That was indeed the issue, I think it was on v4 from an old integration. I updated the permissions and it now works fine.
Same here, nest structure, account and thermostat goes offline.
I can control Nest itself with android app, so it can send / receive data.
After I restart Openhab, nest is online in Things meniu again, after arround 3,5 h it went offline again.
Now it happens when i switched my routers, with the old one as I remember it was always online.
Canāt enable log as you wrote, maybe doing it not in the right place, see:
Did you also test with openHAB 2.2.0 that got released today @Justas?
Some additional bug fixes were merged just before the openHAB 2.2.0 release was made. Time will tell if they solve all connection issues.
The old (1.x) binding was using a polling mechanism (max 1 update per minute due to Nest API rate limits) whereas the new binding is now using Server-sent Events (SSE). So you should instantly have the data when it is sent by your devices to Nest. Especially with a fire/smoke alarm that can make a big difference (when it works ofcourse ).
The Jersey library used by the binding for SSE seems to have some issues when connections disconnect for which a workaround was created.
Those commands are executed in the Console.
Iāve created another org.openhab.binding.nest-2.2.0-fahrenheit.jar with all the features and fixes as in the final openHAB 2.2.0 release but using Fahrenheit instead of Celsius.
The code is in the same nest-fahrenheit branch on GitHub.
I was just about to ask about this. Thanks!!
Successfully running.
Thanks for the help in this post, I finally got the Nest working for me, but I would like to know if there is a way that the binding can report the temperatures in Fahrenheit (in the US, we rarely use Celsius)?
Thanks,
~John
3 posts above youā¦
Donāt know how I missed it, got it installedā¦ now to work on some custom icons
Just upgraded to 2.2, so I thought Iād try the new nest binding, but no luck.
I still have the old nest1 binding running - can I have both? or just one?
I added the nest binding to my addons.cfg, and the Thing shows up. I enter my prodict id, and secret, then enter the one-time pin (from the website), but it mostly wont save. The thing just sits there marked āuninitializedā. Even on the one or two occasions when I have got it to save, it still just says āuninitializedā with no OAuth code and the PIN shown.
Most people seem to have this working, so I must be doing something stupid.
What am I missing?
Does it list the Nest 2.2.0 binding in āPaper UI ā Configuration ā Bindingsā and as Active in the Console?
openhab> bundle:list | grep Nest
228 ā Active ā 80 ā 2.2.0 ā Nest Binding
Yes to both, the binding is listed, and shows as active in the console.
When I delete the Thing, and re-add it, I get this in the log:
2017-12-22 14:15:58.449 [WARN ] [ore.thing.internal.ThingRegistryImpl] - Cannot create thing. No binding found that supports creating a thing of type 'nest:account'.
I also get:
Status: UNINITIALIZED - HANDLER_REGISTERING_ERROR org.eclipse.smarthome.core.thing.internal.ThingImpl cannot be cast to org.eclipse.smarthome.core.thing.Bridge
OK, I think I figured out what is the problem.
You cant have nest1 and nest loaded at the same time, itās one or the other. I uninstalled nest1, installed nest (v2.2), and bingo! the account is now online.
Now have to figure out the channelsā¦
Hmmm, donāt seem to be anywhere near as many channels as the documentation says. Maybe Iāll try the latest SNAPSHOT see if that helps.
Thereās also a āShow Moreā button at the right of the listed channels.
So There is! didnāt see that.
Thanks,
Trying to uninstall the default 2.2.0 addon via PaperUI (so I can install the Fahrenheit addon), but it just sits with the wheel spinning forever? Iāve commented out my Nest things, but that hasnāt helped either. Nothing showing an error in events.logā¦
Thanks for the help getting this working.
Iām havjng trouble getting a switch to respond to the hvac state and mode. These are String channels, so I should be able to map a Switch to the various values, which are āheatingā, ā coolingā, āheat/coolā, and āoffā I believe.
This is my sitemap:
Switch item=dining_room_hvac_mode mappings=["heating"="Heat","cooling"="Cool","heat/cool"="Auto","off"="Off"]
Switch item=dining_room_hvac_state mappings=["heating"="Heat","cooling"="Cool","off"="Idle"]
Where the items are String types. This construct works fine elsewhere, and the channels are not mapped to other values at all. Is this an openhab 2.2 issue, or am I missing something?
Also I see that there are no channels for the Nest Protect that give the date/time of the last connection, or last manual test (just manual test in progress as a switch). Itās hard to tell if the smoke alarms are connected without this information, can I vote for including these channels (they were in the V1.0 binding).
Thanks.
Is there a way to get the temperature to display as 71 instead of 71.0?
Also, when trying to set the setpoint channel, it throws the following error:
2017-12-24 16:21:28.140 [WARN ] [nding.nest.handler.NestBridgeHandler] - Nest API error: Temperature C value is too high: 67.0
Looks like this value is still celsius.
Yes @wborn, it works now flawlessly for 1 week already.
Upgrading to 2.2.0 helped, thank You!
