The problem is present in OH3.0.0 and 3.1.x.
The problem did not exist in OH2.5.x.
Unfortunately, the two parameters 11 & 12 cannot be set via the Thing configuration.
However, the two parameters can be set and saved via the code tab.
0 is selected by default.
Parameter no.11 - Turn Load 1 (Q) OFF Automatically with Timer
Parameter no.12 - Turn Load 1 (Q) ON Automatically with Timer
Here is the description of the parameter of Quibino:
default value 0
0 - Auto OFF / ON Disabled
1 - 32536 = 1 - 32536 seconds - Auto OFF / ON timer enabled for a given amount of seconds
Is that an error in the database or in Obenhab 3?
If there is an error in the database, can you please correct it?
No, you don’t need to recreate the thing - but you will need to update the binding once this all flows through the system, which will take a day or two.
