Problem switching ORMANAS LED Strip (IKEA)
I have problems to switch on/off my ORMANAS LED Strip from IKEA.
When i switch it on, it is on for a very short time and switches directly off again.
2024-11-06 11:30:25.341 [INFO ] [openhab.event.ItemCommandEvent      ] - Item 'zigbee_led_schreibtisch_noah_dimmer' received command ON
2024-11-06 11:30:25.485 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'zigbee_led_schreibtisch_noah_dimmer' changed from 8,5,0 to 8,5,100
2024-11-06 11:30:25.505 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'zigbee_led_schreibtisch_noah_dimmer' changed from 8,5,100 to 8.503937,5.11811,0
2024-11-06 11:30:25.699 [INFO ] [openhab.event.ItemCommandEvent      ] - Item 'zigbee_led_schreibtisch_noah_dimmer' received command 8,5,0
2024-11-06 11:30:25.946 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'zigbee_led_schreibtisch_noah_dimmer' changed from 8.503937,5.11811,0 to 8,5,0
2024-11-06 11:30:26.474 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'zigbee_led_schreibtisch_noah_dimmer' changed from 8,5,0 to 8.503937,5.11811,0
This is the thing:
An the details of the channel:
Who can help?
Perhaps the Zigbee2MQTT documentation helps:
Best regards
Daniel
Just a question:
Do you own DIRIGERA gateway? If yes I would like you test DIRIGERA Binding (IKEA Home smart)
No, sorry. I don’t own a DIRIGERA gateway.
I switched to the MQTT binding with Zigbee2MQTT. The IKEA device works perfectly with the described configuration.
