Unfortunately not. It’s an older HomeCinema from Samsung.
Test ongoing
Test ongoing
That stinks. I’m not sure if that’s something we can/should resolve as part of this binding since it’s related to another system.
No, I don’t think so. And it is possible to control the volume with a stepper item (screenshot above). For me this is OK.
No error with latest jar anymore. And overall I have to say everything is working!
Only small thing: Maybe you remenber the flipping power channel. It looks like we still have this. Most probably it depends on the refresh rate. I have recorded a video:
https://www.swisstransfer.com/d/5643ffec-990d-4882-8b4b-6faae9d522dc
We see when I switch on the power channel, that WOL works (Power goes up to about 9W). Then Power Channel goes OFF and a bit later ON again. Finally TV is ON (80 W). Maybe you can find the reason and improve more?
Awesome! Very glad to hear, probably going to drop this into the marketplace shortly.
Does this only happen when waking up with a WOL or does this happen even if the TV is reachable? I think we may be having an issue where the protocols are waking up from the TV being reachable and setting some odd values. Can you get me a trace log to show that happening so I can follow both protocols?
It only happens with WOL. Last time it even did not power ON the TV: ON → WOL → OFF
This is a trace where WOL did work, but TV did not turn ON:
WOL_OK_TV_notON.log (73.5 KB)
I try to do another one when TV is turning on.
Voilà. This is a trace where evyrthing did work as expected: ON → WOL → TV ON (without flipping to OFF in between):
WOL_OK_TV_OK.log (184.5 KB)
I looked through the logs. Something weird happened with the WOL. It’s like the TV took forever to come back alive.
WOL_OK_TV_notON:
2023-08-28 20:54:34.732 [TRACE] [.androidtv.internal.AndroidTVHandler] - F00DBABE_AA5E_BABA_DADA_70af241424b4 - Command received at handler: power ON
2023-08-28 20:54:34.733 [DEBUG] [philipstv.PhilipsTVConnectionManager] - Received channel: androidtv:philipstv:F00DBABE_AA5E_BABA_DADA_70af241424b4:power, command: ON
2023-08-28 20:54:36.836 [DEBUG] [nal.protocol.philipstv.WakeOnLanUtil] - WOL sent to Broadcast-IP /192.168.1.255 with MAC 70:AF:24:14:24:B4
2023-08-28 20:54:44.400 [DEBUG] [tocol.philipstv.service.PowerService] - PowerState Json sent: {"powerstate":"On"}
2023-08-28 20:54:51.036 [TRACE] [philipstv.PhilipsTVConnectionManager] - postUpdateThing OFFLINE NONE TV is not reachable and should therefore be off.
2023-08-28 20:54:51.037 [TRACE] [philipstv.PhilipsTVConnectionManager] - Updating status to OFFLINE NONE TV is not reachable and should therefore be off.
2023-08-28 20:54:51.037 [TRACE] [nternal.AndroidTVTranslationProvider] - Failed to translate: TV is not reachable and should therefore be off.
2023-08-28 20:54:51.038 [TRACE] [philipstv.PhilipsTVConnectionManager] - setStatus to false TV is not reachable and should therefore be off. TV is not reachable and should therefore be off.
2023-08-28 20:54:52.034 [DEBUG] [philipstv.PhilipsTVConnectionManager] - F00DBABE_AA5E_BABA_DADA_70af241424b4 - Device Health - Online: false - Logged In: false
2023-08-28 20:54:56.023 [DEBUG] [l.googletv.GoogleTVConnectionManager] - F00DBABE_AA5E_BABA_DADA_70af241424b4 - Device Health - Online: true - Logged In: false - Mode: NORMAL
2023-08-28 20:54:56.023 [DEBUG] [l.googletv.GoogleTVConnectionManager] - F00DBABE_AA5E_BABA_DADA_70af241424b4 - Device is back online. Attempting reconnection.
