in OH 1.8 I got the RWE binding running, that was not a problem.
Now I’m trying OH2 beta 3 and would like to have a look at it, too. In Paper UI → Extensions I installed the binding-rwesmarthome - 1.9.0.b3.
In the Inbox I see nothing…
So I have some questions:
What about the java option -Djdk.tls.client.protocols=TLSv1. Do I have to add it somewhere? If yes, where? I’m trying OH2 on Win10 now, but am planning to install it “productive” on a Raspberry Pi 3.
Do I need to create a config file for the Binding? Where, and how should it be named?
Should I see something in the inbox at all for the binding?
The RWE Binding is not yet updated to support Autodiscovery in OH2 (due to maybe upcoming changes in RWE Smarthome), so you should not see anything in the inbox, as far as I know.
You have to create a file named rwesmarthome.cfg in /configurations/services with the Rwe-related content from your old openhab.cfg-File (but remove the “rwesmarthome.”-Prefix from the items, as that is no longer needed.
thanks for your help.
I hate to say it, but after a clean install of OH2 on my RPi3 I did exactly what you suggested - with no effect. Also checked, that the file is in UNIX format. At that point there was nothing installed but the OH2 offline setup, HABmin and the RWE Smarthome Binding.
I just installed the Snapshot-release instead of the b3 and now it doesn’t work for me either. I get this error, which seems to be an old bug:
2016-08-29 12:26:14.670 [ERROR] [org.openhab.binding.rwesmarthome ] - [org.openhab.binding.rwesmarthome.genericbindingprovider(161)] Circular reference detected, getService returning null 2016-08-29 12:26:14.883 [WARN ] [org.openhab.binding.rwesmarthome ] - FrameworkEvent WARNING - org.openhab.binding.rwesmarthome org.osgi.framework.ServiceException: org.apache.felix.scr.impl.manager.SingleComponentManager.getService() returned a null service object at org.eclipse.osgi.internal.serviceregistry.ServiceFactoryUse.factoryGetService(ServiceFactoryUse.java:232)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:] at org.eclipse.osgi.internal.serviceregistry.ServiceFactoryUse.getService(ServiceFactoryUse.java:111)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:] at org.eclipse.osgi.internal.serviceregistry.ServiceConsumer$2.getService(ServiceConsumer.java:45)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:] at org.eclipse.osgi.internal.serviceregistry.ServiceRegistrationImpl.getService(ServiceRegistrationImpl.java:496)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:] at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.getService(ServiceRegistry.java:461)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:] at org.eclipse.osgi.internal.framework.BundleContextImpl.getService(BundleContextImpl.java:619)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:] at org.apache.felix.scr.impl.manager.SingleRefPair.getServiceObject(SingleRefPair.java:72) at org.apache.felix.scr.impl.helper.BindMethod.getServiceObject(BindMethod.java:646) at org.apache.felix.scr.impl.manager.DependencyManager.getServiceObject(DependencyManager.java:2137) at org.apache.felix.scr.impl.manager.DependencyManager$MultipleDynamicCustomizer.prebind(DependencyManager.java:389) at org.apache.felix.scr.impl.manager.DependencyManager.prebind(DependencyManager.java:1457) at org.apache.felix.scr.impl.manager.AbstractComponentManager.collectDependencies(AbstractComponentManager.java:983)[32:org.apache.felix.scr:2.0.2] at org.apache.felix.scr.impl.manager.SingleComponentManager.getServiceInternal(SingleComponentManager.java:812)[32:org.apache.felix.scr:2.0.2] at org.apache.felix.scr.impl.manager.AbstractComponentManager.activateInternal(AbstractComponentManager.java:724)[32:org.apache.felix.scr:2.0.2] at org.apache.felix.scr.impl.manager.AbstractComponentManager.enable(AbstractComponentManager.java:399)[32:org.apache.felix.scr:2.0.2] at org.apache.felix.scr.impl.config.ConfigurableComponentHolder.enableComponents(ConfigurableComponentHolder.java:676)[32:org.apache.felix.scr:2.0.2] at