Thanks for your excellent work!
I think, I have followed all your instructions but I have some issues with time settings.
As you can see in the next graph of the widget, i have add time after weekday.
Weather data is given at Sun 20H, Mon 2H, Mon 8H, Wen 17H and Wen 17H again.
What am I doning wrong? I expected weather data at Sun 20H, Sun 23H (3 hours later), Mon 12H, Tue, 12H and Wen 12H.
Maybe you can help me in pointing me in the right direction.
Did you figure out the permission problem? I have finally installed the widget and I have it working for the most part, but canāt get the icons from the images directory to show up. Any hints would be appreciated.
I am still quite new to openhab and quite amazed about the possibilities. Obviously the drawback is that it is also quite complicated Anyway, thanks a lot for this widget, itās awesome! I got it implemented without problems except for the two little images for wind speed and humidity.
Openhabianpi is running on a PI 3 B+ and I am using another PI 3 B+ with a 7" screen for showing the HABPanel (Raspbian with Chromium Browser). The thing is that I can see the widget with ANY other device properly, including the two images (Laptop, Smartphone, Tablet). Just the other Pi will not show the images. It also does not work if I type the path manually. The permissions on the images are changed so that everyone has read and execute rights.
Does anybody have any idea where to look further to solve this?
Awesome app. Although I am experiencing the same problem as @Kai_Mahnke but only with my (old) iPad 3.
On pc, phone, new iPad etc everything works flawless. @bastiaan_van_h can you look into this?
Thanks a lot for the work youāre putting into this
I have a question which bugs me now for a couple of days and Iām not moving forward:
How can I change the time of day that is shown?
At the Moment, the widget shows the forecast for 11:00am daily (using openweathermap.org).
Iād love to change this to 1pm or 2pm - I already tried checking all timezones, having a look in the documentation, etc etc.
(the 3-hour forecast time 8am, 6-hour 11am, and so forth - not sure if thatās correct either.)
Hello Bastiaan,
any news on Beta? Having forecast to noon next day makes sense. If we are lucky we see double weekdays what is confusingā¦
Thanks for great widget!
I have already searched this page for hours and done changing and testingā¦ Canāt get it ok. I have the weather-icons-master folder in the correct place, checked the names in the widget code they are the same as in the .items file, but they just donāt seem to get loaded.
Would also like to change the time to one later in the afternoon, around 1pm or 2pm. Is it possible already?
I suppose the reason why the widget displays 11am instead of 12am is because IĀ“m at GMT +1?
@bastiaan_van_h - I downloaded the widget and the new version of the own.controller.js but I still see the double day issue. Can you confirm that the new version was uploaded?
I too have this issue ā no āIdā channels showing up in the Openweathermap local weather and forecast thing. All the other channels show up and work fine. Does anyone else see this behavior?
Ahem. For anyone else in the same position, donāt forget to click the āSHOW MOREā in the Thing configuration for the Local weather and forecast. Itās at the top right of the channel list, and clicking it made revealed the channel I was looking for. No idea why only that one channel was hidden in the interface.
