Yesterday initially installed the binding. Works well, thank you! It is a 55pus7272
Is it possible to to keep the TV online after power off?
The thing goes offline after a while.
I see that a lot of people have the same problem as me:
After a power off the TV it will not recognized by the binding after long time.
I think i found the solution, well sombody els found it and I found his reddit post
Because alot of new TVâs goes in deep sleep mode,
I installed the app: X-Plore from the play store.
Wakelock is on Play store, but not compatible with Android TV. So you need X-Plore to install it
I download Wakelockv3 to a USB and installed with X-Plore
as it seems to be setup as system app, not directly supporting Android TV, you wont find it in installed apps. Found workaround how to run it, go to:
*Settings â Android settings â Device preferences â Storage â Internal storage â Apps â See all apps â scroll to bottom System apps â scroll down to Wakelock v3 and click â Open. (you also can open it after install)
Click on the processor and the wifi normal button, They will be yellow now,
Just close the app. After this my binding always respons within 10 seconds even after a night.
My apps are also reading so the binding know which app is running, Only Kodi does not response somethimes and stuck on the app before. maybe this app reading is fixed by my last software update of the TV
Can you please compile the jar archive version 3.3.0 for API 5 ?
With the current API 5 version ( org.openhab.binding.philipstv-3.1.0-SNAPSHOT-EXPERIMENTAL.jar) I have the following problem: once I do the binding between the TV set and the OH3 binding, the TV is disconnected and I always have to redo the pairing procedure (erase PIN username password, save, restart binding, reenter the new PIN code).
Struggling to get my 65OLED806 to show up in Inbox.
Iâm wondering if Iâm missing something, the binding is installed properly as far as I can tell:
openhab> bundle:list
âŚ
270 â Active â 80 â 3.3.0.202112261447 â openHAB Add-ons :: Bundles :: Philips TV Binding
Running openhab 3.1.0 using the docker container with --net=host and no firewall on that interface.
What exactly is the mechanism behind the TV âshowing up in inboxâ? Iâve tried sniffing the network for messages from my (fixed IP) TV but itâs not talking/broadcasting much. It does show up as a device I can cast to from my Android phone.
Or is there some feature I have to enable on the TV somewhere?
Nevermind, PEBKAC error here. Apparently the local firewall was not completely disabled. Figured it out by sniffing what the philips android app was doing, my openhab box was still filtering incoming UDP packets sent to 239.255.255.250:1900.
For the record, if the TV is in deep sleep it wonât wake up.
I worked around it by configuring a pingdevice item with the MAC of the TV added to it. When I want to switch the TV on, OH now sends a WOL packet if itâs down and a few secs later the philipstv binding can turn it on just fine.
KeyCode, AppName, searchContent for switching HDMI etc. all work perfectly. You can add 65OLED806/12 to your supported list. Thanks!
Bought a Philips 55PUS8106/12 yesterday and the binding is unable to display a pairing code.
The Android App: Android TV Remote from NIAMORDEV was able to connect though, after deleting the data from the TVâs Android TV Remote Service App.
See https://play.google.com/store/apps/details?id=dev.niamor.androidtvremote&hl=en&gl=US
After that the App made the TV show the now 6 digit pairing code:
Using this code in the binding setting (long shot I know) showed this log:
2022-07-03 14:57:12.678 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'philipstv:tv:47c85c589d' changed from ONLINE (CONFIGURATION_PENDING): Pairing Code is available, but credentials missing. Trying to retrieve them. to OFFLINE (HANDLER_INITIALIZING_ERROR): Could not successfully finish pairing process with the TV. 2022-07-03 14:57:12.683 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'philipstv:tv:47c85c589d' changed from OFFLINE (HANDLER_INITIALIZING_ERROR): Could not successfully finish pairing process with the TV. to OFFLINE (CONFIGURATION_ERROR): Error occurred during retrieval of credentials.
Maybe a WireShark trace will reveal more, but probably quite a bit of work.
Whish some consumer organization made it mandatory to supply the API doc.
Could we not request the source code since they are using openSource code in the TV?
Sorry to insist but I try to track when the tv is turned off but every two weeks I got this message:
[tv.internal.handler.PhilipsTvHandler] - Pairing code is available, but username and/or password is missing. Therefore we try to grant authorization and retrieve username and password.
And the reason is the reference of the TV (for instance F00DBABE-AA5E-BABA-DADA-00000000F8C8) is not longer valid.
I unfortunately have the same problem after a while I can no longer send commands to the TV.
Does anyone have an idea?
The only thing that works is to deactivate the plugin briefly wait and then activate it again. Then it takes about 1 minute and the sending of commands works again.
In the log I find the following errors.
