670";
var m2_enable="0";
var m2_x="1120";
var m2_y="0";
var m2_w="160";
var m2_h="160";
var m3_enable="0";
var m3_x="0";
var m3_y="560";
var m3_w="160";
var m3_h="160";
var m4_enable="0";
var m4_x="1120";
var m4_y="560";
var m4_w="160";
var m4_h="160";
Someone has an idea?
Could it be because this regex has a netsted result? Testing it online I get a two group result.
I’re restarted OH2 as well to be sure it’s correctly loaded.
Switch IPCam01_MDetect "Motion Detection - Soggiorno [%s]" { http=">[ON:POST:http://<CAM-IP>/web/cgi-bin/hi3510/param.cgi?cmd=setmdattr&-name=1&-enable=1{Authorization=Basic YWRtaW46Yms4NjdzbXhlZmls}] >[OFF:POST:http://<CAM-IP>/web/cgi-bin/hi3510/param.cgi?cmd=setmdattr&-name=1&-enable=0{Authorization=Basic YWRtaW46Yms4NjdzbXhlZmls}] <[http://<CAM-IP>/web/cgi-bin/hi3510/param.cgi?cmd=getmdattr{Authorization=Basic YWRtaW46Yms4NjdzbXhlZmls}:12000:JS(getOnOff.js)]" }
# cat getOnOff.js
(function(i) {
var re = new RegExp('.*m1_enable=.(.).*');
var out = i.replace("$1");
return if(out=="1") ON else OFF;
})(input)
Response:
2017-08-10 11:07:43.987 [DEBUG] [ab.binding.http.internal.HttpBinding] - item 'IPCam01_MDetect' is about to be refreshed now
2017-08-10 11:07:43.988 [DEBUG] [.httpclient.params.DefaultHttpParams] - Set parameter http.socket.timeout = 5000
2017-08-10 11:07:43.989 [DEBUG] [.httpclient.params.DefaultHttpParams] - Set parameter http.method.retry-handler = org.apache.commons.httpclient.DefaultHttpMethodRetryHandler@8c2ed9
2017-08-10 11:07:43.990 [DEBUG] [he.commons.httpclient.HttpConnection] - Open connection to <CAM-IP>:80
2017-08-10 11:07:43.996 [DEBUG] [httpclient.wire.header ] - >> "GET /web/cgi-bin/hi3510/param.cgi?cmd=getmdattr HTTP/1.1[\r][\n]"
2017-08-10 11:07:43.998 [DEBUG] [he.commons.httpclient.HttpMethodBase] - Adding Host request header
2017-08-10 11:07:43.999 [DEBUG] [httpclient.wire.header ] - >> "Authorization: Basic YWRtaW46Yms4NjdzbXhlZmls[\r][\n]"
2017-08-10 11:07:44.000 [DEBUG] [httpclient.wire.header ] - >> "User-Agent: Jakarta Commons-HttpClient/3.1[\r][\n]"
2017-08-10 11:07:44.001 [DEBUG] [httpclient.wire.header ] - >> "Host: <CAM-IP>[\r][\n]"
2017-08-10 11:07:44.001 [DEBUG] [httpclient.wire.header ] - >> "[\r][\n]"
2017-08-10 11:07:44.009 [DEBUG] [httpclient.wire.header ] - << "HTTP/1.1 200 OK[\r][\n]"
2017-08-10 11:07:44.010 [DEBUG] [httpclient.wire.header ] - << "HTTP/1.1 200 OK[\r][\n]"
2017-08-10 11:07:44.011 [DEBUG] [httpclient.wire.header ] - << "Server: Hipcam[\r][\n]"
2017-08-10 11:07:44.012 [DEBUG] [httpclient.wire.header ] - << "Cache-Control: no-cache[\r][\n]"
2017-08-10 11:07:44.013 [DEBUG] [httpclient.wire.header ] - << "Content-Type:text/html[\r][\n]"
2017-08-10 11:07:44.014 [DEBUG] [httpclient.wire.header ] - << "Connection: close[\r][\n]"
2017-08-10 11:07:44.014 [DEBUG] [httpclient.wire.header ] - << "Content-Length: 545[\r][\n]"
2017-08-10 11:07:44.015 [DEBUG] [httpclient.wire.header ] - << "[\r][\n]"
