Hi folks,
I am using the openHAB cloud. I mostly use it to view and not edit the dashboard. However, when I did try update my dashboard (which is quite large) I get the following error.
Cheers
Hi folks,
Cheers
I get the same error:
Maybe it’s because my dashboard contains several custom widgets (which adds up so some hundred lines of code I think).
Is there a limit for the file size? And is there a solution or a workaround?
I really like the feature of editing Habpanel from anywhere…
Is there any news of this?
I can confirm that if I allow my HabPanel JSon file to be any more than 1999 lines, I get the Error : 413 (Payload Too Large) error.
Which is a shame as I’d love to put in a great Thermostat Widget that @tomvancutsem has written.
FYI
It seems okay to have more than 2000 lines if the JSon file is saved and accessed locally, but attempting to store >1999 lines of JSon on the controller causes the 413 error.
GitHub Issue
https://github.com/openhab/org.openhab.ui.habpanel/issues/324
Just for clarification.
It appears that there is a file size limit when saving while connected via the myopenhab.org service.
Saving while connected on the local LAN is fine.
