just installed the new 2.2.0.004-SNAPSHOT, which installs as expected and runs fine.
Thanks Christian.
Thanks Christian.
Hi, be careful installing the beta releases of openHAB in Synology disks, the last one completely deleted my DSM partition. I have to re-install the OS from scratch now. I have a post for this.
I will put there if I am able to recover my data partitions after I re-install.
Same issue with openHAB-2.1.0.008-DSM6-syno-noarch-0.001.spk, installation failed and errased my configuration
Hello all ,
I run Xpenology 6.1 which is the selfbuilt synology.
all 2.2 packages fail and do not start.
i run now 2.1.008 which runs fine.
i deleted first all packages and rest i could find of my previous installation.
i have a /volume1/Public folder mind the captital letter.
via windows explorer i create the maps conf and addons.
rights in synology are set to all users read and write to the Public folder.
then i just install the package 2.1.0.0.8 as described above and that works.
i also upgraded my java installation to 8u144 as it told me to update.
at this point no luck with the 2.2 versions but as said on the website its WIP.
kindest regards
I had the pcloadletter version installed so yes the se version
I’m interested … anyone can help please.
Anyone can help me investigate what am I doing wrong when can’t access OH2 web interface on my
DS214se, DSM 6.1.3-15152 Update 4
I’ve:
Have you tried using the IP adres instead of ‘nasik’ in your URL?
Met vriendelijke groet,
Ton van Loon
Yup, I’ve tried. Result is the same.
version 2.2 snaphot 7 (available here) installs OK and runs for me without any problems on a DS214play with DSM6.1 (if you take the option to install the config to /volume1/public/openHAB2. I’ve not tried the other install-path options).
Thanks I’ll give it a try. Smth went wrong and I need to reinstall whole DSM first.
After reinstalling DSM all works as expected. Thank you guys.
Hi Christian, I believe you are the only person who created the native Openhab Synology spk versions. Are you planning to do this also for the new Openhab 3.1.x releases and higher. I expect that many people would be happy if you do this.
