Philips Air Binding improved coap connectivity [4.0.0.0;5.0.0.0)
Philips Air Binding
Binding to support the integration with Philips Air Purifiers including the models based on COAP communication protocol (most >2019 models)
Note may require to (manually) install coap and upnp transport
feature:install openhab-transport-coap
feature:install openhab-transport-upnp
Changelog
2021-11-04 Initial market place version.
2022-12-15 Minor update
2023-09-24 Version bump oh4 - Minor update
2024-01-29 Version bump oh4 - Alpha version with new connectivity approach for Coap based devices
  • Use observeAndWait to keep better connectivity
  • Extra verbose logging (needs to be removed later)
2024-05-05 Version bump oh4 - beta version with new connectivity approach for Coap based devices
Notes:
Philips Air Binding is developed by MichaΕ‚ BoroΕ„ski
(GitHub - michalboronski/openhab-addons: Add-ons for openHAB 2.x
Coap protocol support (this version) contributed by [Marcel Verpaalen] (Profile - marcel_verpaalen - openHAB Community)
Discussion topic in this forum: Binding request: Philips air purifier
Market place topic for 3.x version: Philips Air Binding [3.0.0.0;4.0.0.0)
Alternative installation jar (you must manually install coap and upnp transport): https://verpaalen.com/openhab/org.openhab.binding.philipsair-4.1.2.jar
Resources
https://verpaalen.com/openhab/org.openhab.binding.philipsair-4.1.2.kar
Hey, i got myself an AC0850/11 Air purifier. Unfortunately it seems it uses a different data format but also via COAP and the decryption also works. I might wanna try and add that to the binding but the link to the Github for Version 4.2 is dead. Can you maybe update that? Maybe you just forgot to push that branch. I occasionally see Data from in the logs with that version, the older versions do not seem to work as reliably with my purifier.
Thanks a lot
yes, seems I have missed that.
pushed it now
new version pushed.
I manage to build a .kar version with the latest, but still needed to manually
Hello Marcel
I am a bit blind to find your philips binding latest vers. for OH 4.2. Can you please show me the way.
regards
Wolf
Strange, in the marketplace only the version from last year can be found β€œ2023-09-24 Version bump oh4”.
The links to the new .jar or .kar are not working. Should we use the old version?
Let me check what happened to the links/server.
I think I did something wrong indeed when last time updating the files.
Suggest to use this one https://www.verpaalen.com/openhab/org.openhab.binding.philipsair-4.1.2.jar it is the version I also use in my openhab instance.
If you need different version:
These are the files I have on the server (https://www.verpaalen.com/openhab/ ):
The most up2date version is the .jar And normally when I update I rename the existing .jar to [some number].jar
Feb 26  2021 org.openhab.binding.philipsair-3.1.0-SNAPSHOT.jar
Aug 10  2021 org.openhab.binding.philipsair-3.2.0-SNAPSHOT2.jar
Aug 11  2021 org.openhab.binding.philipsair-3.2.0-SNAPSHOT3.jar
Nov  4  2021 org.openhab.binding.philipsair-3.2.0-SNAPSHOT.jar
Nov  5  2021 org.openhab.binding.philipsair-3.2.0-SNAPSHOT.kar
Dec 17  2022 org.openhab.binding.philipsair-3.4.0-SNAPSHOT.jar
Dec 17  2022 org.openhab.binding.philipsair-3.4.0-SNAPSHOT.kar
Dec 17  2022 org.openhab.binding.philipsair-3.4.0-SNAPSHOT-sources.jar
Sep 24  2023 org.openhab.binding.philipsair-4.0.4-SNAPSHOT.jar
Sep 24  2023 org.openhab.binding.philipsair-4.0.4-SNAPSHOT.kar
Sep 24  2023 org.openhab.binding.philipsair-4.0.4-SNAPSHOT-sources.jar
Sep 24  2023 org.openhab.binding.philipsair-4.1.0-SNAPSHOT1.kar
Sep 24  2023 org.openhab.binding.philipsair-4.1.0-SNAPSHOT.jar
Sep 24  2023 org.openhab.binding.philipsair-4.1.0-SNAPSHOT.kar
Sep 24  2023 org.openhab.binding.philipsair-4.1.0-SNAPSHOT-sources.jar
May  6 16:13 org.openhab.binding.philipsair-4.1.2.jar
May  6 16:13 org.openhab.binding.philipsair-4.1.2.kar
May  6 16:13 org.openhab.binding.philipsair-4.1.2-sources.jar
Jan 14  2024 org.openhab.binding.philipsair-4.2.0-SNAPSHOT1.jar
Jan 30 00:25 org.openhab.binding.philipsair-4.2.0-SNAPSHOT2.jar
Jan 30 00:26 org.openhab.binding.philipsair-4.2.0-SNAPSHOT.kar
Jan 30 00:25 org.openhab.binding.philipsair-4.2.0-SNAPSHOT-sources.jar
Jun 10  2021 org.openhab.binding.philipsairC2-3.1.0-SNAPSHOT.jar
Apr  6  2021 org.openhab.binding.philipsairC-3.1.0-SNAPSHOT.jar
Thanks for the quick fix :+1:
Hi Marcel,
fist of all thank you for you work maintaining this binding.
Since my device is not discovered with the marketplace version, I tried installing the 4.1.2 Version manually.
