i added my MQTT Sonoff Stuff without any problem, but my Sonoff POW makes some trouble and in the end OH restarts.
my items:
// DRUCKER LED
// SONOFF TH16 - Temperature & Humidity
Switch Sonoff_TH16_1_Power "Sonoff TH16 Power" <poweroutlet> (gSonoff) {channel="mqtt:topic:SONOFF_TH16_1:power"}
String Sonoff_TH16_1_String "Sonoff TH16 String" <poweroutlet> (gSonoff) {channel="mqtt:topic:SONOFF_TH16_1:state"}
Number Sonoff_TH16_1_Temp "Sonoff TH16 Temp [%s °C]" <temperature> (gSonoff) {channel="mqtt:topic:SONOFF_TH16_1:temperature"}
Number Sonoff_TH16_1_Humidity "Sonoff TH16 Humidity [%s %%]" <humidity> (gSonoff) {channel="mqtt:topic:SONOFF_TH16_1:humidity"}
Number Sonoff_TH16_1_RSSI "Sonoff TH16 WLAN Stärke [%.0f %%]" <wifi> (gSonoff) {channel="mqtt:topic:SONOFF_TH16_1:rssi"}
Number Sonoff_TH16_1_Load "Sonoff TH16 Load Avg. [%s %%]" <heating> (gSonoff) {channel="mqtt:topic:SONOFF_TH16_1:load"}
String Sonoff_TH16_1_Uptime "Sonoff TH16 Uptime" <time> (gSonoff) {channel="mqtt:topic:SONOFF_TH16_1:uptime"}
String Sonoff_TH16_1_ssid "Sonoff TH16 WiFi" <wifi> (gSonoff) {channel="mqtt:topic:SONOFF_TH16_1:ssid"}
// PC
// SONOFF POW - Strom messen
Switch Sonoff_POW_1_Power "Sonoff POW Power [MAP(de.map):%s]" <poweroutlet> (gSonoff) {channel="mqtt:topic:SONOFF_POW_1:power_pow"}
String Sonoff_POW_1_String "Sonoff POW String" <poweroutlet> (gSonoff) {channel="mqtt:topic:SONOFF_POW_1:state_pow"}
Number Sonoff_POW_1_Voltage "Sonoff POW Spannung [%s V]" <temperature> (gSonoff) {channel="mqtt:topic:SONOFF_POW_1:voltage_pow"}
Number Sonoff_POW_1_Total "Sonoff POW Energie geamt [%s kWh]" <humidity> (gSonoff) {channel="mqtt:topic:SONOFF_POW_1:total_pow"}
Number Sonoff_POW_1_TotalYesterday "Sonoff POW Energie gestern [%s kWh]" <temperature> (gSonoff) {channel="mqtt:topic:SONOFF_POW_1:totalyesterday_pow"}
Number Sonoff_POW_1_TotalToday "Sonoff POW Energie heute [%s kWh]" <humidity> (gSonoff) {channel="mqtt:topic:SONOFF_POW_1:totaltoday_pow"}
Number Sonoff_POW_1_Current "Sonoff POW Strom [%s A]" <temperature> (gSonoff) {channel="mqtt:topic:SONOFF_POW_1:current_pow"}
Number Sonoff_POW_1_Period "Sonoff POW Period [%s]" <humidity> (gSonoff) {channel="mqtt:topic:SONOFF_POW_1:period_pow"}
Number Sonoff_POW_1_Factor "Sonoff POW Leistungsfaktor [%s]" <humidity> (gSonoff) {channel="mqtt:topic:SONOFF_POW_1:factor_pow"}
Number Sonoff_POW_1_Power2 "Sonoff POW Leistung [%s W]" <temperature> (gSonoff) {channel="mqtt:topic:SONOFF_POW_1:power2_pow"}
Number Sonoff_POW_1_ApparentPower "Sonoff POW Scheinleistung [%s VA]" <humidity> (gSonoff) {channel="mqtt:topic:SONOFF_POW_1:apparentpower_pow"}
Number Sonoff_POW_1_ReactivePower "Sonoff POW Blindleistung [%s VAr]" <temperature> (gSonoff) {channel="mqtt:topic:SONOFF_POW_1:reactivepower_pow"}
Number Sonoff_POW_1_RSSI "Sonoff POW WLAN Stärke [%.0f %%]" <wifi> (gSonoff) {channel="mqtt:topic:SONOFF_POW_1:rssi_pow"}
