h_bien74
(h_bien74)
July 4, 2017, 11:23am
1
Hi @all ,
yesterday i tried to update openhab 2.0 Release Candidate to openhab 2.1 Release Candidate on synology with dsm 6.1 without luck.
After the Update there are no directories like /conf /addons neither a openHab User.
After that i tried to de- and reinstall but with the same effect.
I’m the only one with that problems? Can anyone help me please?
greetings spratzi
I experience the same with “OpenHAB-2.1.0.005-syno-noarch-0.001.spk”
No luck for me either with “OpenHAB-2.1.0.005-syno-noarch-0.001.spk” (DS214, DSM 6.1.2-15132, JAVA 8 SE installed)
cniweb
(Christian Häussler)
July 5, 2017, 7:51pm
4
I think the problem is the folders that are linked to the public folder.
Should I create a package without these folders so that the original folders are used?
h_bien74
(h_bien74)
July 6, 2017, 8:27am
5
Hi cniweb,
i don’t know if that solve the problem, we must try. What’s about the missing openhab user? You think the problems depend on each other?
thx
cniweb
July 6, 2017, 6:37pm
6
hmm, OK the openhab2 user could also be the problem.
h_bien74
(h_bien74)
July 9, 2017, 5:18pm
8
for me i solved the problem to went back to openhab 2.0. Maybe i will try iobroker because after every single update for openhab (anyway wich platform) something not working properly.
gereetings spratzi
When i try to install OpenHAB2.0 i get a message that there are a new version…
h_bien74
(h_bien74)
July 10, 2017, 8:08am
10
You must deinstall Openhab 2.1 first
h_bien74
(h_bien74)
July 11, 2017, 3:28pm
11
I compared the installer.sh from openhab-syno-spk-2.0.0.001 with openhab-syno-spk-2.1.0.005 and found a mistake in the first line from 2.1 :
DOWNLOAD_PATH=“Service End for Bintray, JCenter, GoCenter, and ChartCenter | JFrog ”
must be:
wonder how this package could work at somebody
That was the first mistake i see, wil have a look further
Will this be corrected and made new install file? I’m new in this world so it need to be really simple i’m on synology DS
cniweb
July 11, 2017, 10:05pm
13
I released a new version:
Can you try it, please.
Thanks,
Chris
h_bien74
(h_bien74)
July 11, 2017, 10:22pm
14
I tried, but no luck. Update and clean install.
Same behaviour as before
Christian Häussler bot@community.openhab.org schrieb am Mi., 12. Juli
2017, 00:10:
Still does not work for me
loovanloon
(Ton van Loon)
July 12, 2017, 4:03pm
16
Clean install with .006 did not work for me either.
Benjy
(Ben Clark)
July 12, 2017, 4:11pm
17
A PR to fix the most likely cause has been submitted Update installer.sh - DSM 6 by SchoppAx · Pull Request #72 · openhab/openhab-syno-spk · GitHub
When this is merged and @cniweb has built .007 ( ) , we can try again
h_bien74
(h_bien74)
July 12, 2017, 8:00pm
19
I don’t install because it’s a snapshot…
cniweb
July 12, 2017, 8:27pm
20
