i want to move my Openhabian installation to a new SD-Card. That means, I want to have a new installation on a another SD-Card, but keep all bindings and so on. What do I have to backup then?
JSONDB
Configuration folder with item,- rules-…-files
Anything else?
Is it after a new installation possible to just paste the old files on the new folders?
Today I tried the SD Image& resore with the Win32DiskImager (on a WIN10 machine). I thought it would be a good idea before mirgate from OH2.4 to 2.5
I did that before with 2 identical Toshiba 32GB SD cards. Now one of them is used for something else so I bought a new one 32GB from Verbatim.
But writing the image to the Verbatim now fails!
During the writing process the imager claims that there is less space then the image size. The Verbatim has only 29.8GB free space! The OH installation is far less, and it comments also “additional space seems to contain no data”. The restore process works without failiure, but OH will not start from this card. No blinking on the raspi, nothing.
What ca I do, to get my image to the new card?
You may need to use a partition editor to shrink the size of the SD card with the image. Do a google search for how to do this without erasing whats on the card. I use linux PC and Gparted for such but not sure what works best for Windows but sure you will find it with a search.
You can always use sudo openhab-cli backup --full then move the zipped file to another location (USB or PC I use FileZilla for this) then install a fresh image on the new card then restore your backup.
Doing it this way you can keep your production SD until you verify the new SD is working. To restore the backup stop OH first sudo systemctl stop openhab2, place the zip file in the backup location then sudo openhab-cli restore /var/lib/openhab2/backups and sudo systemctl start openhab2
You run openHABian on a Pi but shut it down to backup on Windoze ?
There’s Amanda to be part of the system, and you can also use low level tools such as dd for one-time copies.
But yes, if you copy raw partitions, the destination has to be at least as large as the source.
So better reinstall (take the opportunity to go down to 8 GB) and use openhab-cli backup/restore to copy your config.
Ok, today I setup a new openhabian installation on the new card. The install worked, also access to the UI.
then I restored the backup as H102 described. But it seemms, that this is not compatible to OH2.5
I get many errors, this one is coming repeatedly:
I think the new install OH2.5 and copying the configuraton from the 2.4 installation back was not the best idea!
Clearing cache and restarting OH gets the system running incl the UI’s, BUT:
RestDocs not working (ok, I knew that)
GPIO Binding not loading/working
Broadlink no longer working
Samba shares are gone
MQTT broker not copied. I tried to install the new MQTT binding, but it does not connect
2019-12-22 11:27:24.114 [INFO ] [.transport.mqtt.MqttBrokerConnection] - Starting MQTT broker connection to '192.168.178.55' with clientid 247a67ee-9d7e-4a5e-b829-34aa5d5b9fb9
2019-12-22 11:27:24.187 [hingStatusInfoChangedEvent] - 'mqtt:systemBroker:mqttson' changed from OFFLINE to OFFLINE (COMMUNICATION_ERROR): io.netty.channel.AbstractChannel$AnnotatedConnectException: Connection refused: /192.168.178.55:1883
Thats really frustrating, 8h of hacking, and nearly nothing useful is working
Maybe its better to get another fitting SD card and do only the upgrade to 2.5 without touching anything else.
This is a good sign. Now Stop try restarting OH a few times, waiting each time for OH to fully load each time and see if that helps. There have been several reports that this has been need to get everything working.
Also post the logs about the other binding that are not loading as well as mqtt if the problem persist.
Hi, I am back again.
I received my 2. identical SD card and made a image copy.
Unistalled REST docs and made the upgrade to OH2.5 and reinstalled REST.
I also cleared the cache and restarted several times.
2019-12-28 16:30:57.568 [me.event.ThingUpdatedEvent] - Thing 'zwave:serial_zstick:15f71b6bf6d' has been updated.
2019-12-28 16:31:15.224 [vent.ItemStateChangedEvent] - zwave_serial_zstick_15f673bb2bc_serial_can changed from 0 to 1
2019-12-28 16:31:33.286 [hingStatusInfoChangedEvent] - 'zwave:serial_zstick:15f71b6bf6d' changed from ONLINE to UNINITIALIZED
2019-12-28 16:31:36.447 [hingStatusInfoChangedEvent] - 'zwave:serial_zstick:15f71b6bf6d' changed from UNINITIALIZED to UNINITIALIZED (HANDLER_MISSING_ERROR)
2019-12-28 16:31:47.071 [hingStatusInfoChangedEvent] - 'zwave:serial_zstick:15f71b6bf6d' changed from UNINITIALIZED (HANDLER_MISSING_ERROR) to INITIALIZING
2019-12-28 16:31:47.099 [hingStatusInfoChangedEvent] - 'zwave:serial_zstick:15f71b6bf6d' changed from INITIALIZING to OFFLINE (BRIDGE_OFFLINE): Controller is offline
2019-12-28 16:31:47.299 [vent.ItemStateChangedEvent] - zwave_serial_zstick_15f673bb2bc_serial_can changed from 1 to 0
2019-12-28 16:31:57.912 [hingStatusInfoChangedEvent] - 'zwave:serial_zstick:15f71b6bf6d' changed from OFFLINE (BRIDGE_OFFLINE): Controller is offline to ONLINE
Rest is also not working, don’t know where to look here.