2017-08-10 11:07:44.016 [DEBUG] [httpclient.wire.content ] - << " var m1_enable="1";[\r][\n]"
2017-08-10 11:07:44.017 [DEBUG] [httpclient.wire.content ] - << " var m1_x="30";[\r][\n]"
2017-08-10 11:07:44.018 [DEBUG] [httpclient.wire.content ] - << " var m1_y="31";[\r][\n]"
2017-08-10 11:07:44.018 [DEBUG] [httpclient.wire.content ] - << " var m1_w="1214";[\r][\n]"
2017-08-10 11:07:44.019 [DEBUG] [httpclient.wire.content ] - << " var m1_h="667";[\r][\n]"
2017-08-10 11:07:44.019 [DEBUG] [httpclient.wire.content ] - << " var m1_sensitivity="50";[\r][\n]"
2017-08-10 11:07:44.020 [DEBUG] [httpclient.wire.content ] - << " var m1_threshold="0";[\r][\n]"
2017-08-10 11:07:44.021 [DEBUG] [httpclient.wire.content ] - << " var m2_enable="0";[\r][\n]"
2017-08-10 11:07:44.021 [DEBUG] [httpclient.wire.content ] - << " var m2_x="1120";[\r][\n]"
2017-08-10 11:07:44.022 [DEBUG] [httpclient.wire.content ] - << " var m2_y="0";[\r][\n]"
2017-08-10 11:07:44.022 [DEBUG] [httpclient.wire.content ] - << " var m2_w="160";[\r][\n]"
2017-08-10 11:07:44.023 [DEBUG] [httpclient.wire.content ] - << " var m2_h="160";[\r][\n]"
2017-08-10 11:07:44.023 [DEBUG] [httpclient.wire.content ] - << " var m2_sensitivity="50";[\r][\n]"
2017-08-10 11:07:44.024 [DEBUG] [httpclient.wire.content ] - << " var m2_threshold="0";[\r][\n]"
2017-08-10 11:07:44.025 [DEBUG] [httpclient.wire.content ] - << " var m3_enable="0";[\r][\n]"
2017-08-10 11:07:44.025 [DEBUG] [httpclient.wire.content ] - << " var m3_x="0";[\r][\n]"
2017-08-10 11:07:44.026 [DEBUG] [httpclient.wire.content ] - << " var m3_y="560";[\r][\n]"
2017-08-10 11:07:44.026 [DEBUG] [httpclient.wire.content ] - << " var m3_w="160";[\r][\n]"
2017-08-10 11:07:44.027 [DEBUG] [httpclient.wire.content ] - << " var m3_h="160";[\r][\n]"
2017-08-10 11:07:44.027 [DEBUG] [httpclient.wire.content ] - << " var m3_sensitivity="50";[\r][\n]"
2017-08-10 11:07:44.028 [DEBUG] [httpclient.wire.content ] - << " var m3_threshold="0";[\r][\n]"
2017-08-10 11:07:44.029 [DEBUG] [httpclient.wire.content ] - << " var m4_enable="0";[\r][\n]"
2017-08-10 11:07:44.029 [DEBUG] [httpclient.wire.content ] - << " var m4_x="1120";[\r][\n]"
2017-08-10 11:07:44.030 [DEBUG] [httpclient.wire.content ] - << " var m4_y="560";[\r][\n]"
2017-08-10 11:07:44.030 [DEBUG] [httpclient.wire.content ] - << " var m4_w="160";[\r][\n]"
2017-08-10 11:07:44.031 [DEBUG] [httpclient.wire.content ] - << " var m4_h="160";[\r][\n]"
2017-08-10 11:07:44.031 [DEBUG] [httpclient.wire.content ] - << " var m4_sensitivity="50";[\r][\n]"
2017-08-10 11:07:44.032 [DEBUG] [httpclient.wire.content ] - << " var m4_threshold="0";[\r][\n]"
2017-08-10 11:07:44.033 [DEBUG] [he.commons.httpclient.HttpMethodBase] - Should close connection in response to directive: close
2017-08-10 11:07:44.034 [DEBUG] [he.commons.httpclient.HttpConnection] - Releasing connection back to connection manager.