org.apache.felix.scr.impl.BundleComponentActivator.initialEnable(BundleComponentActivator.java:339)[32:org.apache.felix.scr:2.0.2] at org.apache.felix.scr.impl.Activator.loadComponents(Activator.java:360)[32:org.apache.felix.scr:2.0.2] at org.apache.felix.scr.impl.Activator.access$000(Activator.java:53)[32:org.apache.felix.scr:2.0.2] at org.apache.felix.scr.impl.Activator$ScrExtension.start(Activator.java:260)[32:org.apache.felix.scr:2.0.2] at org.apache.felix.utils.extender.AbstractExtender.createExtension(AbstractExtender.java:259)[32:org.apache.felix.scr:2.0.2] at org.apache.felix.utils.extender.AbstractExtender.modifiedBundle(AbstractExtender.java:232)[32:org.apache.felix.scr:2.0.2] at org.apache.felix.utils.extender.AbstractExtender.addingBundle(AbstractExtender.java:192)[32:org.apache.felix.scr:2.0.2] at org.osgi.util.tracker.BundleTracker$Tracked.customizerAdding(BundleTracker.java:469)[org.osgi.core-6.0.0.jar:] at org.osgi.util.tracker.BundleTracker$Tracked.customizerAdding(BundleTracker.java:415)[org.osgi.core-6.0.0.jar:] at org.osgi.util.tracker.AbstractTracked.trackAdding(AbstractTracked.java:256)[org.osgi.core-6.0.0.jar:] at org.osgi.util.tracker.AbstractTracked.track(AbstractTracked.java:229)[org.osgi.core-6.0.0.jar:] at org.osgi.util.tracker.BundleTracker$Tracked.bundleChanged(BundleTracker.java:444)[org.osgi.core-6.0.0.jar:] at org.eclipse.osgi.internal.framework.BundleContextImpl.dispatchEvent(BundleContextImpl.java:902)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:] at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:] at org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEventSynchronous(ListenerQueue.java:148)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:] at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEventPrivileged(EquinoxEventPublisher.java:165)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:] at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEvent(EquinoxEventPublisher.java:75)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:] at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEvent(EquinoxEventPublisher.java:67)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:] at org.eclipse.osgi.internal.framework.EquinoxContainerAdaptor.publishModuleEvent(EquinoxContainerAdaptor.java:102)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:] at org.eclipse.osgi.container.Module.publishEvent(Module.java:466)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:] at org.eclipse.osgi.container.Module.doStart(Module.java:538)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:] at org.eclipse.osgi.container.Module.start(Module.java:439)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:] at org.eclipse.osgi.framework.util.SecureAction.start(SecureAction.java:454)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:] at org.eclipse.osgi.internal.hooks.EclipseLazyStarter.postFindLocalClass(EclipseLazyStarter.java:107)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:] at org.eclipse.osgi.internal.loader.classpath.ClasspathManager.findLocalClass(ClasspathManager.java:531)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:] at org.eclipse.osgi.internal.loader.ModuleClassLoader.findLocalClass(ModuleClassLoader.java:324)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:] at org.eclipse.osgi.internal.loader.BundleLoader.findLocalClass(BundleLoader.java:320)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:] at org.eclipse.osgi.internal.loader.sources.SingleSourcePackage.loadClass(SingleSourcePackage.java:36)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:] at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:379)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:] at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:345)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:] at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:337)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:] at