I’m working on OpeHab 2.3 and above. Recently I tried to solve this scenario, let’s describe it theoretically:
- There is a switch with multiple states, that communicates with OpenHab
- According to the state a light relay should be activated
- Each relay should switch itself off after a given delay time
- There are many of relays and switch states that are bundled
My current solution:
- I would like to solve this in an elegant and efficient way according that there is the same procedure for each switch state but different relay and delay time
- I’m using procedures for repeated action
- I’m declaring a timer for each relay
My current code look like this:
var Timer ExampleTimer_1 = null
var Timer ExampleTimer_2 = null
var Timer ExampleTimer_3 = null
var Timer ExampleTimer_4 = null
val Delayed_Switch = [ SwitchItem Relay, Timer Tim, Number DelayTime |
if(Relay.state == ON)
sendCommand(Relay, OFF)
if( Tim !== null )
Tim.cancel
Tim=null
else
sendCommand(Relay, ON)
Tim=createTimer(now.plusSeconds(DelayTime))[|
Tim=null
rule "Example rule"
Item MultiStateSwitch received update
switch(MultiStateSwitch.state.toString)
case "State Tex 1":
Delayed_Switch.apply(Light_1_Relay, ExampleTimer_1, 120)
case "State Tex 2":
Delayed_Switch.apply(Light_1_Relay, ExampleTimer_2, 20)
case "State Tex 3":
Delayed_Switch.apply(Light_1_Relay, ExampleTimer_3, 80)
When I save this rule I get the following error:
[INFO ] [del.core.internal.ModelRepositoryImpl] - Validation issues found in configuration model 'Example.rules', using it anyway:
Assignment to final parameter
[INFO ] [del.core.internal.ModelRepositoryImpl] - Refreshing model 'Example.rules'
After a switch send a state change the following happens:
[INFO ] [smarthome.event.ItemCommandEvent ] - Item 'Light_1_Relay' received command ON
[ERROR] [untime.internal.engine.RuleEngineImpl] - Rule 'Example rule': Couldn't invoke 'assignValueTo' for feature param Tim
[ERROR] [org.quartz.core.JobRunShell ] - Job DEFAULT.2020-04-12T17:13:53.606+02:00: Proxy for org.eclipse.xtext.xbase.lib.Procedures$Procedure0: [ | {
sendCommand(<XFeatureCallImplCustom>,<XFeatureCallImplCustom>)
<null>.Tim = <XNullLiteralImplCustom>
} ] threw an unhandled Exception:
java.lang.IllegalArgumentException: Couldn't invoke 'assignValueTo' for feature param Tim
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.assignValueTo(XbaseInterpreter.java:1224) [156:org.eclipse.xtext.xbase:2.12.0.v20170519-0752]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._doEvaluate(XbaseInterpreter.java:1212) [156:org.eclipse.xtext.xbase:2.12.0.v20170519-0752]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.doEvaluate(XbaseInterpreter.java:215) [156:org.eclipse.xtext.xbase:2.12.0.v20170519-0752]
at org.eclipse.smarthome.model.script.interpreter.ScriptInterpreter.doEvaluate(ScriptInterpreter.java:219) [137:org.eclipse.smarthome.model.script:0.10.0.oh230]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.internalEvaluate(XbaseInterpreter.java:203) [156:org.eclipse.xtext.xbase:2.12.0.v20170519-0752]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._doEvaluate(XbaseInterpreter.java:446) [156:org.eclipse.xtext.xbase:2.12.0.v20170519-0752]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.doEvaluate(XbaseInterpreter.java:227) [156:org.eclipse.xtext.xbase:2.12.0.v20170519-0752]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.evaluate(XbaseInterpreter.java:189) [156:org.eclipse.xtext.xbase:2.12.0.v20170519-0752]
at org.eclipse.xtext.xbase.interpreter.impl.ClosureInvocationHandler.doInvoke(ClosureInvocationHandler.java:46) [156:org.eclipse.xtext.xbase:2.12.0.v20170519-0752]
at org.eclipse.xtext.xbase.interpreter.impl.AbstractClosureInvocationHandler.invoke(AbstractClosureInvocationHandler.java:29) [156:org.eclipse.xtext.xbase:2.12.0.v20170519-0752]
at com.sun.proxy.$Proxy143.apply(Unknown Source) [?:?]
at org.eclipse.smarthome.model.script.internal.actions.TimerExecutionJob.execute(TimerExecutionJob.java:49) [137:org.eclipse.smarthome.model.script:0.10.0.oh230]
at org.quartz.core.JobRunShell.run(JobRunShell.java:202) [107:org.eclipse.smarthome.core.scheduler:0.10.0.oh230]
at org.quartz.simpl.SimpleThreadPool$WorkerThread.run(SimpleThreadPool.java:573) [107:org.eclipse.smarthome.core.scheduler:0.10.0.oh230]
[INFO ] [smarthome.event.ItemCommandEvent ] - Item 'Light_1_Relay' received command OFF
[ERROR] [org.quartz.core.ErrorLogger ] - Job (DEFAULT.2020-04-12T17:13:53.606+02:00: Proxy for org.eclipse.xtext.xbase.lib.Procedures$Procedure0: [ | {
} ] threw an exception.
org.quartz.SchedulerException: Job threw an unhandled exception.
at org.quartz.core.JobRunShell.run(JobRunShell.java:213) [107:org.eclipse.smarthome.core.scheduler:0.10.0.oh230]
Caused by: java.lang.IllegalArgumentException: Couldn't invoke 'assignValueTo' for feature param Tim
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.assignValueTo(XbaseInterpreter.java:1224) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._doEvaluate(XbaseInterpreter.java:1212) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.doEvaluate(XbaseInterpreter.java:215) ~[?:?]
at org.eclipse.smarthome.model.script.interpreter.ScriptInterpreter.doEvaluate(ScriptInterpreter.java:219) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.internalEvaluate(XbaseInterpreter.java:203) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._doEvaluate(XbaseInterpreter.java:446) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.doEvaluate(XbaseInterpreter.java:227) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.evaluate(XbaseInterpreter.java:189) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.ClosureInvocationHandler.doInvoke(ClosureInvocationHandler.java:46) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.AbstractClosureInvocationHandler.invoke(AbstractClosureInvocationHandler.java:29) ~[?:?]
at com.sun.proxy.$Proxy143.apply(Unknown Source) ~[?:?]
at org.eclipse.smarthome.model.script.internal.actions.TimerExecutionJob.execute(TimerExecutionJob.java:49) ~[?:?]
at org.quartz.core.JobRunShell.run(JobRunShell.java:202) ~[?:?]
... 1 more
As far as I understand the error after triggering the procedure could be related to timer being null declared.
So I have some questions, how this cam be solved:
- How can I initialise a timer so I can safely pass it to a procedure?
- Maybe a better way would be to declare an array of timers, but then I need to somehow initialise the timers in this array and call them by the array index, or?
- What is the errors after saving the rule file meaning?
- Maybe there is some more elegant way?
Thank you in advance for some tips and tricks!
