I have installed OpenHab2 and connected a mcp23017 IC to the i2c. I followed the instructions at the MCP23017 binding documentation but i was not able to get it working.
When I used the wiringpi2 library with python I was able to get it working. What am I doing wrong in openhab ? Do I need to download addons for the mcp23017 IC?
OH1 bindings generally work in OH2 with a small number of specific exceptions. Pi4J is a mature and stable Java library for WiringPi that is well suited for a base from which to build an OH2 binding.
Often there are OS-level user privileges that can complicate access to hardware like GPIO and i2c.
I am a little lost now⦠The binding of mcp23017 which is in the documentation tells me to use switch or contact but it seems that there is no underlying code which handles this. On the other hand; Alexander shows in his comment that the 23017 is working in OH1.8.3ā¦
So my question is why is Pi4J and WiringPi needed to get it working? How is it implemented in OH1?
For OH2 there are addons but this is a .kar file�
OH1 has a zip-file holding a number of .jar files.
OH1 bindings that arenāt yet installable in OH2 through Paper UI can be tested by dropping their JAR file in your OH2 addons directory. Sometimes special setup is needed for accessing local hardware. Please contact the binding developer for instructions and suggest any changes for the wiki page for that binding. New OH1 bindings should not be merged unless seen to work on OH2, so Iām assuming (hoping) that was done.
That is where I get lost because the mcp23017 binding is not in the list of jar files if I download the addons for the 1.8 version from the openhab runtime section. I do not see an org.openhab.binding.mcp23017 binding. How did alexander it working in the 1.8.3 version. And how do I read the binding documentation because in the documentation it states only to create an switc or contact item. The mcp23017 binding and the code which handles all communication with the mcp23017 hardware over i2c should then be part of the installation?
Do I need to add the i2c binding first?
If I download the OH2 addons I have only 1 .kar file and I do not know where to copy it or how to use it
@johandekroon Hi. Sorry about late reply: I had not realized discussion here:-(
Installaion of binding is made really simple: Copy org.openhab.binding.mcp23017-1.9.0-SNAPSHOT.jar
into addons folder of openhab 1.8.3 installation. There is no furher install required.
Iāve not tested this binding under Openhab2. I plan to migrate to Openhab2 as release is avaliable.
If there are troubles with the implementation, iāll fix them and create new PR.
Small question: Is openhab user in gpio group? I assume, that you use Raspberry.
About your question: How it worksā¦
Class MCP23017Binding implements GpioPinListenerDigital interface provided by Pi4J library.
There is a handleGpioPinDigitalStateChangeEvent, that will be called by Pi4j, if pin state was changed.
So input pins, that must be mapped to Contact items, can post their changes to OpenHab bus here.
Output pins, that must be mapped to Switch items, will be handeld normally in internalReceiveCommand function.
Very important thing is āaddressā attribute within the item definition. Here is defined the address of chip returned by
"i2cdetect -y 1" call.
Feel free to contact me on further questions or send bug reports. I would try to answer ASAP.
I have successfully installed the openhab 1.8.3 version and got the 23017 IC working. I have copied the files into the openhab2 structure but this does not work out of the box yet. My plan is to setup the eclipse development environment and play with it to get it working in OH2ā¦So Whatou ⦠maybe I will get back with more questions on how to implement the binding for OH2
For me the openhab was quite new. The problem for me was I could not find a 23017 addon. I have downloaded the openhab core and addons from the OH download page⦠I also checked the 23017 binding page.
The addons are all for the OH1 and not the OH2.
Could not find a 23017 addon in the downloaded zip-file.
In the 23017 binding page the following line: This binding will be available from 1.9.0 onwards or is available from corresponding snapshot
put me in the wrong direction. I expected that there must be a org.openhab.binding.mcp23017ā¦jar file somewhere in the addons I had downloaded but could not find it in the zip. On the other hand I had this idea that I did something wrong because āhow hard could it beā. (but I downloaded the 1.8.3 version and not the 1.9 version)
Finally watou gave me the answer I needed. I have placed the jar file in the OH1 addon directory and it worked.
