I’m experiencing a very weird behaviour with persistence service. I have a standard InfluxDB+Grafana setup.
Practically every month, precisely at midnight of the last day of a month, persistence seems to stop for one single of the few items I have in my setup. It re-starts after a couple of days without me doing anything.
Here is what I see in Grafana:
We need to determine if the problem is caused by persistence or the Item no longer updating. If the Item is no longer updating we need to look at what is producing the updates (binding, device) to see if it is generating events during this time.
I should have specified. The item is online and keeps updating regularly and I can see the readings in BasicUI ok.
Nothing except item change events appear on the events.log.
So this is definitely a persistence problem.
I don’t have any cron rule. This is my rules file, very simple, I have nothing else that I can think of:
Blockquote
rule “Records when device was last seen”
Item GF_Backyard_Temperature received update or
Item GF_Backyard_Humidity received update or
Item GF_Backyard_Barometer received update
postUpdate(GF_Backyard_LastUpdate, new DateTimeType())
Hmmm. You are using only cron type strategies. I think @unparagoned might be on to something.
Try this. Change the first zeros on all of your cron expressions to a different number so these don’t all run at the same time. Perhaps you are running out of scheduling threads. It seems unlikely but without further information it’s the only thing that stands out.
NOTE: I assume FF is a Group. If not then the * isn’t doing what you think it’s doing. * means “All members of this Group”, not “All Items whose name starts with FF”.
@rlkoshak, I did what you suggested, changing the cron expressions and rebooted the system. Persistence re-started immediately. I’ll check it out to see if the behaviour re-appears.
Before simply restarting openhabian wasn’t effective. So I believe @unparagoned was actually pointing in the right direction!
I will also consider changing the strategy for some items to everyChange…
For now it seems solved! Many thanks for the fantastic help here!
No expertise here, but have often seen recommendation that boils down to “for graphing use everyMinute”.
Wonder if your graphing util asks for odd or even minutes data at first.