Number Sonoff_POW_1_Load "Sonoff POW Load Avg. [%s %%]" <heating> (gSonoff) {channel="mqtt:topic:SONOFF_POW_1:load_pow"}
String Sonoff_POW_1_Uptime "Sonoff POW Uptime" <time> (gSonoff) {channel="mqtt:topic:SONOFF_POW_1:uptime_pow"}
String Sonoff_POW_1_ssid "Sonoff POW WiFi" <wifi> (gSonoff) {channel="mqtt:topic:SONOFF_POW_1:ssid_pow"}
as soon as i add my POW ITEMS, i get this ERROR in the LOG:
2021-08-20 00:55:52.645 [ERROR] [d4j.internal.RRD4jPersistenceService] - Could not create rrd4j database file '/var/lib/openhab/persistence/rrd4j/Sonoff_POW_1_Factor.rrd': Invalid file header. File [/var/lib/openhab/persistence/rrd4j/Sonoff_POW_1_Factor.rrd] is not a RRD4J RRD file
2021-08-20 00:55:52.636 [WARN ] [org.openhab.core.items.GenericItem ] - failed notifying listener 'org.openhab.core.persistence.internal.PersistenceManagerImpl@642fd3' about state update of item Sonoff_POW_1_Period: No enum constant org.rrd4j.ConsolFun.
java.lang.IllegalArgumentException: No enum constant org.rrd4j.ConsolFun.
at java.lang.Enum.valueOf(Enum.java:240) ~[?:?]
at org.rrd4j.ConsolFun.valueOf(ConsolFun.java:10) ~[?:?]
at org.rrd4j.core.Archive.getConsolFun(Archive.java:207) ~[?:?]
at org.rrd4j.core.RrdDb.getRrdDef(RrdDb.java:955) ~[?:?]
at org.openhab.persistence.rrd4j.internal.RRD4jPersistenceService.getConsolidationFunction(RRD4jPersistenceService.java:397) ~[?:?]
at org.openhab.persistence.rrd4j.internal.RRD4jPersistenceService.store(RRD4jPersistenceService.java:142) ~[?:?]
at org.openhab.core.persistence.internal.PersistenceManagerImpl.handleStateEvent(PersistenceManagerImpl.java:152) ~[?:?]
at org.openhab.core.persistence.internal.PersistenceManagerImpl.stateChanged(PersistenceManagerImpl.java:473) ~[?:?]
at org.openhab.core.items.GenericItem.lambda$1(GenericItem.java:259) [bundleFile:?]
2021-08-20 00:55:52.660 [ERROR] [d4j.internal.RRD4jPersistenceService] - Could not create rrd4j database file '/var/lib/openhab/persistence/rrd4j/Sonoff_POW_1_ApparentPower.rrd': Invalid file header. File [/var/lib/openhab/persistence/rrd4j/Sonoff_POW_1_ApparentPower.rrd] is not a RRD4J RRD file
2021-08-20 00:55:52.664 [ERROR] [d4j.internal.RRD4jPersistenceService] - Could not create rrd4j database file '/var/lib/openhab/persistence/rrd4j/Sonoff_POW_1_Power2.rrd': Invalid file header. File [/var/lib/openhab/persistence/rrd4j/Sonoff_POW_1_Power2.rrd] is not a RRD4J RRD file
2021-08-20 00:55:52.668 [ERROR] [d4j.internal.RRD4jPersistenceService] - Could not create rrd4j database file '/var/lib/openhab/persistence/rrd4j/Sonoff_POW_1_ReactivePower.rrd': Invalid file header. File [/var/lib/openhab/persistence/rrd4j/Sonoff_POW_1_ReactivePower.rrd] is not a RRD4J RRD file
i did not set up any persistence yet.
Where is the problem with this ?
Thank you!
