I just want to share here the procedure I followed finally to calculate two different type of Moving Average Methods:
- Simple Moving average (average of the last x measurement readings)
- Single Exponential Smoothing (At+1 = a Mt + (1 - a) Ft
The method can be defined via a parameter in the rule ( AveragingMethod
) - but could be also of course an item Parameter.
Item Definition:
Each Item which should be averaged should be
a) in the Group gMovingAverage
b) have a second corresponding item with the same name + postfix ("_MovingAverage")
which must tbe in the group “gAveragedMembers”
Rule:
> rule "SprMovingAverageCalculation"
> when
> Member of gMovingAverage changed
> then
> // example item which is to be updated with this rule:
> // myItemName_MovingAverage
> var Number AverageValue
> var DateTime StartTime
> var Number AveragingPeriod_Minutes
> var Number ExponentialSmoothingFactor_Alpha
> //var Item itemAverage
> // calculate the average
> if( triggeringItem.state !== null )
> // --------- define the averaging method
> //var AveragingMethod = "MovingAverage"
> var AveragingMethod = "SingleExponentialSmoothing"
> // define all necessary parameters - these could eventually also provided by separate parameter items (if they need to be dynamic changeable)
> AveragingPeriod_Minutes = 30 // this is useful only for the Method "MovingAverage"
> ExponentialSmoothingFactor_Alpha = 0.3
> val Number local_AllowedDistortionPercent = 0.10
> // ------------------ Standard Averaging MEthod from persistance service
> AverageValue = triggeringItem.averageSince(now.minusMinutes(AveragingPeriod_Minutes))
> val SearchItemName = ((triggeringItem.name) as String) + "_MovingAverage"
> // find the item containging the moving average
> val itemAverage = gAveragedMembers.members.findFirst[ name.equals( SearchItemName )]
> // ------------------ Alternative Averaging Method using REST API and skipping values out of range
> StartTime = now.minusMinutes(AveragingPeriod_Minutes)
> // retrieve the stored datapoints of the triggeringItem from persistance service via the REST Interface
> val local_httpString = "http://localhost:8080/rest/persistence/items/" + ((triggeringItem.name) as String) + "?starttime=" + StartTime.toString("yyyy-MM-dd'T'HH:mm:ss")
> val RESULT_json = sendHttpGetRequest(local_httpString,1000)
> // get the number of datapoints from the json structure
> var Number local_numdatapoints = transform("JSONPATH", "$.datapoints", RESULT_json)
> // retrieve the persisted values also for the averaging item -> this is required to allow an exponential smoothing algorithm
> // Note: actually we do not need to retrieve all datapoints from the same StartTime but we keep it for simplicity
> val local_httpString_itemAverage = "http://localhost:8080/rest/persistence/items/" + ((itemAverage.name) as String) + "?starttime=" + StartTime.toString("yyyy-MM-dd'T'HH:mm:ss")
> val RESULT_json_itemAverage = sendHttpGetRequest(local_httpString_itemAverage,1000)
> var Number local_numdatapoints_itemAverage = transform("JSONPATH", "$.datapoints", RESULT_json_itemAverage)
> // Note: extracting an array of data is not supported with JSONPATH - thus next line is invalid
> //--- multiple JSON PATH results from an arry seems not supported by JSONPATH transformation - thus we use javascript transformation function
> //var local_datapoints = transform("JSONPATH", "$.data", RESULT_json)
> // build the parameter string for the Javascript function.
> // unfortunately multiple arguments to Javascript functions is not supported in OpenHAB - Thus we concatenate the parameters in a single
> // String parameter seperated by a | character
> // Parameters are
> // json_string_input - json structure (as string) containing all data points for the measurement item
> // AllowedDistortionPercent - Percent of allowed difference between the average and the actual measurement to take the actual
> // measurement value into account for averaging
> // Average_non_clean - the average value as calculated from simple persistance service
> // json_string_input_averaged - json structure (as string) containing all data points for the averaged-item
> // AveragingMethod
> // Averaging Method can be one out of the following parameters:
> // AveragingMethod = "MovingAverage"
> // AveragingMethod = "SingleExponentialSmoothing"
> // ExponentialSmoothingFactor_Alpha -- defines the exponential smoothing factor alpha
> var String local_paramstring = RESULT_json.concat("|").concat(String::valueOf(local_AllowedDistortionPercent)).concat("|").concat(String::valueOf(AverageValue)).concat("|").concat(RESULT_json_itemAverage).concat("|").concat(AveragingMethod).concat("|").concat(String::valueOf(ExponentialSmoothingFactor_Alpha))
> logInfo("SprinklerRule:SprMovingAverageCalculation", "ParameterString for javascript transform of Item: " + triggeringItem.name + "= " + local_paramstring )
> // invoke the Javascript Function - where the actual calculation is performed
> var String local_CleanAverageValue_string = transform("JS", "average_within_range.js", local_paramstring)
> var local_CleanAverageValue = Float::parseFloat(local_CleanAverageValue_string) as Number
> // ------------- write result to the itemAverage
> // using standard average
> //itemAverage.postUpdate( AverageValue )
> // using local clean average
> itemAverage.postUpdate( local_CleanAverageValue )
> else
> logInfo("SprinklerRule:SprMovingAverageCalculation", "Item: " + triggeringItem.name + " has state NULL: No average calculated ")
> end // end of rule SprMovingAverageCalculation
And the correspnding Javascript file (to be located in the …/transform directory ):
(function(inputParam)
// Input Parameters needs to be passed in single parameter, seperated by a | character
//json_string_input | AllowedDistortionPercent | Average_non_clean | json_string_input_averaged | AveragingMethod | ExponentialSmoothingFactor_Alpha
var inputArray = inputParam.split("|");
var json_string_input = inputArray[0];
var AllowedDistortionPercent = Number(inputArray[1]);
var Average_non_clean = Number(inputArray[2]);
var json_string_input_averaged = inputArray[3];
var AveragingMethod = inputArray[4];
var ExponentialSmoothingFactor_Alpha = Number(inputArray[5]);
if(AveragingMethod!="MovingAverage" && AveragingMethod!="SingleExponentialSmoothing")
return ("Error in javascript: AveragingMethod not recognized");
// This is an exaple of an exptected json_string_input string
// "name": "the_item_name",
// "datapoints": "2",
// "data": [
// "time": 1574888891000,
// "state": "551.35"
// "time": 1574889191000,
// "state": "-1.0"
var json_object = JSON.parse(json_string_input);
var json_object_average = JSON.parse(json_string_input_averaged);
var datapoints = json_object.datapoints;
var datapoints_average = json_object_average.datapoints;
var Arithmetic_sum_valid_datapoints = 0.0;
var valid_datapoints = 0;
var local_CleanAverageValue = 0.0;
var difference = 0.0;
// --------------- Moving Average Method
if(AveragingMethod=="MovingAverage")
for(i = 0, l = Number(json_object.data.length); i < l; i++)
// `i` will take on the values `0`, `1`, `2`,..., i.e. in each iteration
// we can access the next element in the array with `data.items[i]`, example:
// var obj = data.items[i];
// Since each element is an object (in our example),
// we can now access the objects properties with `obj.id` and `obj.name`.
// We could also use `data.items[i].id`.
if( Number(json_object.data[i].state) > 0)
difference = Math.abs(Number(json_object.data[i].state) - Average_non_clean);
if(((Number(json_object.data[i].state) - Average_non_clean)/Average_non_clean) < AllowedDistortionPercent)
// if current datapoint is within valid distortion range then we use this datapoint for the averaging calculation
Arithmetic_sum_valid_datapoints = Arithmetic_sum_valid_datapoints + Number(json_object.data[i].state);
valid_datapoints = valid_datapoints + 1;
if(valid_datapoints > 0)
local_CleanAverageValue = Math.round(Arithmetic_sum_valid_datapoints / valid_datapoints*1000)/1000;
else
} // End of moving average method
// --------------- Single Exponential Smoothing Method
else if(AveragingMethod=="SingleExponentialSmoothing")
if(Number(json_object.data.length)>=1 && Number(json_object_average.data.length)>=1)
// the last entry in the array is the latest measurement
i = Number(json_object.data.length)-1;
j = Number(json_object_average.data.length)-1
difference = Math.round(Math.abs(Number(json_object.data[i].state) - Number(json_object_average.data[j].state))*1000)/1000;
// there is a valid datapoint available - otherwise we use the same value as the last averaging value
// counter i should represent the time t for the new measuerment data but at the same time it should represent time t-1 for the
// averaging value series as the averaging value series should have always one datapoint less (as we compute this here in this function)
local_CleanAverageValue = Math.round((Number(json_object.data[i].state) * ExponentialSmoothingFactor_Alpha + Number(json_object_average.data[j].state) * (1.0 - ExponentialSmoothingFactor_Alpha))*1000)/1000
else
// use the previous value again if the new measurement value seems to be "far" out of range
local_CleanAverageValue = Number(json_object_average.data[j].state)
else
// use the previous value again if the new measurement value is invalid
} // end of SingleExponentialSmoothing Method
return (local_CleanAverageValue);
})(input)
It is quite a quick programming style and can for sure be made more efficient but I think it shows the concept.