I also copied the files in the addon to the OH2 addon directory but this did not work. Donāt know why⦠I still need to figure out why OH1 is working and OH2 not.
I hope this is enough info for you? if not⦠keep on asking
Thx Alexander for this binding, I would like to use it also in OPENHAB 2
First yes it does not work in PAPERUI but putting the JAR in the addons map will install the addon.
But First ERROR
017-04-15 17:15:15.250 [DEBUG] [org.openhab.binding.mcp23017 ] - BundleEvent INSTALLED - org.openhab.binding.mcp23017
2017-04-15 17:15:18.555 [DEBUG] [org.openhab.binding.mcp23017 ] - BundleEvent RESOLVED - org.openhab.binding.mcp23017
2017-04-15 17:15:18.648 [DEBUG] [org.openhab.binding.mcp23017 ] - ServiceEvent REGISTERED - {org.openhab.model.item.binding.BindingConfigReader, org.openhab.binding.mcp23017.MCP23017BindingProvider}={component.name=org.openhab.binding.mcp23017.genericbindingprovider, component.id=344, service.id=496, service.bundleid=204, service.scope=bundle} - org.openhab.binding.mcp23017
2017-04-15 17:15:18.666 [DEBUG] [org.openhab.binding.mcp23017 ] - ServiceEvent REGISTERED - {org.osgi.service.event.EventHandler}={event.topics=openhab/*, component.name=org.openhab.binding.mcp23017.binding, component.id=343, service.id=497, service.bundleid=204, service.scope=bundle} - org.openhab.binding.mcp23017
2017-04-15 17:15:18.775 [DEBUG] [org.openhab.binding.mcp23017 ] - BundleEvent STARTING - org.openhab.binding.mcp23017
2017-04-15 17:15:18.786 [DEBUG] [org.openhab.binding.mcp23017 ] - BundleEvent STARTED - org.openhab.binding.mcp23017
2017-04-15 17:15:19.105 [ERROR] [org.openhab.binding.mcp23017 ] - [org.openhab.binding.mcp23017.binding(343)] Error during instantiation of the implementation object
java.lang.RuntimeException: ERROR; Access to GPIO pins on this system requires priviliged access.
at com.pi4j.wiringpi.GpioUtil.enableNonPrivilegedAccess(Native Method)
at org.openhab.binding.mcp23017.internal.MCP23017Binding.<init>(MCP23017Binding.java:83)
at sun.reflect.NativeConstructorAccessorImpl.newInstance0(Native Method)[:1.8.0_121]
at sun.reflect.NativeConstructorAccessorImpl.newInstance(NativeConstructorAccessorImpl.java:62)[:1.8.0_121]
at sun.reflect.DelegatingConstructorAccessorImpl.newInstance(DelegatingConstructorAccessorImpl.java:45)[:1.8.0_121]
at java.lang.reflect.Constructor.newInstance(Constructor.java:423)[:1.8.0_121]
at java.lang.Class.newInstance(Class.java:442)[:1.8.0_121]
at org.apache.felix.scr.impl.manager.SingleComponentManager.createImplementationObject(SingleComponentManager.java:236)[32:org.apache.felix.scr:2.0.6]
at org.apache.felix.scr.impl.manager.SingleComponentManager.createComponent(SingleComponentManager.java:108)[32:org.apache.felix.scr:2.0.6]
at org.apache.felix.scr.impl.manager.SingleComponentManager.getService(SingleComponentManager.java:906)[32:org.apache.felix.scr:2.0.6]
at org.apache.felix.scr.impl.manager.SingleComponentManager.getServiceInternal(SingleComponentManager.java:879)[32:org.apache.felix.scr:2.0.6]
at org.apache.felix.scr.impl.manager.SingleComponentManager.getService(SingleComponentManager.java:823)[32:org.apache.felix.scr:2.0.6]
at org.eclipse.osgi.internal.serviceregistry.ServiceFactoryUse$1.run(ServiceFactoryUse.java:212)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
at java.security.AccessController.doPrivileged(Native Method)[:1.8.0_121]
at org.eclipse.osgi.internal.serviceregistry.ServiceFactoryUse.factoryGetService(ServiceFactoryUse.java:210)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
