Hi Martin here is the snippet of my related thing file:
// Homematic Things
Bridge homematic:bridge:ccu2 [ gatewayType="ccu", gatewayAddress="192.xxx.xxx.xxx", callbackHost="192.168.8.135" ]{
Thing GATEWAY-EXTRAS-724E7770 GWE00000000 "CCU2 - Gateway-Extras"
// Beleuchtungen
// Flur
Thing HM-LC-Sw1-DR OEQ0330832 "Schalter" @ "Flur" {
Channels:
Type M-LC-Sw1-DR_STAE : 1#STATE [
delay = 0,
receiveDelay = 0
// Esszimmer
Thing HM-LC-Dim1TPBU-FM NEQ1802517 "Dimmerschalter" @ "Esszimmer" {
Channels:
Type HM-LC-Dim1TPBU-FM_1_LEVEL : 1#LEVEL [
delay = 0,
receiveDelay = 0
Thing HM-LC-Sw1-FM OEQ1868041 "Steckdose-Wheinachtsstern" @ "Esszimmer" {
Channels:
Type HM-LC-Sw1-FM_1_STATE : 1#STATE [
delay = 0,
receiveDelay = 0
Thing HM-CC-RT-DN OEQ0857126 "Thermostat links" @ "Esszimmer" {
Channels:
Type HM-CC-RT-DN_4_SET_TEMPERATURE : 4#SET_TEMPERATURE [
delay = 0,
receiveDelay = 0
Thing HM-CC-RT-DN OEQ0667382 "Thermostat rechts" @ "Esszimmer" {
Channels:
delay = 0,
receiveDelay = 0
// Küche
Thing HM-LC-Dim1TPBU-FM NEQ1802520 "Dimmerschalter" @ "Küche" {
Channels:
delay = 0,
receiveDelay = 0
Thing HM-CC-RT-DN OEQ0858472 "Thermostat links" @ "Küche" {
Channels:
delay = 0,
receiveDelay = 0
Thing HM-CC-RT-DN OEQ0666462 "Thermostat rechts" @ "Küche" {
Channels:
delay = 0,
receiveDelay = 0
// Wetterstation
Thing HmIP-SWO-PL 00181BE98B3E30 "Wetterstation" @ "Hof" {
Channels:
Type HmIP-SWO-PL_1_ACTUAL_TEMPERATURE : 1#ACTUAL_TEMPERATURE [
delay = 0,
receiveDelay = 0
Type HmIP-SWO-PL_1_HUMIDITY : 1#HUMIDITY [
delay = 0,
receiveDelay = 0
Type HmIP-SWO-PL_1_WIND_SPEED : 1#WIND_SPEED [
delay = 0,
receiveDelay = 0
Type HmIP-SWO-PL_1_RAIN_COUNTER : 1#RAIN_COUNTER [
delay = 0,
receiveDelay = 0
Type HmIP-SWO-PL_1_RAINING : 1#RAINING [
delay = 0,
receiveDelay = 0
//Thing GATEWAY-EXTRAS-CCU2 GWE00000000 "CCU2 - Gatway-Extras"
And this is the item:
// Wetterstation //
Number Wetterstation_Temperatur "Außentemperatur [%.1f °C]" <temperature> {channel="homematic:HmIP-SWO-PL:ccu2:00181BE98B3E30:1#ACTUAL_TEMPERATURE"}
Number Wetterstation_Luftfeuchtigkeit "Luftfeuchtigkeit [%d %%]" <humidity> {channel="homematic:HmIP-SWO-PL:ccu2:00181BE98B3E30:1#HUMIDITY"}
Number Wetterstation_Windgeschwindigkeit "Windgeschwindigkeit [%.1f km/h]" <wind> {channel="homematic:HmIP-SWO-PL:ccu2:00181BE98B3E30:1#WIND_SPEED"}
Number Wetterstation_Regenmenge "Regenmenge [%.1f mm]" <rain> {channel="homematic:HmIP-SWO-PL:ccu2:00181BE98B3E30:1#RAIN_COUNTER"}
Switch Wetterstation_Regen "Regen" <rain> {channel="homematic:HmIP-SWO-PL:ccu2:00181BE98B3E30:1#RAINING"}
this could be a interssting log:
08:08:12.557 [ERROR] [.ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item ‘Zeitraum_Temperatur’ for widget org.openhab.core.model.sitemap.sitemap.Switch
08:08:12.562 [ERROR] [.ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item ‘Zeitraum_Temperatur’ for widget org.openhab.core.model.sitemap.sitemap.Switch
08:08:12.567 [ERROR] [.ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item ‘Zeitraum_Temperatur’ for widget org.openhab.core.model.sitemap.sitemap.Switch
and this:
08:09:00.090 [ERROR] [rd4j.internal.RRD4jPersistenceService] - Could not create rrd4j database file ‘/var/lib/openhab/persistence/rrd4j/Wetterstation_Temperatur.rrd’: Invalid file header. File [/var/lib/openhab/persistence/rrd4j/Wetterstation_Temperatur.rrd] is not a RRD4J RRD file
08:09:00.096 [ERROR] [rd4j.internal.RRD4jPersistenceService] - Could not create rrd4j database file ‘/var/lib/openhab/persistence/rrd4j/Wetterstation_Regenmenge.rrd’: Invalid file header. File [/var/lib/openhab/persistence/rrd4j/Wetterstation_Regenmenge.rrd] is not a RRD4J RRD file
This is the related sitemap snippet:
Frame label="Wetter"
Text item=Wetterstation_Temperatur
//Text label="Wetter" icon="sun_clouds"
Text item=Wetterstation_Luftfeuchtigkeit
Text item=Wetterstation_Windgeschwindigkeit
Text item=Wetterstation_Regenmenge
Switch item=Wetterstation_Regen icon="rain" label="Regen"
Switch item=Zeitraum_Temperatur label="Interval" icon="time" mappings=[0="Stunde", 1="Tag", 2="Woche", 3="Jahr"]
//Chart item=Wetterstation_Temperatur period=h refresh=7200 visibility=[Zeitraum_Temperatur==0, Zeitraum_Temperatur=="Uninitialized"] legend=true
//Chart item=Wetterstation_Temperatur period=D refresh=14400 visibility=[Zeitraum_Temperatur==1] legend=true
//Chart item=Wetterstation_Temperatur period=W refresh=14400 visibility=[Zeitraum_Temperatur==2] legend=true
//Chart item=Wetterstation_Temperatur period=Y refresh=14400 visibility=[Zeitraum_Temperatur==3] legend=true
and this the persist file:
Strategies {
everyMinute : "0 * * * * ?"
default = everyChange
Items {
Wetterstation_Temperatur : strategy = everyUpdate, everyMinute, restoreOnStartup
Wetterstation_Regenmenge : strategy = everyUpdate, everyMinute, restoreOnStartup
Solar_Inverter_1 : strategy = everyUpdate, everyMinute, restoreOnStartup
Hopefully this can help finding the error
