is there a way I can parse the model in my widgets?
e.g. I have hundreds of temperature items that shall get a “Default Standalone widget”.
It would be great if I didn’t have to configure each widget separately but instead use the value of the item the widget belongs to.
Even more ellaborate I would like to create widgets for equipment that takes the values of the respective point instead of having to configure for each equipment the items separately.
There are more widget to be used in combination with that. To use the project, you need them all.
Documentation is still missing, but will hopefully come soon.
Hallo @hmerk having a quick look at the project - great idea by the way - seems to point that the second problem seems to be solved. I can parse through all items of an equipment and even have a great filtering for item types - e.g. seen in Light Card widget
But also here I have to configure the groupItem as the root for the oh-repeater.
What I’m also looking for is a way to get this “groupItem” automatically by a reference to the Item or equipment the widget is linked too.
Can I get this reference somehow?
E.g. in above picture I would like to get the reference to the item HeizungErker_ActualTemperature.