2023-08-28 20:54:56.091 [INFO ] [tocol.googletv.GoogleTVMessageParser] - F00DBABE_AA5E_BABA_DADA_70af241424b4 - Login Successful
2023-08-28 20:54:56.156 [DEBUG] [l.googletv.GoogleTVConnectionManager] - F00DBABE_AA5E_BABA_DADA_70af241424b4 - Setting power to false
2023-08-28 20:54:57.036 [DEBUG] [philipstv.PhilipsTVConnectionManager] - F00DBABE_AA5E_BABA_DADA_70af241424b4 - Device Health - Online: true - Logged In: false
2023-08-28 20:54:57.036 [DEBUG] [philipstv.PhilipsTVConnectionManager] - F00DBABE_AA5E_BABA_DADA_70af241424b4 - Device is back online. Attempting reconnection.
2023-08-28 20:54:57.104 [TRACE] [philipstv.PhilipsTVConnectionManager] - postUpdateThing ONLINE NONE online.online
2023-08-28 20:54:57.107 [TRACE] [nternal.AndroidTVTranslationProvider] - Translated: online.online as Online
2023-08-28 20:54:57.108 [TRACE] [philipstv.PhilipsTVConnectionManager] - setStatus to true online.online Online
2023-08-28 20:54:57.266 [DEBUG] [protocol.philipstv.ConnectionManager] - {"powerstate":"StandbyKeep"}
2023-08-28 20:54:57.267 [TRACE] [philipstv.PhilipsTVConnectionManager] - postUpdateThing OFFLINE NONE
2023-08-28 20:54:57.270 [TRACE] [philipstv.PhilipsTVConnectionManager] - Updating status to OFFLINE NONE
2023-08-28 20:54:57.271 [TRACE] [nternal.AndroidTVTranslationProvider] - Failed to translate:
2023-08-28 20:54:57.271 [TRACE] [philipstv.PhilipsTVConnectionManager] - setStatus to false
2023-08-28 20:55:02.273 [DEBUG] [philipstv.PhilipsTVConnectionManager] - F00DBABE_AA5E_BABA_DADA_70af241424b4 - Device Health - Online: true - Logged In: false
WOL_OK_TV_OK:
2023-08-28 20:58:36.542 [TRACE] [.androidtv.internal.AndroidTVHandler] - F00DBABE_AA5E_BABA_DADA_70af241424b4 - Command received at handler: power ON
2023-08-28 20:58:36.544 [DEBUG] [philipstv.PhilipsTVConnectionManager] - Received channel: androidtv:philipstv:F00DBABE_AA5E_BABA_DADA_70af241424b4:power, command: ON
2023-08-28 20:58:38.649 [DEBUG] [nal.protocol.philipstv.WakeOnLanUtil] - WOL sent to Broadcast-IP /192.168.1.255 with MAC 70:AF:24:14:24:B4
2023-08-28 20:58:46.830 [DEBUG] [philipstv.PhilipsTVConnectionManager] - F00DBABE_AA5E_BABA_DADA_70af241424b4 - Device Health - Online: true - Logged In: false
2023-08-28 20:58:46.830 [DEBUG] [philipstv.PhilipsTVConnectionManager] - F00DBABE_AA5E_BABA_DADA_70af241424b4 - Device is back online. Attempting reconnection.
2023-08-28 20:58:46.883 [TRACE] [philipstv.PhilipsTVConnectionManager] - postUpdateThing ONLINE NONE online.online
2023-08-28 20:58:46.886 [TRACE] [nternal.AndroidTVTranslationProvider] - Translated: online.online as Online
2023-08-28 20:58:46.887 [TRACE] [philipstv.PhilipsTVConnectionManager] - setStatus to true online.online Online
2023-08-28 20:58:47.272 [DEBUG] [tocol.philipstv.service.PowerService] - PowerState Json sent: {"powerstate":"On"}
2023-08-28 20:58:47.376 [DEBUG] [protocol.philipstv.ConnectionManager] - {"powerstate":"StandbyKeep"}
2023-08-28 20:58:47.376 [TRACE] [philipstv.PhilipsTVConnectionManager] - postUpdateThing OFFLINE NONE
2023-08-28 20:58:47.382 [TRACE] [philipstv.PhilipsTVConnectionManager] - Updating status to OFFLINE NONE
2023-08-28 20:58:47.383 [TRACE] [nternal.AndroidTVTranslationProvider] - Failed to translate:
2023-08-28 20:58:47.383 [TRACE] [philipstv.PhilipsTVConnectionManager] - setStatus to false
2023-08-28 20:58:47.464 [TRACE] [philipstv.PhilipsTVConnectionManager] - postUpdateThing ONLINE NONE online.online
2023-08-28 20:58:47.470 [TRACE] [nternal.AndroidTVTranslationProvider] - Translated: online.online as Online
2023-08-28 20:58:47.471 [TRACE] [philipstv.PhilipsTVConnectionManager] - setStatus to true online.online Online
2023-08-28 20:58:48.063 [DEBUG] [l.googletv.GoogleTVConnectionManager] - F00DBABE_AA5E_BABA_DADA_70af241424b4 - Device Health - Online: true - Logged In: false - Mode: NORMAL
2023-08-28 20:58:48.063 [DEBUG] [l.googletv.GoogleTVConnectionManager] - F00DBABE_AA5E_BABA_DADA_70af241424b4 - Device is back online. Attempting reconnection.
2023-08-28 20:58:52.385 [DEBUG] [philipstv.PhilipsTVConnectionManager] - F00DBABE_AA5E_BABA_DADA_70af241424b4 - Device Health - Online: true - Logged In: true
2023-08-28 20:58:53.096 [INFO ] [tocol.googletv.GoogleTVMessageParser] - F00DBABE_AA5E_BABA_DADA_70af241424b4 - Login Successful
2023-08-28 20:58:53.197 [DEBUG] [l.googletv.GoogleTVConnectionManager] - F00DBABE_AA5E_BABA_DADA_70af241424b4 - Setting power to true
Notice the different order of operations that happened between the two (be careful to see Philips vs Google in the message). First, I’ve not seen “StandbyKeep” anywhere in the code so far. It’s always been “On” “Off” or “Standby”. So that’s causing some issues there because it knocks the thing offline due to an unknown power state. Second, on the one that failed it looks like the binding didn’t wait long enough to send the On. Notice it sends the On almost exactly 10 seconds after the command is sent to the handler. The thing hadn’t come online yet at that point (it took almost 25 seconds from command to online). In the one that was successful the handler came online in about 10 seconds and the command was sent promptly. I’m wondering if we should hold sending the power on until we get “StandbyKeep” and use that as a trigger. Also notice, GTV logged in first and then PTV. You can see GTV set the power states on each at some point. I think that’s what caused the power state to flip back and forth.
Part of this is because of the way we’re doing health monitoring. Every 5 seconds we poll the device to see if we can make a tcp connection onto the port. The theory is, if we can’t even open a tcp connection then the protocols definitely won’t be able to hook. I’m thinking that we can adjust that to maybe 1 second the moment a power-on command is sent so we keep a closer eye on it.
For anyone watching this, I’ve officially pushed the most recent jar to the AndroidTV marketplace posting. While I’m sure I’ll have some interim test builds, I’ll be doing the more stable ones to there going forward until this is merged into the OH repo.
@morph166955 I have done another test with WOL from network binding and without sending power on command to TV. Just to watch the status of the thing when TV goes out of deep sleep mode.
Enable GoogleTV = ON:
var wolAction = actions.Things.getActions("network","network:pingdevice:881e749a1e");
wolAction.sendWakeOnLanPacketViaMac();
Trace:
WOL_OK_Thing_Offline_GTVProtON.log (144.2 KB)
2nd test with Enable GoogleTV = OFF:
TV wakes up immediately (~8W)
Thing status does not go Online. The status stays somehow in:
Disable/Enable Thing and status was immediately ONLINE
Trace:
WOL_OK_Thing_Offline_GTVProtOFF_DisableEnableThing.log (223.9 KB)
Maybe it helps to find the WOL issue we have.
Yup, exactly what I was expecting to see. The health monitor definitely saw you do the WOL and is firing off the connection when the port opens. It’s this “StandbyKeep” state. Not sure where that came from but it’s throwing the protocol from online to offline inside of a split second. I think if you were to send a power on once GTV comes up it would power up as expected and the thing would come online.
Everything looks fine from what I can see other than that. I think if I can tune up some of the timers and add StandbyKeep it should clean this up. I have a few ideas, just haven’t had the time to do the code yet. Maybe this afternoon, been a busy week.
2023-08-30 06:22:47.701 [DEBUG] [philipstv.PhilipsTVConnectionManager] - F00DBABE_AA5E_BABA_DADA_70af241424b4 - Device Health - Online: false - Logged In: false
2023-08-30 06:22:50.178 [DEBUG] [l.googletv.GoogleTVConnectionManager] - F00DBABE_AA5E_BABA_DADA_70af241424b4 - Device Health - Online: false - Logged In: false - Mode: NORMAL
2023-08-30 06:22:53.126 [DEBUG] [philipstv.PhilipsTVConnectionManager] - F00DBABE_AA5E_BABA_DADA_70af241424b4 - Device Health - Online: true - Logged In: false
2023-08-30 06:22:53.126 [DEBUG] [philipstv.PhilipsTVConnectionManager] - F00DBABE_AA5E_BABA_DADA_70af241424b4 - Device is back online. Attempting reconnection.
2023-08-30 06:22:53.197 [TRACE] [philipstv.PhilipsTVConnectionManager] - postUpdateThing ONLINE NONE online.online
2023-08-30 06:22:53.198 [DEBUG] [philipstv.PhilipsTVConnectionManager] - Refresh Scheduler already started for Philips TV F00DBABE_AA5E_BABA_DADA_70af241424b4, terminating.
2023-08-30 06:22:53.200 [DEBUG] [philipstv.PhilipsTVConnectionManager] - Starting Refresh Scheduler for Philips TV F00DBABE_AA5E_BABA_DADA_70af241424b4 with refresh rate of 10.
2023-08-30 06:22:53.201 [TRACE] [nternal.AndroidTVTranslationProvider] - Translated: online.online as Online
2023-08-30 06:22:53.202 [TRACE] [philipstv.PhilipsTVConnectionManager] - setStatus to true online.online Online
2023-08-30 06:22:53.203 [DEBUG] [protocol.philipstv.ConnectionManager] - Target Uri is: https://192.168.1.57:1926/6/powerstate
2023-08-30 06:22:53.738 [DEBUG] [protocol.philipstv.ConnectionManager] - ----------------------------------------
2023-08-30 06:22:53.739 [DEBUG] [protocol.philipstv.ConnectionManager] - HTTP/1.1 200 OK
2023-08-30 06:22:53.739 [DEBUG] [protocol.philipstv.ConnectionManager] - {"powerstate":"StandbyKeep"}
2023-08-30 06:22:53.740 [TRACE] [philipstv.PhilipsTVConnectionManager] - postUpdateThing OFFLINE NONE
2023-08-30 06:22:53.740 [DEBUG] [philipstv.PhilipsTVConnectionManager] - Stopping Refresh Scheduler for Philips TV: F00DBABE_AA5E_BABA_DADA_70af241424b4
2023-08-30 06:22:53.741 [TRACE] [philipstv.PhilipsTVConnectionManager] - Updating status to OFFLINE NONE
2023-08-30 06:22:53.743 [TRACE] [nternal.AndroidTVTranslationProvider] - Failed to translate:
2023-08-30 06:22:53.743 [TRACE] [philipstv.PhilipsTVConnectionManager] - setStatus to false
2023-08-30 06:22:55.181 [DEBUG] [l.googletv.GoogleTVConnectionManager] - F00DBABE_AA5E_BABA_DADA_70af241424b4 - Device Health - Online: true - Logged In: false - Mode: NORMAL
2023-08-30 06:22:55.182 [DEBUG] [l.googletv.GoogleTVConnectionManager] - F00DBABE_AA5E_BABA_DADA_70af241424b4 - Device is back online. Attempting reconnection.
2023-08-30 06:22:55.183 [DEBUG] [l.googletv.GoogleTVConnectionManager] - F00DBABE_AA5E_BABA_DADA_70af241424b4 - Attempting to reconnect to the GoogleTV
2023-08-30 06:22:55.272 [INFO ] [tocol.googletv.GoogleTVMessageParser] - F00DBABE_AA5E_BABA_DADA_70af241424b4 - Login Successful
2023-08-30 06:22:55.273 [TRACE] [nternal.AndroidTVTranslationProvider] - Translated: online.online as Online
2023-08-30 06:22:55.279 [DEBUG] [l.googletv.GoogleTVConnectionManager] - F00DBABE_AA5E_BABA_DADA_70af241424b4 - Setting power to false
2023-08-30 06:22:55.898 [DEBUG] [l.googletv.GoogleTVConnectionManager] - I/O error while reading from stream: Connection reset
2023-08-30 06:22:55.900 [TRACE] [nternal.AndroidTVTranslationProvider] - Translated: offline.io-error as I/O Error
2023-08-30 06:22:55.902 [DEBUG] [l.googletv.GoogleTVConnectionManager] - F00DBABE_AA5E_BABA_DADA_70af241424b4 - Message reader thread exiting 6466
2023-08-30 06:22:59.245 [DEBUG] [philipstv.PhilipsTVConnectionManager] - F00DBABE_AA5E_BABA_DADA_70af241424b4 - Device Health - Online: false - Logged In: false
2023-08-30 06:22:59.246 [DEBUG] [philipstv.PhilipsTVConnectionManager] - F00DBABE_AA5E_BABA_DADA_70af241424b4 - Device is offline.
2023-08-30 06:22:59.247 [TRACE] [philipstv.PhilipsTVConnectionManager] - postUpdateThing OFFLINE COMMUNICATION_ERROR offline.communication-error-will-try-to-reconnect
2023-08-30 06:22:59.248 [TRACE] [philipstv.PhilipsTVConnectionManager] - Updating status to OFFLINE COMMUNICATION_ERROR offline.communication-error-will-try-to-reconnect
2023-08-30 06:22:59.250 [TRACE] [nternal.AndroidTVTranslationProvider] - Translated: offline.communication-error-will-try-to-reconnect as Communication error, will try to reconnect
2023-08-30 06:22:59.251 [TRACE] [philipstv.PhilipsTVConnectionManager] - setStatus to false offline.communication-error-will-try-to-reconnect Communication error, will try to reconnect
2023-08-30 06:23:00.733 [DEBUG] [l.googletv.GoogleTVConnectionManager] - F00DBABE_AA5E_BABA_DADA_70af241424b4 - Device Health - Online: false - Logged In: false - Mode: NORMAL
2023-08-30 06:23:04.254 [DEBUG] [philipstv.PhilipsTVConnectionManager] - F00DBABE_AA5E_BABA_DADA_70af241424b4 - Device Health - Online: true - Logged In: false
2023-08-30 06:23:04.254 [DEBUG] [philipstv.PhilipsTVConnectionManager] - F00DBABE_AA5E_BABA_DADA_70af241424b4 - Device is back online. Attempting reconnection.
2023-08-30 06:23:04.319 [TRACE] [philipstv.PhilipsTVConnectionManager] - postUpdateThing ONLINE NONE online.online
2023-08-30 06:23:04.320 [DEBUG] [philipstv.PhilipsTVConnectionManager] - Refresh Scheduler already started for Philips TV F00DBABE_AA5E_BABA_DADA_70af241424b4, terminating.
2023-08-30 06:23:04.321 [DEBUG] [philipstv.PhilipsTVConnectionManager] - Starting Refresh Scheduler for Philips TV F00DBABE_AA5E_BABA_DADA_70af241424b4 with refresh rate of 10.
2023-08-30 06:23:04.321 [TRACE] [nternal.AndroidTVTranslationProvider] - Translated: online.online as Online
2023-08-30 06:23:04.322 [TRACE] [philipstv.PhilipsTVConnectionManager] - setStatus to true online.online Online
2023-08-30 06:23:04.324 [DEBUG] [protocol.philipstv.ConnectionManager] - Target Uri is: https://192.168.1.57:1926/6/powerstate
2023-08-30 06:23:04.470 [DEBUG] [protocol.philipstv.ConnectionManager] - ----------------------------------------
2023-08-30 06:23:04.470 [DEBUG] [protocol.philipstv.ConnectionManager] - HTTP/1.1 200 OK
2023-08-30 06:23:04.471 [DEBUG] [protocol.philipstv.ConnectionManager] - {"powerstate":"StandbyKeep"}
2023-08-30 06:23:04.471 [TRACE] [philipstv.PhilipsTVConnectionManager] - postUpdateThing OFFLINE NONE
2023-08-30 06:23:04.473 [DEBUG] [philipstv.PhilipsTVConnectionManager] - Stopping Refresh Scheduler for Philips TV: F00DBABE_AA5E_BABA_DADA_70af241424b4
2023-08-30 06:23:04.475 [TRACE] [philipstv.PhilipsTVConnectionManager] - Updating status to OFFLINE NONE
2023-08-30 06:23:04.476 [TRACE] [nternal.AndroidTVTranslationProvider] - Failed to translate:
2023-08-30 06:23:04.476 [TRACE] [philipstv.PhilipsTVConnectionManager] - setStatus to false
2023-08-30 06:23:05.735 [DEBUG] [l.googletv.GoogleTVConnectionManager] - F00DBABE_AA5E_BABA_DADA_70af241424b4 - Device Health - Online: true - Logged In: false - Mode: NORMAL
2023-08-30 06:23:05.736 [DEBUG] [l.googletv.GoogleTVConnectionManager] - F00DBABE_AA5E_BABA_DADA_70af241424b4 - Device is back online. Attempting reconnection.
