Paradox EVO Binding
The other way is to enter programming mode (you will need the programmer PIN for that) from your keypad and check the value of section 3012. It’s pretty easy. Just refer to the programming guide.
If you don’t feel confident with that probably asking security company would be the best idea.
I do not have the programmer PIN either. The only two things I have are the panel user code (I think with admin rights) and the module password (I suppose that this password at least works according to the log " Login - Login to IP150 - OK"). I have to wait for the answer of the security company.
Hello, Can you update the JAR file? I can not reach IP150 through http till openhab runs. Paradox Android App is able to log in from both LAN and WAN.
This is limitation of IP150 as far as I know. You cannot also connect via web interface if you’re connected via Babyware and vice versa.
For this to work I’ve created a command channel to the bridge. You can map a button to send LOGOUT/LOGIN command from OpenHab to the security system. With this option you have the flexibility to connect/disconnect on demand.
Please check the README. There is an example how to setup such item. If you have issues please let me know.
Cheers,
K.
OK. Pls update the download folder with the latest jar file. Then I can update.
Hi.
New version has been uploaded.
Backward incompatible changes exist - some channels got renamed due to review requirements, also the static data like serial numbers, firmware revisions, etc is now modelled as properties and not channels.
Cheers,
K.
Hi @Jean_Henning,
Just wondered if you still invest time in reverse engineering this protocol and if you have any progress with partition activate/deactivate commands?
One additional question.
I’ve found that after the login sequence if you wait for around 200-300ms and call receive from the socket, there is a 37 bytes packet received which does not fit into the staging you’ve documented. What I currently do is I just receive and ignore it.
Did you noticed such packet at your system? Do you have any clue what it’s doing?
I’m currently away from home but when I get back I will publish the contents if you’re interested into it.
Cheers,
Konstantin
At the moment I use this OH version: openHAB 2.5.0 Build #1512
If I update newer snapshot, your binding does not work.
I have problems with other bindings as well, like Xiaomi.
It becomes very unstable.
Are you using the JAR or the source code and build it yourself?
I believe in my last push due to requested changes there is a regression in communication part when the binding times out.
I will try to fix it as soon as possible but meanwhile please use the latest built JAR.
Cheers,
K.
EDIT: Just checked. My Openhab is M1 release. Haven’t upgraded since then…
Thanks! There are important changes after february I think, that’s why I wanted to update. But it is not that urgent. I use your latest jar file. I installed Eclipse enviroment but I had version problems and I could not fix it. I hadn’t got enough time. Anyway I wanted to make some debug logs for you with the new versions. I can upgrade and put back the original version fast. So if you want, I can do the debug files to see where it stops in the next two weeks. I wil be busy next week and probably I can do it only a week after.
I’m currently busy with other time-consuming stuff outside OpenHAB and that’s why also the pull request is getting delayed. I just cannot contribute right now. Two weeks from now may be the time when I will get more free time so feel free to send me the logs.
When I have time I’ll make sure to also upgrade my own system and test it myself.
Cheers,
K.
Thanks! No problem, we have planty of time. Probably I go back to M1 as well. I’ll make the log soon.
Hi all,
just a quick heads up that the binding has been merged in the main branch so probably you will be able to install the normal way once the milestone has been published.
I’m currently looking how to implement a discovery service so things can be added from the modern UIs. Bridge should be able to do that because what we need initially is just a connection to the paradox system. All the supported types should be very easy to retrieve. Will post when I have progress with that.
Cheers,
Konstantin
Thanks! Currently I’m on 2.5M1. As soon as M2 is released I will try it out. I also test the distro versions time to time but the recent versions were not working for me. System itself was working in the backound but Paper UI, Basic UI were unstable or frozen.
discovery service is also merged in main branch.
Be aware that you need to configure the bridge first and then all entities will be automatically discovered.
Things will be labeled by the ThingTypeUID + the label of the thing given in the paradox system.
Background discovery is disabled currently.
Best regards,
Konstantin
Hello, I have installed openHAB 2.5.0 Build #1645 snapshot. It does not contains Paradoxalarm binding. Plus I can confirm that it works with org.openhab.binding.paradoxalarm-2.5.0-SNAPSHOT seamless.
Hello, Info. I have installed the next snapshot. Paradox binding does not start. Here is the openhab.log: paradox_debug.txt (4.4 KB) I go back the last pervious one. It works with that fine and I will try one next one later.
Anyone can help me with this error? Thank you.
019-08-02 10:00:24.625 [INFO ] [l.handlers.ParadoxIP150BridgeHandler] - Found EVOHD panel type.
2019-08-02 10:00:24.627 [INFO ] [al.communication.GenericCommunicator] - Stopping communication to Paradox system
2019-08-02 10:00:24.629 [INFO ] [al.communication.GenericCommunicator] - Waiting the socket to close…
2019-08-02 10:00:25.631 [INFO ] [al.communication.GenericCommunicator] - Communicator closed successfully.
2019-08-02 10:00:25.634 [INFO ] [l.handlers.ParadoxIP150BridgeHandler] - Phase2 - Creating communicator for panel EVOHD
2019-08-02 10:00:25.643 [INFO ] [al.communication.GenericCommunicator] - Login - Login to IP150 - OK
2019-08-02 10:00:25.719 [INFO ] [al.communication.GenericCommunicator] - Successful logon to the panel.
2019-08-02 10:00:39.009 [hingStatusInfoChangedEvent] - ‘paradoxalarm:ip150:cced4079’ changed from OFFLINE to OFFLINE (COMMUNICATION_ERROR): Error initializing panel handler. Exception: java.io.IOException: Unable to read from socket or received data is wrong.
Hi.
Thanks for the feedback! I’m currently on my summer vacation without laptop so will have a look at it earliest on Tuesday next week.
Cheers,
K.
The behavior looks like there is difference in protocol between evo48/96/192 and evohd.
To be sure I will need you to raise the log level to TRACE for paradox binding and attach the log here. If this is the case I guess we need to code new communicator for EVOHD if someone reverse engineers the protocol.
Cheers,
K.