at org.eclipse.osgi.internal.serviceregistry.ServiceFactoryUse.getService(ServiceFactoryUse.java:111)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
at org.eclipse.osgi.internal.serviceregistry.ServiceConsumer$2.getService(ServiceConsumer.java:45)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistrationImpl.getService(ServiceRegistrationImpl.java:496)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.getService(ServiceRegistry.java:461)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
at org.eclipse.osgi.internal.framework.BundleContextImpl.getService(BundleContextImpl.java:619)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
at com.eclipsesource.jaxrs.publisher.internal.ResourceTracker.addingService(ResourceTracker.java:39)[10:com.eclipsesource.jaxrs.publisher:5.3.1.201602281253]
at org.osgi.util.tracker.ServiceTracker$Tracked.customizerAdding(ServiceTracker.java:941)[org.osgi.core-6.0.0.jar:]
at org.osgi.util.tracker.ServiceTracker$Tracked.customizerAdding(ServiceTracker.java:870)[org.osgi.core-6.0.0.jar:]
at org.osgi.util.tracker.AbstractTracked.trackAdding(AbstractTracked.java:256)[org.osgi.core-6.0.0.jar:]
at org.osgi.util.tracker.AbstractTracked.track(AbstractTracked.java:229)[org.osgi.core-6.0.0.jar:]
at org.osgi.util.tracker.ServiceTracker$Tracked.serviceChanged(ServiceTracker.java:901)[org.osgi.core-6.0.0.jar:]
at org.eclipse.osgi.internal.serviceregistry.FilteredServiceListener.serviceChanged(FilteredServiceListener.java:109)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
at org.eclipse.osgi.internal.framework.BundleContextImpl.dispatchEvent(BundleContextImpl.java:914)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
at org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEventSynchronous(ListenerQueue.java:148)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.publishServiceEventPrivileged(ServiceRegistry.java:862)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.publishServiceEvent(ServiceRegistry.java:801)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistrationImpl.register(ServiceRegistrationImpl.java:127)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.registerService(ServiceRegistry.java:225)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
at org.eclipse.osgi.internal.framework.BundleContextImpl.registerService(BundleContextImpl.java:464)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
at org.apache.felix.scr.impl.manager.AbstractComponentManager$3.register(AbstractComponentManager.java:886)[32:org.apache.felix.scr:2.0.6]
at org.apache.felix.scr.impl.manager.AbstractComponentManager$3.register(AbstractComponentManager.java:873)[32:org.apache.felix.scr:2.0.6]
at org.apache.felix.scr.impl.manager.RegistrationManager.changeRegistration(RegistrationManager.java:132)[32:org.apache.felix.scr:2.0.6]
at org.apache.felix.scr.impl.manager.AbstractComponentManager.registerService(AbstractComponentManager.java:940)[32:org.apache.felix.scr:2.0.6]
at org.apache.felix.scr.impl.manager.AbstractComponentManager.activateInternal(AbstractComponentManager.java:740)[32:org.apache.felix.scr:2.0.6]
at org.apache.felix.scr.impl.manager.DependencyManager$MultipleDynamicCustomizer.addedService(DependencyManager.java:333)[32:org.apache.felix.scr:2.0.6]
at org.apache.felix.scr.impl.manager.DependencyManager$MultipleDynamicCustomizer.addedService(DependencyManager.java:291)[32:org.apache.felix.scr:2.0.6]