2017-08-10 11:07:44.036 [ERROR] [ab.binding.http.internal.HttpBinding] - Transformation 'JS(getOnOff.js)' threw an exception. [response= var m1_enable="1";
var m1_x="30";
var m1_y="31";
var m1_w="1214";
var m1_h="667";
var m2_enable="0";
var m2_x="1120";
var m2_y="0";
var m2_w="160";
var m2_h="160";
var m3_enable="0";
var m3_x="0";
var m3_y="560";
var m3_w="160";
var m3_h="160";
var m4_enable="0";
var m4_x="1120";
var m4_y="560";
var m4_w="160";
var m4_h="160";
2017-08-10 11:07:44.039 [DEBUG] [ab.binding.http.internal.HttpBinding] - transformed response is ' var m1_enable="1";
var m1_x="30";
var m1_y="31";
var m1_w="1214";
var m1_h="667";
var m2_enable="0";
var m2_x="1120";
var m2_y="0";
var m2_w="160";
var m2_h="160";
var m3_enable="0";
var m3_x="0";
var m3_y="560";
var m3_w="160";
var m3_h="160";
var m4_enable="0";
var m4_x="1120";
var m4_y="560";
var m4_w="160";
var m4_h="160";
2017-08-10 11:07:44.040 [DEBUG] [ab.binding.http.internal.HttpBinding] - Couldn't create state for item 'IPCam01_MDetect' from string ' var m1_enable="1";
var m1_x="30";
var m1_y="31";
var m1_w="1214";
var m1_h="667";
var m2_enable="0";
var m2_x="1120";
var m2_y="0";
var m2_w="160";
var m2_h="160";
var m3_enable="0";
var m3_x="0";
var m3_y="560";
var m3_w="160";
var m3_h="160";
var m4_enable="0";
var m4_x="1120";
var m4_y="560";
var m4_w="160";
var m4_h="160";
# cat getOnOff.js
(function(i) {
var out = i.replace(re, "$1");
})(input)
Could it possible it ha ssomething to do with the newline of the response or strange characters like ";[\r][\n]" or the " ?
Debug result:
2017-08-10 15:19:51.339 [DEBUG] [he.commons.httpclient.HttpConnection] - Open connection to <CAM-IP>:80
2017-08-10 15:19:51.348 [DEBUG] [httpclient.wire.header ] - >> "GET /web/cgi-bin/hi3510/param.cgi?cmd=getmdattr HTTP/1.1[\r][\n]"
2017-08-10 15:19:51.350 [DEBUG] [he.commons.httpclient.HttpMethodBase] - Adding Host request header
2017-08-10 15:19:51.351 [DEBUG] [httpclient.wire.header ] - >> "Authorization: Basic YWRtaW46Yms4NjdzbXhlZmls[\r][\n]"
2017-08-10 15:19:51.352 [DEBUG] [httpclient.wire.header ] - >> "User-Agent: Jakarta Commons-HttpClient/3.1[\r][\n]"
2017-08-10 15:19:51.353 [DEBUG] [httpclient.wire.header ] - >> "Host: <CAM-IP>[\r][\n]"
2017-08-10 15:19:51.354 [DEBUG] [httpclient.wire.header ] - >> "[\r][\n]"
2017-08-10 15:19:51.363 [DEBUG] [httpclient.wire.header ] - << "HTTP/1.1 200 OK[\r][\n]"
2017-08-10 15:19:51.364 [DEBUG] [httpclient.wire.header ] - << "HTTP/1.1 200 OK[\r][\n]"
2017-08-10 15:19:51.365 [DEBUG] [httpclient.wire.header ] - << "Server: Hipcam[\r][\n]"
2017-08-10 15:19:51.366 [DEBUG] [httpclient.wire.header ] - << "Cache-Control: no-cache[\r][\n]"
2017-08-10 15:19:51.367 [DEBUG] [httpclient.wire.header ] - << "Content-Type:text/html[\r][\n]"
2017-08-10 15:19:51.368 [DEBUG] [httpclient.wire.header ] - << "Connection: close[\r][\n]"
2017-08-10 15:19:51.369 [DEBUG] [httpclient.wire.header ] - << "Content-Length: 545[\r][\n]"
