Hi, I’m using a VM for test installation. That is, installing the current debian 64bit, apt update/full-upgrade, install git, get openhabian, start openhabian-config, 60 Manual/fresh setup -> Choose all needed packages, especially Java 64bit but not Java 32bit.
After installation is finished, I end up with a 32bit Java installed in /opt/jdk/zulu8.42.0.21-ca-jdk8.0.232-linux_i686/bin/java, which is obviously the right path, but the wrong version. Instead I have to install zulu the manual way through azul repository.
