1 - 3: → Done
4: Discovery → OK
5: Pin process → OK
6: Thing Online / Power ON/OFF / Switch Apps / Mute / Ambilight ON/OFF → OK
7: Thing is in status " HANDLER_INITIALIZING_ERROR". These are the errors I get:
2023-08-26 15:29:54.304 [ERROR] [st.core.internal.thing.ThingResource] - Exception during HTTP PUT request for update config at 'things/androidtv:philipstv:F00DBABE_AA5E_BABA_DADA_70af241424b4/config'
2023-08-26 15:30:12.899 [ERROR] [nal.common.AbstractInvocationHandler] - An error occurred while calling method 'ThingHandler.initialize()' on 'org.openhab.binding.androidtv.internal.AndroidTVHandler@100baad': null
2023-08-26 15:30:12.905 [ERROR] [core.thing.internal.ThingManagerImpl] - Exception occurred while initializing handler of thing 'androidtv:philipstv:F00DBABE_AA5E_BABA_DADA_70af241424b4': null
Full Log Enable GoogleTV:
openhab.log (19.7 KB)
Of course pin process for GTV does not work when Thing is in status “UNINITIALIZED” / " HANDLER_INITIALIZING_ERROR". Also no googletv keystore file in the androidtv folder.
These commands work with channel KeyPress now:
https://jointspace.sourceforge.net/projectdata/documentation/jasonApi/1/doc/API-Method-input-key-POST.html
KeyCode does not have any functionality anymore in PTV, correct?
I would love to know if Keyboard and Search Content do the same thing or not. I haven’t had any exposure to that.
These are GTV commands? Or should both work for PTV as well? I have never used these channels.
Update1: I think it is not the same. Search Content is to activate Google Assistance. Instead of pressing a button on Remote Control and speak, I can send a String Command to this Channel:
- Toggle Google Assistant on TV for a given Input (e.g. “HDMI1” switches to HDMI1 or search for content)
For Keyboard I could not see any functionality. This is most probably GTV protocol?
