I’m running the latest openhabian installation and for a while now I get crashes without knowing where they come from. They end up in a “java.lang.OutOfMemoryError: Java heap space” error.
openhabian seems to use the openJDK - could it be a solution to switch over to Oracle Java - and if yes, how would I achieve this?
openHABian uses Zulu. Its basically an optimized openJDK.
For ARM (rPis), Zulu embedded is used.
You can try to switch to Oracle but I am afraid that your problems will not go away (I don’t know what is the root cause of your problems)
There are many guides online on how to deploy Oracle JVM on Raspberry Pi. Remember to use update-alternatives --config java after you install another JVM to select it as default.
