I am trying to use the Design Pattern to clean a rules files I have. My most complicated rule involves using my door sensors and cameras to alert me by sending a text message with a picture if a door is opened and the alarm is “armed”. So, here is a example of a rule for one of my doors:
rule "front door opened"
Item Front_Door changed from CLOSED to OPEN
if(Alarm.state==ON){
var FrontdoorcamO = "frontdoorO.jpg"
var frontdoormessageO = "Front door opened at "+ now.toString ("HH:mm dd-MM-yyyy")
executeCommandLine("wget http://X.X.X.X:XXXX/picture/3/current -O /tmp/" + FrontdoorcamO)
Thread::sleep(5000)
sendMail("XXXXXXXXXX@vzwpix.com", "Contact", frontdoormessageO, "file:///tmp/" +FrontdoorcamO)
Fault.postUpdate("ALERT - Front Door Has Been Opened")}
else if(Alarm.state==OFF){
Fault.postUpdate("Front door has been opened")}
I have to replicate this rule 5 more times for the other external doors. Right now, I have cut and pasted this rule for the others, changing the door names.
I started to re-write this rule using gDoors group, and I think I have that part resolved, but the problem I am running in to is the :
command. The “3” part of this command is specific to each camera (different number for each camera). So to consolidate, and have one rule for all six doors, I need to assign the camera number that is the closest to each triggering item and do something like:
executeCommandLine("wget http://X.X.X.X:XXXX/picture/"+triggeringItem.name"/current -O /tmp" +Camera)
but have the triggeringItem.name transformed to the camera number that has a view on the door. What would be the best way to go about this? I attempted to write the rule as:
rule "a door is opened"
Member of gDoors changed from CLOSED to OPEN
if(Alarm.state==ON)
val Front_Door = "3"
val Alcove_Door = "7"
val GarageSide_Door = "5"
val Bulkhead_Door = "6"
val Kitchen_Door = "7"
var String name = triggeringItem.name.toString.split("_").get(0)
var Camera = name+".jpg"
var MessageO = (name + "opened at "+ now.toString ("HH:mm dd-MM-yyyy")
var Command = ("wget http://X.X.X.X:XXXX/picture/")+triggeringItem.name("/current -O /tmp/" +Camera)
executeCommandLine(Command)
Thread::sleep(5000)
sendMail("XXXXXXXXXX@vzwpix.com". "Contact", MessageO, "file:///tmp/" +Camera)
Fault.postUpdate(name + "has been opened")}
I am getting no errors showing in VS Code, but this shows up in the log:
2018-07-25 13:10:35.425 [WARN ] [el.core.internal.ModelRepositoryImpl] - Configuration model 'Doors-Test.rules' has errors, therefore ignoring it: [7,2]: no viable alternative at input 'val'
[15,5]: missing ')' at 'var'
[18,37]: no viable alternative at input '"Contact"'
[18,46]: mismatched input ',' expecting 'end'
I am clearly missing something… any help would be appreciated!
~John