2017-08-10 15:19:51.370 [DEBUG] [httpclient.wire.header ] - << "[\r][\n]"
2017-08-10 15:19:51.371 [DEBUG] [httpclient.wire.content ] - << " var m1_enable="1";[\r][\n]"
2017-08-10 15:19:51.372 [DEBUG] [httpclient.wire.content ] - << " var m1_x="30";[\r][\n]"
2017-08-10 15:19:51.373 [DEBUG] [httpclient.wire.content ] - << " var m1_y="31";[\r][\n]"
2017-08-10 15:19:51.374 [DEBUG] [httpclient.wire.content ] - << " var m1_w="1214";[\r][\n]"
2017-08-10 15:19:51.375 [DEBUG] [httpclient.wire.content ] - << " var m1_h="667";[\r][\n]"
2017-08-10 15:19:51.375 [DEBUG] [httpclient.wire.content ] - << " var m1_sensitivity="50";[\r][\n]"
2017-08-10 15:19:51.376 [DEBUG] [httpclient.wire.content ] - << " var m1_threshold="0";[\r][\n]"
2017-08-10 15:19:51.377 [DEBUG] [httpclient.wire.content ] - << " var m2_enable="0";[\r][\n]"
2017-08-10 15:19:51.377 [DEBUG] [httpclient.wire.content ] - << " var m2_x="1120";[\r][\n]"
2017-08-10 15:19:51.378 [DEBUG] [httpclient.wire.content ] - << " var m2_y="0";[\r][\n]"
2017-08-10 15:19:51.379 [DEBUG] [httpclient.wire.content ] - << " var m2_w="160";[\r][\n]"
2017-08-10 15:19:51.380 [DEBUG] [httpclient.wire.content ] - << " var m2_h="160";[\r][\n]"
2017-08-10 15:19:51.380 [DEBUG] [httpclient.wire.content ] - << " var m2_sensitivity="50";[\r][\n]"
2017-08-10 15:19:51.381 [DEBUG] [httpclient.wire.content ] - << " var m2_threshold="0";[\r][\n]"
2017-08-10 15:19:51.382 [DEBUG] [httpclient.wire.content ] - << " var m3_enable="0";[\r][\n]"
2017-08-10 15:19:51.390 [DEBUG] [httpclient.wire.content ] - << " var m3_x="0";[\r][\n]"
2017-08-10 15:19:51.393 [DEBUG] [httpclient.wire.content ] - << " var m3_y="560";[\r][\n]"
2017-08-10 15:19:51.394 [DEBUG] [httpclient.wire.content ] - << " var m3_w="160";[\r][\n]"
2017-08-10 15:19:51.395 [DEBUG] [httpclient.wire.content ] - << " var m3_h="160";[\r][\n]"
2017-08-10 15:19:51.395 [DEBUG] [httpclient.wire.content ] - << " var m3_sensitivity="50";[\r][\n]"
2017-08-10 15:19:51.396 [DEBUG] [httpclient.wire.content ] - << " var m3_threshold="0";[\r][\n]"
2017-08-10 15:19:51.396 [DEBUG] [httpclient.wire.content ] - << " var m4_enable="0";[\r][\n]"
2017-08-10 15:19:51.397 [DEBUG] [httpclient.wire.content ] - << " var m4_x="1120";[\r][\n]"
2017-08-10 15:19:51.399 [DEBUG] [httpclient.wire.content ] - << " var m4_y="560";[\r][\n]"
2017-08-10 15:19:51.399 [DEBUG] [httpclient.wire.content ] - << " var m4_w="160";[\r][\n]"
2017-08-10 15:19:51.400 [DEBUG] [httpclient.wire.content ] - << " var m4_h="160";[\r][\n]"
2017-08-10 15:19:51.401 [DEBUG] [httpclient.wire.content ] - << " var m4_sensitivity="50";[\r][\n]"
2017-08-10 15:19:51.401 [DEBUG] [httpclient.wire.content ] - << " var m4_threshold="0";[\r][\n]"
2017-08-10 15:19:51.402 [DEBUG] [he.commons.httpclient.HttpMethodBase] - Should close connection in response to directive: close
2017-08-10 15:19:51.403 [DEBUG] [he.commons.httpclient.HttpConnection] - Releasing connection back to connection manager.
2017-08-10 15:19:51.405 [ERROR] [ab.binding.http.internal.HttpBinding] - Transformation 'JS(getOnOff.js)' threw an exception. [response= var m1_enable="1";
var m1_x="30";
var m1_y="31";
var m1_w="1214";
var m1_h="667";
var m2_enable="0";
var m2_x="1120";
var m2_y="0";
var m2_w="160";
var m2_h="160";
var m3_enable="0";
var m3_x="0";
var m3_y="560";
var m3_w="160";
var m3_h="160";
var m4_enable="0";
var m4_x="1120";
var m4_y="560";
var m4_w="160";
var m4_h="160";
2017-08-10 15:19:51.407 [DEBUG] [ab.binding.http.internal.HttpBinding] - transformed response is ' var m1_enable="1";
var m1_x="30";
var m1_y="31";
var m1_w="1214";
var m1_h="667";
var m2_enable="0";
var m2_x="1120";
var m2_y="0";
var m2_w="160";
var m2_h="160";
var m3_enable="0";
var m3_x="0";
var m3_y="560";
var m3_w="160";
var m3_h="160";
var m4_enable="0";
var m4_x="1120";
var m4_y="560";
var m4_w="160";
var m4_h="160";
2017-08-10 15:19:51.411 [DEBUG] [ab.binding.http.internal.HttpBinding] - Couldn't create state for item 'IPCam01_MDetect' from string ' var m1_enable="1";
var m1_x="30";
var m1_y="31";
var m1_w="1214";
var m1_h="667";
var m2_enable="0";
var m2_x="1120";
var m2_y="0";
var m2_w="160";
var m2_h="160";
var m3_enable="0";
var m3_x="0";
var m3_y="560";
var m3_w="160";
var m3_h="160";
var m4_enable="0";
var m4_x="1120";
var m4_y="560";
var m4_w="160";
var m4_h="160";
Thanks for your time
In addition, shouldnt var out an array?
Isn’t possible to debug what the javascript is doing? With some console.log? It dosn’t work…
Unfortunately it doesn’t work? What am I doing wrong? For switching I used a normal switch widget. It also does not change the visible status of On->OFF or OFF-ON when clicked. I always have to reload the page completely.
MDAR
#16
2018-11-05 16:26:13.562 [ERROR] [el.item.internal.GenericItemProvider] - Binding configuration of type 'http' of item 'Eth484Relay1' could not be parsed correctly.
org.eclipse.smarthome.model.item.BindingConfigParseException: bindingConfig '*:http://192.168.178.160/io.cgi?DOA1' doesn't contain a valid out-binding-configuration. A valid configuration is matched by the RegExp '(.*?):([A-Z]*):(.*)'
at org.openhab.core.binding.internal.BindingConfigReaderDelegate.processBindingConfiguration(BindingConfigReaderDelegate.java:51) ~[?:?]
at org.eclipse.smarthome.model.item.internal.GenericItemProvider.internalDispatchBindings(GenericItemProvider.java:397) ~[?:?]
at org.eclipse.smarthome.model.item.internal.GenericItemProvider.internalDispatchBindings(GenericItemProvider.java:366) ~[?:?]
at org.eclipse.smarthome.model.item.internal.GenericItemProvider.processBindingConfigsFromModel(GenericItemProvider.java:229) ~[?:?]
at org.eclipse.smarthome.model.item.internal.GenericItemProvider.modelChanged(GenericItemProvider.java:432) ~[?:?]
at org.eclipse.smarthome.model.core.internal.ModelRepositoryImpl.notifyListeners(ModelRepositoryImpl.java:301) ~[?:?]
at org.eclipse.smarthome.model.core.internal.ModelRepositoryImpl.addOrRefreshModel(ModelRepositoryImpl.java:139) ~[?:?]
at org.eclipse.smarthome.model.core.internal.folder.FolderObserver.checkFile(FolderObserver.java:227) ~[?:?]
at org.eclipse.smarthome.model.core.internal.folder.FolderObserver.processWatchEvent(FolderObserver.java:291) ~[?:?]
at org.eclipse.smarthome.core.service.WatchQueueReader.lambda$3(WatchQueueReader.java:323) ~[?:?]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$201(ScheduledThreadPoolExecutor.java:180) [?:?]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:293) [?:?]
Caused by: org.openhab.model.item.binding.BindingConfigParseException: bindingConfig '*:http://192.168.178.160/io.cgi?DOA1' doesn't contain a valid out-binding-configuration. A valid configuration is matched by the RegExp '(.*?):([A-Z]*):(.*)'
at org.openhab.binding.http.internal.HttpGenericBindingProvider.parseOutBindingConfig(HttpGenericBindingProvider.java:254) ~[?:?]
at org.openhab.binding.http.internal.HttpGenericBindingProvider.parseBindingConfig(HttpGenericBindingProvider.java:155) ~[?:?]
at org.openhab.binding.http.internal.HttpGenericBindingProvider.processBindingConfiguration(HttpGenericBindingProvider.java:119) ~[?:?]
at org.openhab.core.binding.internal.BindingConfigReaderDelegate.processBindingConfiguration(BindingConfigReaderDelegate.java:49) ~[?:?]
... 16 more
2018-11-05 16:26:13.663 [ERROR] [el.item.internal.GenericItemProvider] - Binding configuration of type 'http' of item 'Eth484Relay2' could not be parsed correctly.
org.eclipse.smarthome.model.item.BindingConfigParseException: bindingConfig 'ON:http://192.168.178.160/io.cgi?DOA2' doesn't contain a valid out-binding-configuration. A valid configuration is matched by the RegExp '(.*?):([A-Z]*):(.*)'
Caused by: org.openhab.model.item.binding.BindingConfigParseException: bindingConfig 'ON:http://192.168.178.160/io.cgi?DOA2' doesn't contain a valid out-binding-configuration. A valid configuration is matched by the RegExp '(.*?):([A-Z]*):(.*)'
... 16 more
2018-11-05 16:53:30.711 [INFO ] [el.core.internal.ModelRepositoryImpl] - Refreshing model 'http.items'
2018-11-05 16:53:30.729 [ERROR] [el.item.internal.GenericItemProvider] - Binding configuration of type 'http' of item 'Eth484Relay1' could not be parsed correctly.
org.eclipse.smarthome.model.item.BindingConfigParseException: bindingConfig 'ON:http://192.168.178.160/io.cgi?DOA1' doesn't contain a valid out-binding-configuration. A valid configuration is matched by the RegExp '(.*?):([A-Z]*):(.*)'
Caused by: org.openhab.model.item.binding.BindingConfigParseException: bindingConfig 'ON:http://192.168.178.160/io.cgi?DOA1' doesn't contain a valid out-binding-configuration. A valid configuration is matched by the RegExp '(.*?):([A-Z]*):(.*)'
... 16 more
2018-11-05 16:53:30.830 [ERROR] [el.item.internal.GenericItemProvider] - Binding configuration of type 'http' of item 'Eth484Relay2' could not be parsed correctly.
... 16 more
I assume that the key to my downfall has something to do with this line