2022-07-26 15:32:17.705 [WARN ] [lipstv.internal.service.PowerService] - Unexpected Error handling the PowerState command REFRESH for Channel power: Read timed out
2022-07-26 15:32:39.649 [WARN ] [tv.internal.service.AmbilightService] - Error during handling the Ambilight command OFF for Channel ambilightPower: Read timed out
java.net.SocketTimeoutException: Read timed out
at java.net.SocketInputStream.socketRead0(Native Method) ~[?:?]
at java.net.SocketInputStream.socketRead(SocketInputStream.java:115) ~[?:?]
at java.net.SocketInputStream.read(SocketInputStream.java:168) ~[?:?]
at java.net.SocketInputStream.read(SocketInputStream.java:140) ~[?:?]
at sun.security.ssl.SSLSocketInputRecord.read(SSLSocketInputRecord.java:478) ~[?:?]
at sun.security.ssl.SSLSocketInputRecord.readHeader(SSLSocketInputRecord.java:472) ~[?:?]
at sun.security.ssl.SSLSocketInputRecord.bytesInCompletePacket(SSLSocketInputRecord.java:70) ~[?:?]
at sun.security.ssl.SSLSocketImpl.readApplicationRecord(SSLSocketImpl.java:1454) ~[?:?]
at sun.security.ssl.SSLSocketImpl$AppInputStream.read(SSLSocketImpl.java:1065) ~[?:?]
at org.apache.http.impl.io.SessionInputBufferImpl.streamRead(SessionInputBufferImpl.java:137) ~[bundleFile:?]
at org.apache.http.impl.io.SessionInputBufferImpl.fillBuffer(SessionInputBufferImpl.java:153) ~[bundleFile:?]
at org.apache.http.impl.io.SessionInputBufferImpl.readLine(SessionInputBufferImpl.java:280) ~[bundleFile:?]
at org.apache.http.impl.conn.DefaultHttpResponseParser.parseHead(DefaultHttpResponseParser.java:140) ~[bundleFile:?]
at org.apache.http.impl.conn.DefaultHttpResponseParser.parseHead(DefaultHttpResponseParser.java:57) ~[bundleFile:?]
at org.apache.http.impl.io.AbstractMessageParser.parse(AbstractMessageParser.java:259) ~[bundleFile:?]
at org.apache.http.impl.DefaultBHttpClientConnection.receiveResponseHeader(DefaultBHttpClientConnection.java:163) ~[bundleFile:?]
at org.apache.http.impl.conn.CPoolProxy.receiveResponseHeader(CPoolProxy.java:167) ~[bundleFile:?]
at org.apache.http.protocol.HttpRequestExecutor.doReceiveResponse(HttpRequestExecutor.java:273) ~[bundleFile:?]
at org.apache.http.protocol.HttpRequestExecutor.execute(HttpRequestExecutor.java:125) ~[bundleFile:?]
at org.apache.http.impl.execchain.MainClientExec.execute(MainClientExec.java:271) ~[bundleFile:?]
at org.apache.http.impl.execchain.ProtocolExec.execute(ProtocolExec.java:184) ~[bundleFile:?]
at org.apache.http.impl.execchain.RetryExec.execute(RetryExec.java:88) ~[bundleFile:?]
at org.apache.http.impl.execchain.RedirectExec.execute(RedirectExec.java:110) ~[bundleFile:?]
at org.apache.http.impl.client.InternalHttpClient.doExecute(InternalHttpClient.java:184) ~[bundleFile:?]
at org.apache.http.impl.client.CloseableHttpClient.execute(CloseableHttpClient.java:117) ~[bundleFile:?]
at org.openhab.binding.philipstv.internal.ConnectionManager.doHttpsPost(ConnectionManager.java:82) ~[bundleFile:?]
at org.openhab.binding.philipstv.internal.service.AmbilightService.setAmbilightPowerState(AmbilightService.java:164) ~[bundleFile:?]
at org.openhab.binding.philipstv.internal.service.AmbilightService.handleCommand(AmbilightService.java:112) [bundleFile:?]
at org.openhab.binding.philipstv.internal.handler.PhilipsTvHandler.handleCommand(PhilipsTvHandler.java:175) [bundleFile:?]
at jdk.internal.reflect.GeneratedMethodAccessor69.invoke(Unknown Source) ~[?:?]
at java.lang.reflect.Method.invoke(Method.java:566) ~[?:?]
at org.openhab.core.internal.common.AbstractInvocationHandler.invokeDirect(AbstractInvocationHandler.java:154) [bundleFile:?]
at org.openhab.core.internal.common.InvocationHandlerSync.invoke(InvocationHandlerSync.java:59) [bundleFile:?]
at com.sun.proxy.$Proxy2388.handleCommand(Unknown Source) [?:?]
at org.openhab.core.thing.internal.profiles.ProfileCallbackImpl.handleCommand(ProfileCallbackImpl.java:80) [bundleFile:?]
at org.openhab.core.thing.internal.profiles.SystemDefaultProfile.onCommandFromItem(SystemDefaultProfile.java:48) [bundleFile:?]
at jdk.internal.reflect.GeneratedMethodAccessor68.invoke(Unknown Source) ~[?:?]
at org.openhab.core.internal.common.Invocation.call(Invocation.java:52) [bundleFile:?]