2023-08-30 06:23:05.736 [DEBUG] [l.googletv.GoogleTVConnectionManager] - F00DBABE_AA5E_BABA_DADA_70af241424b4 - Attempting to reconnect to the GoogleTV
2023-08-30 06:23:05.804 [INFO ] [tocol.googletv.GoogleTVMessageParser] - F00DBABE_AA5E_BABA_DADA_70af241424b4 - Login Successful
2023-08-30 06:23:05.806 [TRACE] [nternal.AndroidTVTranslationProvider] - Translated: online.online as Online
2023-08-30 06:23:05.813 [DEBUG] [l.googletv.GoogleTVConnectionManager] - F00DBABE_AA5E_BABA_DADA_70af241424b4 - Setting power to false
Ok, let’s give this a shot for the power…
Trace log please. What should happen now:
I could see different behaviour with latest jar and have done different trace logs. Sometimes Thing did go online and all good. But I could also see that Thing did go Online and then Offline again with GoogleTV Status “I/O:Error”:
Enable GoogleTV_Enabled_IOError.log (211.3 KB)
It also happened once that TV did not turn on at all:
Enable GoogleTV_Disabled_TVnotPoweredON.log (239.4 KB)
These two logs are with “Enable GoogleTV = Enabled” and “Enable GoogleTV = Disabled”:
Enable GoogleTV_Enabled.log (197.7 KB)
Enable GoogleTV_Disabled.log (224.3 KB)
I’m not sure why it went to I/O Error and stuck there. I see where it happened…
2023-09-03 11:27:52.446 [DEBUG] [l.googletv.GoogleTVConnectionManager] - I/O error while reading from stream: Connection reset
2023-09-03 11:27:52.447 [TRACE] [nternal.AndroidTVTranslationProvider] - Translated: offline.io-error as I/O Error
But then…
2023-09-03 11:28:19.037 [INFO ] [tocol.googletv.GoogleTVMessageParser] - F00DBABE_AA5E_BABA_DADA_70af241424b4 - Login Successful
2023-09-03 11:28:19.038 [TRACE] [nternal.AndroidTVTranslationProvider] - Translated: online.online as Online
So it should have gone online again. I’ll add some extra debug statements to see what’s happening.
Hello, I have several points to clarify
Well, I install the addon, however on/off channel works, but the philips like (such as amblilight) not working
Did you install the last posted here or the AndroidTV binding from the marketplace?
Please don’t expect too much support with this little information. I’m working in a technical support role and the worst thing when people ask for help is “it does not work”.
Please also check how to ask for help:
Last posted here
Thanks for template, and even your posts was never like it i will try to fill it here:
where can i get the right portion of logs?
Well, it’s not about strictly following the template line by line, but it’s about providing as much information as possible (detailed steps you did, screenshots, log files, etc).
I did quickly double check in my system and have re-added the PhilipsTV-Thing:
For GoogleTV you don’t need to do the pin process separately.
But before you delete the thing and add it again, you should first delete the credentials and pin in the command line., e.g.:
sudo rm -R /var/lib/openhab/androidtv
Could be that path is different in your system.
If this does not work, you should definitively share TRACE or DEBUG log files. How to create log files is described in the documentation: Logging | openHAB
Console e.g.
log:set TRACE org.openhab.binding.androidtv
Last point: Not all models have beed tested in the past. What model do you have?
And good to know:
Some things to note:
