This post is about:
- Persistence
- OpenHab 4
- InfluxDB v2
(There is already a good post about InfluxDB v1.x).
Renaming items is easy…
Contact Foo ...
to
Contact Bar ...
But if your item was persisted, you have now the old data in a measurement called Foo and the new data in Bar. It will likely break your charts and if you update your charts, the older data will be gone. Time to clean that up.
To get started, I find it convenient to have a Grafana chart open, showing both the OLD and the NEW item id.
So here is an example.
I renamed my DoorSensorOffice_SensorDoor into Office_Door_SensorDoor.
The value is the state so it is either 0 or 1 but it does not matter, it could be a battery level, a temperature, etc… anything.
Here is the graph:
We see the old ata in red and the new data in green.
Reminder: the following applies to InfluxDB v2.x and not InfluxDB v1.x.
My InfluxDB bucket for OpenHAB is called… openhab.
The following FLUX query will copy the old data into the new measurement (while keeping the new data obviously). I am going back 4 years but you can adjust as needed.
from(bucket: "openhab")
|> range(start: -4y, stop: now())
|> filter(fn: (r) => r._measurement == "DoorSensorOffice_SensorDoor")
|> set(key: "_measurement", value: "Office_Door_SensorDoor")
|> to(bucket: "openhab")
After submitting the query, we can see in InfluxDB:
and grafana confirms the copy: we can see green everywhere and some remains of red ![]()
Now time to clean up. I did not find a FLUX query that can do that strangely but the command line will do.
We will need:
- an InfluxDB
TOKENwith proper rights - a
MEAS-urement variable - 2 dates
Let’s first set store the MEAS value:
MEAS=DoorSensorOffice_SensorDoor
We can now run the command from the terminal:
influx delete \
--start '2020-01-01T00:00:00Z' \
--stop '2025-01-01T00:00:00Z' \
--token $TOKEN \
--bucket openhab \
--predicate '_measurement="'$MEAS'"'
A refresh in Grafana shows that we did clean things up:
I hope this can help some.
My tip would be: If you rename items, make sure to keep track both OLD and NEW name somewhere. It makes such a migration easier.