org.eclipse.osgi.internal.loader.ModuleClassLoader.loadClass(ModuleClassLoader.java:160)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:] at java.lang.ClassLoader.loadClass(ClassLoader.java:357)[:1.8.0_101] at java.lang.ClassLoader.defineClass1(Native Method)[:1.8.0_101] at java.lang.ClassLoader.defineClass(ClassLoader.java:763)[:1.8.0_101] at org.eclipse.osgi.internal.loader.ModuleClassLoader.defineClass(ModuleClassLoader.java:272)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:] at org.eclipse.osgi.internal.loader.classpath.ClasspathManager.defineClass(ClasspathManager.java:632)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:] at org.eclipse.osgi.internal.loader.classpath.ClasspathManager.findClassImpl(ClasspathManager.java:588)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:] at org.eclipse.osgi.internal.loader.classpath.ClasspathManager.findLocalClassImpl(ClasspathManager.java:540)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:] at org.eclipse.osgi.internal.loader.classpath.ClasspathManager.findLocalClass(ClasspathManager.java:527)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:] at org.eclipse.osgi.internal.loader.ModuleClassLoader.findLocalClass(ModuleClassLoader.java:324)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:] at org.eclipse.osgi.internal.loader.BundleLoader.findLocalClass(BundleLoader.java:320)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:] at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:395)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:] at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:345)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:] at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:337)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:] at org.eclipse.osgi.internal.loader.ModuleClassLoader.loadClass(ModuleClassLoader.java:160)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:] at java.lang.ClassLoader.loadClass(ClassLoader.java:357)[:1.8.0_101] at java.lang.ClassLoader.defineClass1(Native Method)[:1.8.0_101] at java.lang.ClassLoader.defineClass(ClassLoader.java:763)[:1.8.0_101] at org.eclipse.osgi.internal.loader.ModuleClassLoader.defineClass(ModuleClassLoader.java:272)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:] at org.eclipse.osgi.internal.loader.classpath.ClasspathManager.defineClass(ClasspathManager.java:632)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:] at org.eclipse.osgi.internal.loader.classpath.ClasspathManager.findClassImpl(ClasspathManager.java:588)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:] at org.eclipse.osgi.internal.loader.classpath.ClasspathManager.findLocalClassImpl(ClasspathManager.java:540)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:] at org.eclipse.osgi.internal.loader.classpath.ClasspathManager.findLocalClass(ClasspathManager.java:527)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:] at org.eclipse.osgi.internal.loader.ModuleClassLoader.findLocalClass(ModuleClassLoader.java:324)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:] at org.eclipse.osgi.internal.loader.BundleLoader.findLocalClass(BundleLoader.java:320)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:] at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:395)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:] at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:345)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:] at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:337)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:] at org.eclipse.osgi.internal.loader.ModuleClassLoader.loadClass(ModuleClassLoader.java:160)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:] at java.lang.ClassLoader.loadClass(ClassLoader.java:357)[:1.8.0_101] at org.eclipse.osgi.internal.framework.EquinoxBundle.loadClass(EquinoxBundle.java:568)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:] at org.apache.felix.scr.impl.manager.AbstractComponentManager.initDependencyManagers(AbstractComponentManager.java:952)[32:org.apache.felix.scr:2.0.2] at org.apache.felix.scr.impl.manager.AbstractComponentManager.collectDependencies(AbstractComponentManager.java:980)[32:org.apache.felix.scr:2.0.2] at org.apache.felix.scr.impl.manager.SingleComponentManager.getServiceInternal(SingleComponentManager.java:812)[32:org.apache.felix.scr:2.0.2] at org.apache.felix.scr.impl.manager.SingleComponentManager.getService(SingleComponentManager.java:774)[32:org.apache.felix.scr:2.0.2] at org.eclipse.osgi.internal.serviceregistry.ServiceFactoryUse$1.run(ServiceFactoryUse.java:212)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:] at java.security.AccessController.doPrivileged(Native Method)[:1.8.0_101] at org.eclipse.osgi.internal.serviceregistry.ServiceFactoryUse.factoryGetService(ServiceFactoryUse.java:210)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:] at org.eclipse.osgi.internal.serviceregistry.ServiceFactoryUse.getService(ServiceFactoryUse.java:111)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:] at org.eclipse.osgi.internal.serviceregistry.ServiceConsumer$2.getService(ServiceConsumer.java:45)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:] at org.eclipse.osgi.internal.serviceregistry.ServiceRegistrationImpl.getService(ServiceRegistrationImpl.java:496)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:] at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.getService(ServiceRegistry.java:461)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:] at org.eclipse.osgi.internal.framework.BundleContextImpl.getService(BundleContextImpl.java:619)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:] at com.eclipsesource.jaxrs.publisher.internal.ResourceTracker.addingService(ResourceTracker.java:39)[11:com.eclipsesource.jaxrs.publisher:5.3.1.201602281253] at org.osgi.util.tracker.ServiceTracker$Tracked.customizerAdding(ServiceTracker.java:941)[org.osgi.core-6.0.0.jar:] at org.osgi.util.tracker.ServiceTracker$Tracked.customizerAdding(ServiceTracker.java:870)[org.osgi.core-6.0.0.jar:] at org.osgi.util.tracker.AbstractTracked.trackAdding(AbstractTracked.java:256)[org.osgi.core-6.0.0.jar:] at org.osgi.util.tracker.AbstractTracked.track(AbstractTracked.java:229)[org.osgi.core-6.0.0.jar:] at org.osgi.util.tracker.ServiceTracker$Tracked.serviceChanged(ServiceTracker.java:901)[org.osgi.core-6.0.0.jar:] at org.eclipse.osgi.internal.serviceregistry.FilteredServiceListener.serviceChanged(FilteredServiceListener.java:109)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:] at org.eclipse.osgi.internal.framework.BundleContextImpl.dispatchEvent(BundleContextImpl.java:914)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:] at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:] at org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEventSynchronous(ListenerQueue.java:148)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:] at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.publishServiceEventPrivileged(ServiceRegistry.java:862)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:] at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.publishServiceEvent(ServiceRegistry.java:801)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:] at org.eclipse.osgi.internal.serviceregistry.ServiceRegistrationImpl.register(ServiceRegistrationImpl.java:127)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:] at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.registerService(ServiceRegistry.java:225)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:] at org.eclipse.osgi.internal.framework.BundleContextImpl.registerService(BundleContextImpl.java:464)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:] at org.apache.felix.scr.impl.manager.AbstractComponentManager$3.register(AbstractComponentManager.java:869)[32:org.apache.felix.scr:2.0.2] at org.apache.felix.scr.impl.manager.AbstractComponentManager$3.register(AbstractComponentManager.java:857)[32:org.apache.felix.scr:2.0.2] at org.apache.felix.scr.impl.manager.RegistrationManager.changeRegistration(RegistrationManager.java:133)[32:org.apache.felix.scr:2.0.2] at org.apache.felix.scr.impl.manager.AbstractComponentManager.registerService(AbstractComponentManager.java:915)[32:org.apache.felix.scr:2.0.2] at org.apache.felix.scr.impl.manager.AbstractComponentManager.activateInternal(AbstractComponentManager.java:715)[32:org.apache.felix.scr:2.0.2] at org.apache.felix.scr.impl.manager.AbstractComponentManager.enable(AbstractComponentManager.java:399)[32:org.apache.felix.scr:2.0.2] at org.apache.felix.scr.impl.config.ConfigurableComponentHolder.enableComponents(ConfigurableComponentHolder.java:676)[32:org.apache.felix.scr:2.0.2] at org.apache.felix.scr.impl.BundleComponentActivator.initialEnable(BundleComponentActivator.java:339)[32:org.apache.felix.scr:2.0.2] at org.apache.felix.scr.impl.Activator.loadComponents(Activator.java:360)[32:org.apache.felix.scr:2.0.2] at org.apache.felix.scr.impl.Activator.access$000(Activator.java:53)[32:org.apache.felix.scr:2.0.2] at org.apache.felix.scr.impl.Activator$ScrExtension.start(Activator.java:260)[32:org.apache.felix.scr:2.0.2] at org.apache.felix.utils.extender.AbstractExtender.createExtension(AbstractExtender.java:259)[32:org.apache.felix.scr:2.0.2] at org.apache.felix.utils.extender.AbstractExtender.modifiedBundle(AbstractExtender.java:232)[32:org.apache.felix.scr:2.0.2] at org.osgi.util.tracker.BundleTracker$Tracked.customizerModified(BundleTracker.java:482)[org.osgi.core-6.0.0.jar:] at org.osgi.util.tracker.BundleTracker$Tracked.customizerModified(BundleTracker.java:415)[org.osgi.core-6.0.0.jar:] at org.osgi.util.tracker.AbstractTracked.track(AbstractTracked.java:232)[org.osgi.core-6.0.0.jar:] at org.osgi.util.tracker.BundleTracker$Tracked.bundleChanged(BundleTracker.java:444)[org.osgi.core-6.0.0.jar:] at org.eclipse.osgi.internal.framework.BundleContextImpl.dispatchEvent(BundleContextImpl.java:902)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:] at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:] at org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEventSynchronous(ListenerQueue.java:148)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:] at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEventPrivileged(EquinoxEventPublisher.java:165)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:] at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEvent(EquinoxEventPublisher.java:75)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:] at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEvent(EquinoxEventPublisher.java:67)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:] at org.eclipse.osgi.internal.framework.EquinoxContainerAdaptor.publishModuleEvent(EquinoxContainerAdaptor.java:102)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:] at org.eclipse.osgi.container.Module.publishEvent(Module.java:466)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:] at org.eclipse.osgi.container.Module.start(Module.java:457)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:] at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1582)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:] at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1562)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:] at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.doContainerStartLevel(ModuleContainer.java:1533)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:] at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1476)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:] at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:] at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:] at org.eclipse.osgi.framework.eventmgr.EventManager$EventThread.run(EventManager.java:340)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:]
As I said I installed the Snapshot-online-version on my RPi3 where Java 1.8…101 is installed.
Just tried the offline-version and that seems to run better!! I got some other errors (can’t open some files…) in the logs but the bindings were loaded and seem to work.
On my windows 10 with the Snapshot-version I don’t geht the error…
Don’t know if this info helps.
If I can provide anything else useful, let me know.
I’m about to give it up for RPi3, Windows with Build #463 still works like a charm (in terms of RWE SH Binding).
My fresh install on RPi3 of Build #463 says:
2016-08-31 19:48:03.305 [INFO ] [ommunicator.RWESmarthomeCommunicator] - Starting RWE Smarthome communicator
2016-08-31 19:48:03.942 [ERROR] [nal.communicator.RWESmarthomeSession] - SSLHandshakeException
javax.net.ssl.SSLHandshakeException: Remote host closed connection during handshake
at sun.security.ssl.SSLSocketImpl.readRecord(SSLSocketImpl.java:992)[:1.8.0_65]
at sun.security.ssl.SSLSocketImpl.performInitialHandshake(SSLSocketImpl.java:1375)[:1.8.0_65]
at sun.security.ssl.SSLSocketImpl.writeRecord(SSLSocketImpl.java:747)[:1.8.0_65]
at sun.security.ssl.AppOutputStream.write(AppOutputStream.java:123)[:1.8.0_65]
at org.apache.http.impl.io.AbstractSessionOutputBuffer.flushBuffer(AbstractSessionOutputBuffer.java:147)
at org.apache.http.impl.io.AbstractSessionOutputBuffer.flush(AbstractSessionOutputBuffer.java:154)
at org.apache.http.impl.io.ContentLengthOutputStream.flush(ContentLengthOutputStream.java:106)
at org.apache.http.entity.StringEntity.writeTo(StringEntity.java:177)
at org.apache.http.entity.HttpEntityWrapper.writeTo(HttpEntityWrapper.java:98)
at org.apache.http.impl.client.EntityEnclosingRequestWrapper$EntityWrapper.writeTo(EntityEnclosingRequestWrapper.java:108)
at org.apache.http.impl.entity.EntitySerializer.serialize(EntitySerializer.java:122)
at org.apache.http.impl.AbstractHttpClientConnection.sendRequestEntity(AbstractHttpClientConnection.java:271)
at org.apache.http.impl.conn.AbstractClientConnAdapter.sendRequestEntity(AbstractClientConnAdapter.java:227)
at org.apache.http.protocol.HttpRequestExecutor.doSendRequest(HttpRequestExecutor.java:257)
at org.apache.http.protocol.HttpRequestExecutor.execute(HttpRequestExecutor.java:125)
at org.apache.http.impl.client.DefaultRequestDirector.tryExecute(DefaultRequestDirector.java:717)
at org.apache.http.impl.client.DefaultRequestDirector.execute(DefaultRequestDirector.java:522)
at org.apache.http.impl.client.AbstractHttpClient.execute(AbstractHttpClient.java:906)
at org.apache.http.impl.client.AbstractHttpClient.execute(AbstractHttpClient.java:805)
at org.apache.http.impl.client.AbstractHttpClient.execute(AbstractHttpClient.java:784)
at org.openhab.binding.rwesmarthome.internal.communicator.client.RWEHTTPClient.execute(RWEHTTPClient.java:61)
at org.openhab.binding.rwesmarthome.internal.communicator.RWESmarthomeSession.executeRequest(RWESmarthomeSession.java:226)
at org.openhab.binding.rwesmarthome.internal.communicator.RWESmarthomeSession.logon(RWESmarthomeSession.java:273)
at org.openhab.binding.rwesmarthome.internal.communicator.RWESmarthomeCommunicator.start(RWESmarthomeCommunicator.java:88)
at org.openhab.binding.rwesmarthome.internal.RWESmarthomeBinding.activate(RWESmarthomeBinding.java:65)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)[:1.8.0_65]
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)[:1.8.0_65]
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)[:1.8.0_65]
at java.lang.reflect.Method.invoke(Method.java:497)[:1.8.0_65]
at org.apache.felix.scr.impl.helper.BaseMethod.invokeMethod(BaseMethod.java:222)
at org.apache.felix.scr.impl.helper.BaseMethod.access$500(BaseMethod.java:37)
at org.apache.felix.scr.impl.helper.BaseMethod$Resolved.invoke(BaseMethod.java:615)
at org.apache.felix.scr.impl.helper.BaseMethod.invoke(BaseMethod.java:499)
at org.apache.felix.scr.impl.helper.ActivateMethod.invoke(ActivateMethod.java:295)
at org.apache.felix.scr.impl.manager.SingleComponentManager.createImplementationObject(SingleComponentManager.java:302)[32:org.apache.felix.scr:2.0.2]
at org.apache.felix.scr.impl.manager.SingleComponentManager.createComponent(SingleComponentManager.java:113)[32:org.apache.felix.scr:2.0.2]
at org.apache.felix.scr.impl.manager.SingleComponentManager.getService(SingleComponentManager.java:866)[32:org.apache.felix.scr:2.0.2]
at org.apache.felix.scr.impl.manager.SingleComponentManager.getServiceInternal(SingleComponentManager.java:833)[32:org.apache.felix.scr:2.0.2]
at java.security.AccessController.doPrivileged(Native Method)[:1.8.0_65]
at org.apache.felix.scr.impl.manager.DependencyManager$SingleDynamicCustomizer.addedService(DependencyManager.java:753)[32:org.apache.felix.scr:2.0.2]
at org.apache.felix.scr.impl.manager.DependencyManager$SingleDynamicCustomizer.addedService(DependencyManager.java:700)[32:org.apache.felix.scr:2.0.2]
at org.apache.felix.scr.impl.manager.ServiceTracker$Tracked.customizerAdded(ServiceTracker.java:1215)[32:org.apache.felix.scr:2.0.2]
at org.apache.felix.scr.impl.manager.ServiceTracker$Tracked.customizerAdded(ServiceTracker.java:1136)[32:org.apache.felix.scr:2.0.2]
at org.apache.felix.scr.impl.manager.ServiceTracker$AbstractTracked.trackAdding(ServiceTracker.java:945)[32:org.apache.felix.scr:2.0.2]
at org.apache.felix.scr.impl.manager.ServiceTracker$AbstractTracked.track(ServiceTracker.java:881)[32:org.apache.felix.scr:2.0.2]
at org.apache.felix.scr.impl.manager.ServiceTracker$Tracked.serviceChanged(ServiceTracker.java:1167)[32:org.apache.felix.scr:2.0.2]
at org.apache.felix.scr.impl.BundleComponentActivator$ListenerInfo.serviceChanged(BundleComponentActivator.java:120)[32:org.apache.felix.scr:2.0.2]
Caused by: java.io.EOFException: SSL peer shut down incorrectly
at sun.security.ssl.InputRecord.read(InputRecord.java:505)[:1.8.0_65]
at sun.security.ssl.SSLSocketImpl.readRecord(SSLSocketImpl.java:973)[:1.8.0_65]
... 116 more
2016-08-31 19:48:04.103 [ERROR] [ommunicator.RWESmarthomeCommunicator] - Could not start RWE Smarthome communicator: SAXException:Premature end of file.
org.openhab.binding.rwesmarthome.internal.communicator.exceptions.SHTechnicalException: SAXException:Premature end of file.
at org.openhab.binding.rwesmarthome.internal.communicator.RWESmarthomeSession.logon(RWESmarthomeSession.java:284)
Caused by: org.xml.sax.SAXParseException; lineNumber: 1; columnNumber: 1; Premature end of file.
at com.sun.org.apache.xerces.internal.parsers.DOMParser.parse(DOMParser.java:257)[:1.8.0_65]
at com.sun.org.apache.xerces.internal.jaxp.DocumentBuilderImpl.parse(DocumentBuilderImpl.java:339)[:1.8.0_65]
at org.openhab.binding.rwesmarthome.internal.communicator.util.XMLUtil.loadXMLFromString(XMLUtil.java:78)
at org.openhab.binding.rwesmarthome.internal.communicator.util.XMLUtil.XPathValueFromString(XMLUtil.java:50)
at org.openhab.binding.rwesmarthome.internal.communicator.RWESmarthomeSession.logon(RWESmarthomeSession.java:274)
... 94 more
2016-08-31 19:48:04.152 [INFO ] [ommunicator.RWESmarthomeCommunicator] - Shutting down RWE Smarthome communicator
2016-08-31 19:48:04.159 [INFO ] [ommunicator.RWESmarthomeCommunicator] - RWE Smarthome communicator shut down.
2016-08-31 19:48:04.162 [INFO ] [b.core.service.AbstractActiveService] - RWESmarthome Refresh Service has been started
2016-08-31 19:48:34.564 [INFO ] [ommunicator.RWESmarthomeCommunicator] - Shutting down RWE Smarthome communicator
2016-08-31 19:48:34.628 [INFO ] [.dashboard.internal.DashboardService] - Stopped dashboard
2016-08-31 19:48:34.660 [INFO ] [arthome.ui.paper.internal.PaperUIApp] - Stopped Paper UI
2016-08-31 19:48:34.706 [INFO ] [assic.internal.servlet.WebAppServlet] - Stopped Classic UI
2016-08-31 19:48:34.769 [INFO ] [basic.internal.servlet.WebAppServlet] - Stopped Basic UI
2016-08-31 19:48:36.173 [INFO ] [b.core.service.AbstractActiveService] - RWESmarthome Refresh Service has been shut down
Victor, I decided to wait for Ollies new Binding which connects to the all new innogy Smarthome API. Already switched my SHC over to the new version today (which was expectedly disappointing btw).
I will soon start to replace switches & dimmers to Homematic and might keep rollershutters and thermostates…
