*1 You drop the jar-file in the “addons” folder in openhab installation.
*2 Do what you normally do.
*3 Profit!?
I Have only used the binding with Paper-UI so far, if you go to your inbox after the plug-in is installed you should see any PS4 on your network there. Just click add, then you can configure the thing and add some more channel if you want.
Hi there! Anyone besides me has problems with controlling application with input keys?
I’ve installed the binding and I am able to move around on main menu with input keys. But as soon as I enter an application (make it Netflix for instance), these input keys stop working.
only after a restart, the power thing had the correct name for the channel (at the first attempt, there was a string attached like “helperchannel” or so …
if the playstation is on, obenhab knows its power status.
Question: is it possible to switch off the playstation via OpenHAB Switch?
very nice Binding! I installed the jar File yesterday and tried to connect my Playstation to ps4-waker. That was a little bit tricky, because I’m running openHAB on a Synology NAS. It turns out, that there are several problems to get ps4-waker running on that device. But I managed it. If I have a look in the connection menu of my PS4 the NAS is successfully connected, and if I start ps4-waker from the prompt of the NAS everything is ok, a lot of information of my PS4 are shown!
So I took the credentials from the ps4-waker file, checked the ip-address of the PS4, saved the pairingCode from the pairing process and created following thing:
But I can’t get the Thing working. In the events.log of openHAB it is always shown as “HANDLER_CONFIGURATION_PENDING”
Possible problem could be:
I’m not using a passcode on my PS4. But the configuration neither works if I define the thing completely without the passCode phrase or with a passcode phrase like passCode="".
The configuration of ipAdress="192.168.50.53" is correct, but when I check the thing configuration in Paper UI, the ip-address ist allways empty like in this screenshot:
