This is really a Newbie question but I am just starting out.
I’m trying to install Mosquitto using the console based on a step-by-step guide (for adding Tuya devices)
The guides indicates to use the console with the folowing command: sudo openhabian-config
this requests a password on the console, I have did quite a few google searches and although most indicate the password is “openhabian” but that does not work…what am I doing wrong ?
You have a total misunderstanding of what you are trying to do. If you run OH on Windoze you cannot install mosquitto. The console command if for openHABian which is Linux.