Hello @ all!
First of all, thank you very much for this great binding!!
I installed it today and it seems to work fine. When I turn the TV on I get the following message in the log:
âThing âphilipstv:tv:F00DBABE_AA5E_BABA_DADA_0ccafb0a3b9eâ changed from ONLINE: Standby to ONLINEâ
and otherwise, when I am turning off the TV I get this message in the log:
âThing âphilipstv:tv:F00DBABE_AA5E_BABA_DADA_0ccafb0a3b9eâ changed from ONLINE to ONLINE: Standbyâ
Now I simply want to find out however the TV is in ONLINE or in STANBY modeâŚ
I tried different thing but I can only get the Thing-Status âONLINEâ or âOFFLINEâ.
I read the following statement in the description of the binding:
"* Thing state ONLINE with Message âStandbyâ: TV is off and network card is awake and receives commands
But I can't evaluate the "message" fromt the Thing state. I can see this message in the log but I want to use it in a rule.
How can I synchronize a switch or any other variable with the "Standby" Mode of the TV?
For example I tried a rule like this:
rule "TV Wohnzimmer Test"
Thing "philipstv:tv:F00DBABE_AA5E_BABA_DADA_0ccafb0a3b9e" changed to ONLINE
var ThingStatusInfo = getThingStatusInfo("philipstv:tv:F00DBABE_AA5E_BABA_DADA_0ccafb0a3b9e")
logInfo("TV Status change", ThingStatusInfo.getStatusDetail().toString())
In this case I get the follwoing 2 lines in the Log:
2022-08-15 17:03:44.273 [INFO ] [b.core.model.script.TV Status change] - NONE
2022-08-15 17:03:44.277 [INFO ] [core.model.script.TV Status change 2] - ONLINE
But I need the info "Standby" :frowning:
Can someone help me?
Regards
Joe
Maybe one can help me out. In the post I am replying to Mihai is controlling Ambilight brightness via cURL. I am trying to switch off the screen (not turning off the TV) via an OpenHab switch. Regularly the TVâs settop box is just playing radio and in these energy costly times, it is nonsense to leave on the screen as it consumes quite some energy even when black (but on).
I found out on my TV that settings nodeid 2131230820 is for âScreen Offâ. However, how do I control it. The JSON is not showing any data (and as such I am unable to retrieve what the status of the screen is).
Some items (node_idâs) in the list have a type âSLIDER_NOTEâ, just like in the above post and you can send a value to the âdataâ to update it. But, when no data is displayed whether the screen is on or off, I have no clue how to toggle this item. I have tried to send values as false, true, on, off, but all to no avail.
I have some slight Problems with my TV and this plugin. After completing the pairing process, I can create new items (e.g. volume) and everything syncs between TV and openhab. (With a slight delay).Everything is fine until I switch of the TV. (Going to Standby). Then the plugin shows the TV as offline. And it never comes back online. Gone until I remove the TV thing and complete the pairing process a second time. Then it works again, until standby. The log is not very helpful:
[INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'philipstv:tv:6c60746257' changed from ONLINE to OFFLINE: TV is not reachable and should therefore be off.
The openhab.log only says:
[INFO ] [tv.internal.handler.PhilipsTvHandler] - Stopping Refresh Scheduler for Philips TV: Philips TV
Thank you so much! I had a look at the issues of pylips, but now I notice that one is shown the open issues by default. There are so many more closed issuesâŚ
Will try to figure this out how to implement this in a rule the coming days, without having to install pylips⌠again many many thanks for pointing me to the right info.
Edit:
Just found out that the binding has the AppName channel from which the Setup menu is also selectable (never knew this OH function, accidentily activated when trying to copy and paste). So first send a command to the AppName channel and then sending commands to the keyCode channel for navigating to the right item and activating itâŚ
Might be an even easier way, but this solution already works
Follow-Up to my problem: Multicast was not working properly. I deployed OpenHAB as a docker container on raspbian. I started the container with --net=host and everything works fine.
Well⌠here we go again. It broke over night. TV-Thing stays offline. Multicast is now working properly though. With a slight improvement: The TV now appears in the inbox again. This is probably because the identifier changed. Why does it do that?
