Platform information:
- Hardware: Intel Core i3-6100T CPU @ 3.20GHz (amd64)
- OS: Docker container: docker pull openhab/openhab:latest
- Java Runtime Environment: whatever is in the container
- openHAB version: 4.1.1
Issue of the topic:
In terms of persistence, I have a pretty simple configuration. I have a file called rrd4j.persist in the persistence folder. The content of this file is:
// persistence strategies have a name and a definition and are referred to in the "Items" section
Strategies {
// if no strategy is specified for an item entry below, the default list will be used
default = everyMinute
Within the GUI I have clicked Settings->System Settings->Persistence. There is a single radial button under Default Service called RRD4j. I have ticked this radial button and clicked Save.
I have a somewhat involved custom.sitemap, for simplicity, here is a brief code segment:
Frame label="Outside" icon="garden" {
Group item=OU_FrontYard {
Default item=OU_FrontYard_UpLights
Switch item=OU_FrontYard_Chimes_Switch label="Chimes:" mappings=[on="UP",off="DOWN"]
Chart item=OU_Temperature period=12h legend=true
For completeness here is my Item definition:
Number:Temperature OU_Temperature "Temperature [%.1f %unit%]" <Temperature> (OU) ["Temperature", "Point","Measurement"] {unit="°F",channel="openweathermap:weather-and-forecast:e520b4654b:local:current#temperature"}
My expectation is to see a Chart that has the temperature for the past 12 hours. Instead, I see this:
The GUI provides a value for the Item:
I suspect that I’m overlooking something incredibly simple, but in my several years of OpenHAB, I’ve never been able to get Charts within Sitemaps to work consistently. Another possibility is that I don’t fundamentally understand how RRD4J works as a persistence service, or how persistence services work in general.
I have read:
Although the documentation says this:
NOTE: rrd4j is for storing numerical data only. It cannot store complex data types. The supported item types are therefore only Switch (internally mapped to 0/1), Dimmer, Number, Contact (internally mapped to 0/1), Rollershutter and Color (only brightness component stored).
It looks to be incorrect?
I could provide another example with an Item that is just a Dimmer and/or Number and I have the same result.
I have also tried more complex configurations in the past (on other installs of OpenHAB) with PostgreSQL, and encountered similar issues, which makes me think it’s just me doing something wrong.
[Edit: more than 12 hours has elapsed! ]
I’d really appreciate some help!
SixO
