I only use mosquitto. No idea, where i can look for the name: “mqttserver”
mqtt.cfg is only with broker mosquitto
And i also get this errors:
2018-11-21 22:37:16.949 [ERROR] [el.item.internal.GenericItemProvider] - Binding configuration of type 'mqtt' of item 'rfid1' could not be parsed correctly.
Now i tried the following, but no
luck:
Number rfid1 "RFID Test [%d]" {mqtt="<[mosquitto:esprfid/uid:*:default]"}
Number rfid1 "RFID Test [%d]" {mqtt="<[mosquitto:esprfid/uid:number:*:default]"}
Number rfid1 "RFID Test [%d]" {mqtt="<[mosquitto:esprfid/uid:command:*:default]"}
I now get a value to rfid1-number-item, but only 2 numbers “27”
My rfid-token-number is much longer…
EDIT:
There was an error in the openhab.log too, some minutes ago: But this was only a heartbeat- with no uid in the mqtt message… So how to prevent this error?
018-11-22 07:46:47.784 [WARN ] [.mqtt.internal.MqttMessageSubscriber] - Error processing MQTT message.
org.openhab.core.transform.TransformationException: Invalid path '$.uid' in '{"type":"hearthbeat","time":1542869208}'
at org.openhab.core.transform.TransformationHelper$TransformationServiceDelegate.transform(TransformationHelper.java:67) ~[199:org.openhab.core.compat1x:2.4.0.201811151136]
at org.openhab.binding.mqtt.internal.MqttMessageSubscriber.processMessage(MqttMessageSubscriber.java:133) [258:org.openhab.binding.mqtt:1.13.0.201811180829]
at org.openhab.io.transport.mqtt.internal.MqttBrokerConnection.messageArrived(MqttBrokerConnection.java:570) [259:org.openhab.io.transport.mqtt:1.13.0.201811180829]
at org.eclipse.paho.client.mqttv3.internal.CommsCallback.deliverMessage(CommsCallback.java:475) [259:org.openhab.io.transport.mqtt:1.13.0.201811180829]
at org.eclipse.paho.client.mqttv3.internal.CommsCallback.handleMessage(CommsCallback.java:379) [259:org.openhab.io.transport.mqtt:1.13.0.201811180829]
at org.eclipse.paho.client.mqttv3.internal.CommsCallback.run(CommsCallback.java:183) [259:org.openhab.io.transport.mqtt:1.13.0.201811180829]
This is the whole string i get from mqtt, when i enter it into an online parser, without the leading esprfid, then i get shown exactly the same data, only every value in one line.
How can i read out the whole string with all values in one single item? Then i would be able to split this in a rule to get the needed values…
This should give you the entire JSON “message” as a string that you could put on a sitemap (just to show that you actually get it all), write to the log, or - as you really need - parse in a rule.
I am sure there is some Java JSON library that you can use for this, but I have never done this, so I am afraid I cannot help on this account.
My suggestion for capturing the complete JSON message in a string was only because you asked if it was possible - and as a way to verify that you actually receive the JSON message in openHAB, i.e. a debugging measure.
This is not neccessarily the way I would do this.
Given the following JSON message (from your original post):
Hi, i think i can´t use this, because the heartbeat only gives me type and time, so there is no uid in the message and there i get error messages.
So my plan is to get the whole string, then look with jsonpath-transformation if the type is access and if yes, send the uid to openhab and do some stuff.
If type is only heartbeat, then the rule will stop at this point and do nothing.
The MQTT binding supports a fifth parameter for inbound messages, called a " <regex_filter>". Using this you can make sure that only messages that matches certain criteria will be passed on to the transformation stage (JSONPATH, in your case).
Note! As a first attempt, I suggest you define all your items as String items just to see that you can sucessfully split your JSON message into separate parts in openHAB. If this works, then you can try to use Number and DateTime (as above) to do “automatic type conversion” if this is needed - I guess it all depends on what you will use the data for in your rules.
rule "RFID Haustür MQTT"
Item rfid_all_haustuer received changed
val newValue_type = transform("JSONPATH", "$.type", rfid_all_haustuer.state.toString)
if (newValue_type == "hearthbeat") {
logInfo("RFID", "RFID Haustür -3- ---> MQTT --> only heartbeat --> " + newValue_type)
else if (newValue_type == "access") {
val newValue_uid = transform("JSONPATH", "$.uid", rfid_all_haustuer.state.toString)
logInfo("RFID", "RFID Haustür -4- ---> MQTT --> access : uid --> " + newValue_type + " : " + newValue_uid)
I have another small problem:
in time i get the epoch (ms since 1970 i think), how can i convert this into a readable format?
This gives me an error:
val newValue_time = transform("JSONPATH", "$.time", rfid_all_haustuer.state.toString)
val DateTimeType MyDateTimeTypeFromEpoch = new DateTimeType(new DateTime(newValue_time).toString)