at org.apache.felix.scr.impl.manager.ServiceTracker$Tracked.customizerAdded(ServiceTracker.java:1215)[32:org.apache.felix.scr:2.0.6]
at org.apache.felix.scr.impl.manager.ServiceTracker$Tracked.customizerAdded(ServiceTracker.java:1136)[32:org.apache.felix.scr:2.0.6]
at org.apache.felix.scr.impl.manager.ServiceTracker$AbstractTracked.trackAdding(ServiceTracker.java:945)[32:org.apache.felix.scr:2.0.6]
at org.apache.felix.scr.impl.manager.ServiceTracker$AbstractTracked.track(ServiceTracker.java:881)[32:org.apache.felix.scr:2.0.6]
at org.apache.felix.scr.impl.manager.ServiceTracker$Tracked.serviceChanged(ServiceTracker.java:1167)[32:org.apache.felix.scr:2.0.6]
at org.apache.felix.scr.impl.BundleComponentActivator$ListenerInfo.serviceChanged(BundleComponentActivator.java:127)[32:org.apache.felix.scr:2.0.6]
at org.apache.felix.scr.impl.manager.AbstractComponentManager.enableInternal(AbstractComponentManager.java:674)[32:org.apache.felix.scr:2.0.6]
at org.apache.felix.scr.impl.manager.AbstractComponentManager.enable(AbstractComponentManager.java:429)[32:org.apache.felix.scr:2.0.6]
at org.apache.felix.scr.impl.manager.ConfigurableComponentHolder.enableComponents(ConfigurableComponentHolder.java:657)[32:org.apache.felix.scr:2.0.6]
at org.apache.felix.scr.impl.BundleComponentActivator.initialEnable(BundleComponentActivator.java:341)[32:org.apache.felix.scr:2.0.6]
at org.apache.felix.scr.impl.Activator.loadComponents(Activator.java:403)[32:org.apache.felix.scr:2.0.6]
at org.apache.felix.scr.impl.Activator.access$200(Activator.java:54)[32:org.apache.felix.scr:2.0.6]
at org.apache.felix.scr.impl.Activator$ScrExtension.start(Activator.java:278)[32:org.apache.felix.scr:2.0.6]
at org.apache.felix.utils.extender.AbstractExtender.createExtension(AbstractExtender.java:259)[32:org.apache.felix.scr:2.0.6]
at org.apache.felix.utils.extender.AbstractExtender.modifiedBundle(AbstractExtender.java:232)[32:org.apache.felix.scr:2.0.6]
at org.apache.felix.utils.extender.AbstractExtender.addingBundle(AbstractExtender.java:192)[32:org.apache.felix.scr:2.0.6]
at org.osgi.util.tracker.BundleTracker$Tracked.customizerAdding(BundleTracker.java:469)[org.osgi.core-6.0.0.jar:]
at org.osgi.util.tracker.BundleTracker$Tracked.customizerAdding(BundleTracker.java:415)[org.osgi.core-6.0.0.jar:]
at org.osgi.util.tracker.BundleTracker$Tracked.bundleChanged(BundleTracker.java:444)[org.osgi.core-6.0.0.jar:]
at org.eclipse.osgi.internal.framework.BundleContextImpl.dispatchEvent(BundleContextImpl.java:902)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEventPrivileged(EquinoxEventPublisher.java:165)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEvent(EquinoxEventPublisher.java:75)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEvent(EquinoxEventPublisher.java:67)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
at org.eclipse.osgi.internal.framework.EquinoxContainerAdaptor.publishModuleEvent(EquinoxContainerAdaptor.java:102)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
at org.eclipse.osgi.container.Module.publishEvent(Module.java:466)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
at org.eclipse.osgi.container.Module.start(Module.java:457)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
at org.eclipse.osgi.framework.util.SecureAction.start(SecureAction.java:454)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
at org.eclipse.osgi.container.ModuleContainer.applyDelta(ModuleContainer.java:717)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
