I have brand new Raspberry Pi which I used for two weeks testing openhab. However I had some issues during two weeks, openhab was running slow so been advised to reinstall openhabian and start again.
Last night I have had removed micro SD card (32GB Sandisk Ultra), formatted as per tutorials and reload openhabian image. After approximately an hour I tried to access RPI via dashboard (http://openhabianpi:8080) in order to complete the installation. But something is stopping access , cant access dashboard.
As I know the IP address of RPI , I was able to SSH to it. Upon typing default username and password was able to access it and found this status:
Blockquote
2017-11-29_02:37:20_UTC [openHABian] Starting the openHABian initial setup.
2017-11-29_02:37:20_UTC [openHABian] Storing configuration… OK
2017-11-29_02:37:20_UTC [openHABian] Changing default username and password… O
K
2017-11-29_02:37:20_UTC [openHABian] Setting up Ethernet connection… OK
2017-11-29_02:37:20_UTC [openHABian] Ensuring network connectivity… OK
2018-03-31_10:33:54_UTC [openHABian] Waiting for dpkg/apt to get ready… OK
2018-03-31_10:34:13_UTC [openHABian] Updating repositories and upgrading install
ed packages… OK
2018-03-31_10:38:56_UTC [openHABian] Installing git package… FAILED
2018-03-31_10:38:56_UTC [openHABian] Initial setup exiting with an error!
So I tried , again by formatting SD card and writing openhabian (the latest realese v1.4) to SD card. Every time it ended at the same place, showing that git package installation has FAILED.
I tried this process 4 times yesterday , every time with the same result.
This morning I decided to try brand new 32GB SD card (Sandisk Ultra) , wrote the image and was hoping that this would work but the result were exactly the same as when I was using first card.
Just to add , both my cards are genuine, tested them with FAKEFLASHTEST software and it has passed test.
First card was used without problems for about two weeks.
My PSU is genuine Raspberry unit with the rating of 2.5A.
The same error happened during my installation. By logging on to the Raspberry and re-executing the sudo apt-get install git command, I received an error message telling me to run another command first (I forgot which one). Then after running this command the apt database was fixed and then rebooting the device did restart the installation that then continued fine.
I had the same issue. As far as I can remember the install scripted failed at one stage because a git clone had not completed successfully. I either commented out the line in install script or deleted the git workspace and rebooted. It then worked.
BTW currently installing Openhabian 1.5 on Rpi 3 - same problem.
root@openhab:/home/openhabian# cat /boot/first-boot.log
2019-07-10_01:21:39_BST [openHABian] Starting the openHABian initial setup.
2019-07-10_01:21:39_BST [openHABian] Storing configuration… OK
2019-07-10_01:21:39_BST [openHABian] Starting webserver with installation log… OK
2019-07-10_01:21:45_BST [openHABian] Changing default username and password… O K
2019-07-10_01:21:51_BST [openHABian] Setting up Ethernet connection… OK
2019-07-10_01:21:51_BST [openHABian] Ensuring network connectivity… OK
2019-07-10_01:21:51_BST [openHABian] Waiting for dpkg/apt to get ready… OK
2019-08-07_19:04:54_BST [openHABian] Updating repositories and upgrading install ed packages… OK
2019-08-07_19:07:12_BST [openHABian] Installing git package… FAILED
2019-08-07_19:07:52_BST [openHABian] Initial setup exiting with an error!
Offcourse
reboot
Fixes the issue, but is there is something to fix in release?
I was trying to install openhabian on my raspberry. I got the same message
This posting helped a lot
I performed this commands:
sudo dpkg --configure -a
sudo reboot
After that the first boot runs without errors.
I think, someone should fix this in the install image.
Now I’m ready for the first experience of openHAB
Maybe you are right
BUT the initial boot did not work. So I looked with my browser at :80 (yes I did not read that) and after that I used SSH und used google with the error [openHABian] Installing git package… FAILED
I found this thread. After I used the three commands on the console sudo dpkg --configure -a sudo apt-get install gi sudo reboot
everything runs fine.
Now I’m trying to get my SmartMeter running
