Hello All,
I have moved to OH2 just two days ago and i’m struggling with the philio multi sensor 4-in-1.
The problem is after the device dsicovery, the motion alarm is also triggering the door/window alarm even if the door is closed.
In OH1 it was working fine as i was defining exactly the sensor type and also the “respond-to-basic” part.
Anyone having the same problem or knows a solution for this?
Looking forward for your feedbacks.
Regards,
Mohamed
chris
(Chris Jackson)
June 8, 2016, 9:17am
2
The database isn’t configured fully - I just had a quick look and there are no types specified for the notifications. If you can update this it would be good - otherwise please raise an issue and I will try and find some time to update it!
http://www.cd-jackson.com/index.php/zwave/zwave-device-database/zwave-device-list/devicesummary/168
@chris i’m still new to using the database, but i guess the process is described properly.
I will try to update it and if not i will raise an issue
Would you provide me with edit access to the database?i have just sent you a request via email.
chris
(Chris Jackson)
June 8, 2016, 10:05am
4
I hope but if you find anything you don’t understand, let me know and I can update…
I’ve just given you access - any problems, let me know…
I have just updated it and submit for review.
I hope i did it correctly
What shall be the next step? how does it later on appear on the next release?
chris
(Chris Jackson)
June 8, 2016, 9:23pm
6
It looks ok.
I will update the binding - hopefully tonight, otherwise tomorrow.
I installed the same sensor, now it work for you?
Yes, now it is configured correctly and working like a charm for few months
Thx,
can you check for me if configurations are same? Will help very much
The device was not initialized because I started OH2 since 1 minute. Temperature and illuminance sometime are coming. Motion and door/close … nothing…
Thank you very much
Hello Igor,
Sorry for the latency i was swamped with stuff for a few days.
Is it working correctly or not? I have a similar configs and it is working fine for me.