at org.eclipse.osgi.container.ModuleContainer.resolveAndApply(ModuleContainer.java:491)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
at org.eclipse.osgi.container.ModuleContainer.resolve(ModuleContainer.java:437)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
at org.eclipse.osgi.container.ModuleContainer.refresh(ModuleContainer.java:955)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
at org.eclipse.osgi.container.ModuleContainer$ContainerWiring.dispatchEvent(ModuleContainer.java:1336)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
at org.eclipse.osgi.container.ModuleContainer$ContainerWiring.dispatchEvent(ModuleContainer.java:1)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
at org.eclipse.osgi.framework.eventmgr.EventManager$EventThread.run(EventManager.java:340)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
2017-04-15 17:15:19.148 [WARN ] [org.openhab.binding.mcp23017 ] - FrameworkEvent WARNING - org.openhab.binding.mcp23017
org.osgi.framework.ServiceException: org.apache.felix.scr.impl.manager.SingleComponentManager.getService() returned a null service object
at org.eclipse.osgi.internal.serviceregistry.ServiceFactoryUse.factoryGetService(ServiceFactoryUse.java:232)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
at org.eclipse.osgi.internal.serviceregistry.ServiceFactoryUse.getService(ServiceFactoryUse.java:111)org.eclipse.osgi.internal.serviceregistry.FilteredServiceListener.serviceChanged(FilteredServiceListener.java:109)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
This was I think because the user openhab was not in the group GPIO.
After adding it the error was gone.
Creating Items gave me following error:
2017-04-15 19:47:07.920 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'mcp23017.itemsā
2017-04-15 19:47:07.952 [ERROR] [nding.AbstractGenericBindingProvider] - Binding org.openhab.binding.mcp23017.internal.MCP23017Binding threw an exception:
java.lang.NullPointerException
at com.pi4j.io.gpio.impl.GpioControllerImpl.unprovisionPin(GpioControllerImpl.java:916)[204:org.openhab.binding.mcp23017:1.10.0.201704100111]
at org.openhab.binding.mcp23017.internal.MCP23017Binding.unBindGpioPin(MCP23017Binding.java:255)[204:org.openhab.binding.mcp23017:1.10.0.201704100111]
at org.openhab.binding.mcp23017.internal.MCP23017Binding.bindingChanged(MCP23017Binding.java:209)[204:org.openhab.binding.mcp23017:1.10.0.201704100111]
at org.openhab.model.item.binding.AbstractGenericBindingProvider.notifyListeners(AbstractGenericBindingProvider.java:124)[184:org.openhab.core.compat1x:2.0.0]
at org.openhab.model.item.binding.AbstractGenericBindingProvider.removeConfigurations(AbstractGenericBindingProvider.java:111)[184:org.openhab.core.compat1x:2.0.0]
at org.openhab.core.binding.internal.BindingConfigReaderDelegate.startConfigurationUpdate(BindingConfigReaderDelegate.java:89)[184:org.openhab.core.compat1x:2.0.0]
at org.eclipse.smarthome.model.item.internal.GenericItemProvider.processBindingConfigsFromModel(GenericItemProvider.java:160)[123:org.eclipse.smarthome.model.item:0.9.0.b4]
at org.eclipse.smarthome.model.item.internal.GenericItemProvider.modelChanged(GenericItemProvider.java:338)[123:org.eclipse.smarthome.model.item:0.9.0.b4]
at org.eclipse.smarthome.model.core.internal.ModelRepositoryImpl.notifyListeners(ModelRepositoryImpl.java:207)[122:org.eclipse.smarthome.model.core:0.9.0.b4]
at org.eclipse.smarthome.model.core.internal.ModelRepositoryImpl.addOrRefreshModel(ModelRepositoryImpl.java:99)[122:org.eclipse.smarthome.model.core:0.9.0.b4]
at org.eclipse.smarthome.model.core.internal.folder.FolderObserver.checkFile(FolderObserver.java:272)[122:org.eclipse.smarthome.model.core:0.9.0.b4]
at org.eclipse.smarthome.model.core.internal.folder.FolderObserver.access$1(FolderObserver.java:265)[122:org.eclipse.smarthome.model.core:0.9.0.b4]
at org.eclipse.smarthome.model.core.internal.folder.FolderObserver$WatchQueueReader.processWatchEvent(FolderObserver.java:146)[122:org.eclipse.smarthome.model.core:0.9.0.b4]
at org.eclipse.smarthome.core.service.AbstractWatchQueueReader.run(AbstractWatchQueueReader.java:122)[98:org.eclipse.smarthome.core:0.9.0.b4]
at java.lang.Thread.run(Thread.java:745)[:1.8.0_121]
AND
2017-04-15 19:47:07.976 [DEBUG] [ernal.MCP23017GenericBindingProvider] - Process binding configuration in context mcp23017.items
2017-04-15 19:47:07.978 [ERROR] [nding.AbstractGenericBindingProvider] - Binding org.openhab.binding.mcp23017.internal.MCP23017Binding threw an exception:
java.lang.RuntimeException: Could not instantiate I2CBus
at com.pi4j.io.i2c.impl.I2CProviderImpl.getBus(I2CProviderImpl.java:74)[204:org.openhab.binding.mcp23017:1.10.0.201704100111]
at com.pi4j.io.i2c.impl.I2CProviderImpl.getBus(I2CProviderImpl.java:112)[204:org.openhab.binding.mcp23017:1.10.0.201704100111]
at com.pi4j.io.i2c.I2CFactory.getInstance(I2CFactory.java:76)[204:org.openhab.binding.mcp23017:1.10.0.201704100111]
at com.pi4j.gpio.extension.mcp.MCP23017GpioProvider.<init>(MCP23017GpioProvider.java:113)[204:org.openhab.binding.mcp23017:1.10.0.201704100111]
at com.pi4j.gpio.extension.mcp.MCP23017GpioProvider.<init>(MCP23017GpioProvider.java:108)[204:org.openhab.binding.mcp23017:1.10.0.201704100111]
at org.openhab.binding.mcp23017.internal.MCP23017Binding.bindGpioPin(MCP23017Binding.java:222)[204:org.openhab.binding.mcp23017:1.10.0.201704100111]
at org.openhab.binding.mcp23017.internal.MCP23017Binding.bindingChanged(MCP23017Binding.java:206)[204:org.openhab.binding.mcp23017:1.10.0.201704100111]
at org.openhab.model.item.binding.AbstractGenericBindingProvider.addBindingConfig(AbstractGenericBindingProvider.java:118)[184:org.openhab.core.compat1x:2.0.0]
at org.openhab.binding.mcp23017.internal.MCP23017GenericBindingProvider.processBindingConfiguration(MCP23017GenericBindingProvider.java:107)[204:org.openhab.binding.mcp23017:1.10.0.201704100111]
at org.openhab.core.binding.internal.BindingConfigReaderDelegate.processBindingConfiguration(BindingConfigReaderDelegate.java:48)[184:org.openhab.core.compat1x:2.0.0]
at org.eclipse.smarthome.model.item.internal.GenericItemProvider.internalDispatchBindings(GenericItemProvider.java:312)[123:org.eclipse.smarthome.model.item:0.9.0.b4]
at org.eclipse.smarthome.model.item.internal.GenericItemProvider.internalDispatchBindings(GenericItemProvider.java:284)[123:org.eclipse.smarthome.model.item:0.9.0.b4]
at org.eclipse.smarthome.model.item.internal.GenericItemProvider.processBindingConfigsFromModel(GenericItemProvider.java:167)[123:org.eclipse.smarthome.model.item:0.9.0.b4]
Caused by: java.io.IOException: Cannot open file handle for /dev/i2c-1 got -1 back.
at com.pi4j.io.i2c.impl.I2CBusImpl.open(I2CBusImpl.java:123)[204:org.openhab.binding.mcp23017:1.10.0.201704100111]
at com.pi4j.io.i2c.impl.I2CProviderImpl.getBus(I2CProviderImpl.java:69)[204:org.openhab.binding.mcp23017:1.10.0.201704100111]
... 21 more