Sady I run into this error message:
2024-09-10 17:33:36.252 [ERROR] [Events.Framework                    ] - FrameworkEvent ERROR
org.osgi.framework.BundleException: Could not resolve module: org.openhab.binding.philipsair [337]
  Unresolved requirement: Import-Package: com.google.gson; version="[2.10.0,3.0.0)"
	at org.eclipse.osgi.container.Module.start(Module.java:463) ~[org.eclipse.osgi-3.18.0.jar:?]
	at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel$2.run(ModuleContainer.java:1847) ~[org.eclipse.osgi-3.18.0.jar:?]
	at org.eclipse.osgi.internal.framework.EquinoxContainerAdaptor$1$1.execute(EquinoxContainerAdaptor.java:136) ~[org.eclipse.osgi-3.18.0.jar:?]
	at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1840) ~[org.eclipse.osgi-3.18.0.jar:?]
	at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1783) ~[org.eclipse.osgi-3.18.0.jar:?]
	at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.doContainerStartLevel(ModuleContainer.java:1745) ~[org.eclipse.osgi-3.18.0.jar:?]
	at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1667) ~[org.eclipse.osgi-3.18.0.jar:?]
	at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1) ~[org.eclipse.osgi-3.18.0.jar:?]
	at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:234) ~[org.eclipse.osgi-3.18.0.jar:?]
	at org.eclipse.osgi.framework.eventmgr.EventManager$EventThread.run(EventManager.java:345) ~[org.eclipse.osgi-3.18.0.jar:?]
2024-09-10 17:33:37.194 [WARN ] [org.apache.felix.fileinstall        ] - Error while starting bundle: file:/usr/share/openhab/addons/org.openhab.binding.philipsair-4.1.2.jar
	at org.eclipse.osgi.internal.framework.EquinoxBundle.start(EquinoxBundle.java:445) ~[org.eclipse.osgi-3.18.0.jar:?]
	at org.apache.felix.fileinstall.internal.DirectoryWatcher.startBundle(DirectoryWatcher.java:1260) ~[?:?]
	at org.apache.felix.fileinstall.internal.DirectoryWatcher.startBundles(DirectoryWatcher.java:1233) ~[?:?]
	at org.apache.felix.fileinstall.internal.DirectoryWatcher.startAllBundles(DirectoryWatcher.java:1221) ~[?:?]
	at org.apache.felix.fileinstall.internal.DirectoryWatcher.doProcess(DirectoryWatcher.java:515) ~[?:?]
	at org.apache.felix.fileinstall.internal.DirectoryWatcher.process(DirectoryWatcher.java:365) ~[?:?]
	at org.apache.felix.fileinstall.internal.DirectoryWatcher.run(DirectoryWatcher.java:316) ~[?:?]
Do you have any clue how to fix it?
Thank you
Martijn
What version openhab are you running
Hi Marcel,
thank you for the hint, I got rid of this error with an update to 4.2.1.
When installing the marketplace version, it still lists 4.0.4 in the sources.
I installed the Package with
bundle:install https://www.verpaalen.com/openhab/org.openhab.binding.philipsair-4.1.2.jar
Now I have the 4.1.2 version, clean logs and can also see some COAP activity on DEBUG.
Last thing I’m missing, is seeing the manually installed binding in the UI to create things with it. But I will search some more regarding that.
I just wanted to give an update/feedback that it the initial problem is gone.
I just installed openHAB 5.0.0. and I am getting an error on the Philips AirPurifier
Thing:
Status: UNINITIALIZED
HANDLER_MISSING_ERROR
Handler factory not found
In Karaf I get the following error when I try to start the bundle:
openhab> bundle:list | grep Philips
247 β”‚ Installed β”‚ 80 β”‚ 4.1.2 β”‚ openHAB Add-ons :: Bundles :: Philips Air Purifier Binding
openhab> bundle:start 247
Error executing command: Error executing command on bundles:
Error starting bundle 247: Could not resolve module: org.openhab.binding.philipsair [247]
Unresolved requirement: Import-Package: org.eclipse.californium.core; version=β€œ[2.7.0,3.0.0)”
Is there a way to fix this, or is a new version of the binding necessary?
Did you try the feature:install openhab-transport-coap?
If yes, and the issue is still there I’m afraid it needs a recompile of the module for r5
It did work on the 4.3.2 version.
The coap features seem to have been updated fine to 5.0.0
openhab> feature:list | grep coap
openhab-core-io-transport-coap β”‚ 5.0.0 β”‚ β”‚ Started β”‚ distro-5.0.0 β”‚
openhab-transport-coap β”‚ 5.0.0 β”‚ x β”‚ Started β”‚ distro-5.0.0 β”‚ CoAP Transport
openhab.tp-coap β”‚ 5.0.0 β”‚ β”‚ Started β”‚ distro-5.0.0 β”‚ Californium CoAP library
I did install you 4.1.2 version thru the bundle install command since the 4.2.0 from the community marketplace did not work.
At the moment no version is available in the community marketplace.
Any chance you will make a new version available?
Kind regards…
You can try this:
Note: I’m on holidays, can’t test this at the moment. Let me know if this works
https://verpaalen.com/openhab/org.openhab.binding.philipsair-5.1.0-SNAPSHOT.jar
Seems the bundle can’t be installed:
openhab> bundle:install https://verpaalen.com/openhab/org.openhab.binding.philipsair-5.1.0-SNAPSHOT.jar
Bundle IDs:
Error executing command: Error installing bundles:
Unable to install bundle https://verpaalen.com/openhab/org.openhab.binding.philipsair-5.1.0-SNAPSHOT.jar: org.osgi.framework.BundleException: Error reading bundle content.
Also when i go to your domain i get:
Could it be there is an issue with this domain?
Anyway, first things first, enjoy your holliday :slight_smile:
Ah, Yes, seems so. Im about to change to a new hosting provider.
Seems the old one stopped already.
Will upload to the new site shortly.
you should be able to download the file now.
there may be some disruptions in the next few days as I still need to organise the new server. But the link will be the same
Hi, still not working:
