Well. Still struggling with this. Been googling and searching and tried this little rule, but still not sure how you can get the dimmer level of Color Bulb.
rule "Get Dimmer Value"
Item FF_Lightify_LED_TV changed
FF_LED_Dim_Level = (FF_Lightify_LED_TV.state as HSBType).getBrightness
If not, is 2.2.0.201712151711 the latest version? This version worked great for 3-4 days, then stopped responding until I went into the Karaf console and issued a bundle:restart command.
The latest should be a 2.4 version and should be available via
the marketplace. However my marketplace addon is currently
complaining about “handshake failures” (even though the URL it
uses seems to work fine). If you can’t get the right version via
the marketplace addon you can download it from the PR or from the
entry at and put it in your
addons folder.
Note that it helps, but it doesn’t solve the issue. Sometimes it quits working before my nightly restart, so I have no control of my Lightify until I do it manually.
I found that reducing the maximum polling interval of the lightify hub to 3 seconds instead of the default caused this problem and the problem of my hub going unresponsive to openhab2 both to disappear. Seems to keep the hub responsive and as long as the hub is responsive the memory and cpu cycles leaks both evaporated.
Just a quick update: the nightly reboot is not a good solution since the JIT compiler takes some time to process rules for e.g. light switches in my home – so one has a delay of a couple of seconds on first use of the day…
@jgreene: Can you post a screenshot of your gateway settings as reference?
These are my settings which appear to work well. No reboot neither a restart of the binding since about 5 days. Over 80.000 requests have been sent to the gateway in that time.
@ceedee are those gateway settings still working for you? I’m using 2.5.0 snapshot and am seeing the same issue with the gateway going unresponsive in the binding, but still working via the Lightify app. I’ll apply them tonight and see if it does anything for me.
Thanks for the feedback @_Jens. What version are you currently running? The latest (2.4.0 I think) from the marketplace? Are you seeing good results with that version and those configuration parameters now?
@mjagdis is this unresponsiveness issue something you’ve been able to recreate? Happy to provide any data I can if needed
Blockquote What version are you currently running? The latest (2.4.0 I think) from the marketplace? Are you seeing good results with that version and those configuration parameters now?
I’m now running 4.2.1 with the (current) marketplace Version of the Lightify AddOn about a week and got no problems since then.
Would it be possible to integrate support for RGB Devices in the binding. I have a Osram Garden Spot Mini which RGB (without W) and it is not discovered by the binding. With assistance I would be able provide needed information.
