i have modified the command. i executed but its seems nothing change
mosquitto_pub -h 192.168.178.36 -p 1884 -u myusername -P mypass -t “home/OpenMQTTGateway/commands/MQTTtoSYS/config” -m ‘{“ohdiscovery”:true}’
You need to replace OpenMQTTGateway by the name of your gateway, here OMG_ESP32_BLE
mosquitto_pub -h 192.168.178.36 -p 1884 -u myusername -P mypass -t “home/OMG_ESP32_BLE/commands/MQTTtoSYS/config” -m ‘{“ohdiscovery”:true}’
wrong copy paste
i change the command but still the same. even after reboot the gateway its still false
Did you try with MQTT explorer ? Also note the quote that should be used below
{"ohdiscovery":true}
Thank you
That was the missing part.
Hi again.
Even if i have set up the ohdiscovery to true , openhab give me errors
Executing the JINJA-transformation failed: An error occurred while transformation. UnknownTokenException: Unknown token found: value_json.batt | is_defined
Any idea??
Thanks Nikos
This may be previous messages that have not been overwritten.
You may delete those messages or wait for them to be overwritten m.
Hi
i have try everything but still no go. the thing it have the wrong flag all the time | is_defined.
i did also new setup on my mosquitto broker but still the same.
Try maybe to publish the command with a retain flag so that it is taken at start
I fix it, but just compiled and flash it again with the openhab option true in the environment file.
It discovered the new things and become green in seconds.
Thanks for your support
Nikos
Do you mean that using the build flag worked right away?
Yes exactly.
With the ready firmware even if the flag was changed with the command, i could not make them work because the “| is_defined” was always there.
Nikos
I have added a save
option to the command in this Pull Request:
Could you try it and let me know if it works ?
mosquitto_pub -t "home/OpenMQTTGateway/commands/MQTTtoSYS/config" -m '{"ohdiscovery":true, "save":true}'
Sorry for the late reply.
where exactly to find the bin for downloading.
Nikos
No problem, build in progress:
Should be available here in a couple of hours
