Problem with openhab2
hi
i would like to ask you to help me because i have a problem with openhab .
Openhab was working great for 4 months but the last weak stop working after 2 houres
I had done backup at second card and the second card for the last openHAB-conf but it does not work again (stop working after 2 houres).
The only think i did was update openhab2 .
Down you can see what i see at my openhab
Linux openhab 4.19.118-v7l+ #1311 SMP Mon Apr 27 14:26:42 BST 2020 armv7l
The programs included with the Debian GNU/Linux system are free software;
the exact distribution terms for each program are described in the
individual files in /usr/share/doc/*/copyright.
Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
permitted by applicable law.
Last login: Sun Jun 21 11:43:08 2020 from 192.168.0.15
###############  openhab  #####################################################
##        Ip = 192.168.0.222
##   Release = Raspbian GNU/Linux 10 (buster)
##    Kernel = Linux 4.19.97-v7l+
##  Platform = Raspberry Pi 4 Model B Rev 1.2
##    Uptime = 0 day(s). 22:32:2
## CPU Usage = 36.2% avg over 4 cpu(s) (4 core(s) x 1 socket(s))
##  CPU Load = 1m: 1.13, 5m: 1.16, 15m: 1.16
##    Memory = Free: 1.66GB (43%), Used: 2.19GB (57%), Total: 3.86GB
##      Swap = Free: 0.09GB (100%), Used: 0.00GB (0%), Total: 0.09GB
##      Root = Free: 24.18GB (86%), Used: 3.68GB (14%), Total: 29.07GB
##   Updates = 0 apt updates available.
##  Sessions = 1 session(s)
## Processes = 127 running processes of 32768 maximum processes
              Welcome to            __  _____    ____  _
            ____  ____  ___  ____  / / / /   |  / __ )(_)___ _____
           / __ \/ __ \/ _ \/ __ \/ /_/ / /| | / __  / / __ `/ __ \
          / /_/ / /_/ /  __/ / / / __  / ___ |/ /_/ / / /_/ / / / /
          \____/ .___/\___/_/ /_/_/ /_/_/  |_/_____/_/\__,_/_/ /_/
              /_/
                  openHAB 2.5.5-1 (Release Build)
Looking for a place to get started? Check out 'sudo openhabian-config' and the
documentation at https://www.openhab.org/docs/installation/openhabian.html
The openHAB dashboard can be reached at http://openhab:8080
To interact with openHAB on the command line, execute: 'openhab-cli --help'
tail -f /var/log/openhab2/openhab.log /var/log/openhab2/events.log
Filter
2020-06-21 22:21:26.029 [DEBUG] [pdb.internal.MapDBPersistenceService] - Stored 'Shellyem1CurrentBoiler' with state '0.025' in mapdb database
2020-06-21 22:21:26.032 [DEBUG] [pdb.internal.MapDBPersistenceService] - store called for Shellyem1CurrentBoiler
2020-06-21 22:21:18.734 [TRACE] [elly.internal.coap.ShellyCoapHandler] - shelly1-b9ca54: Serial 31488 was already processed, ignore update
2020-06-21 22:21:26.035 [DEBUG] [pdb.internal.MapDBPersistenceService] - Stored 'Shellyem1CurrentBoiler' with state '0.025' in mapdb database
2020-06-21 22:21:26.035 [DEBUG] [elly.internal.coap.ShellyCoapHandler] - shelly1-772abb: CoIoT Message from /192.168.0.85:5683 (MID=64338): {"G":[[0,112,1],[0,118,0]]}
2020-06-21 22:21:26.037 [TRACE] [elly.internal.coap.ShellyCoapHandler] - shelly1-772abb: Serial 20992 was already processed, ignore update
2020-06-21 22:21:29.251 [DEBUG] [elly.internal.coap.ShellyCoapHandler] - shelly1-68ab8b: CoIoT Message from /192.168.0.83:5683 (MID=1708): {"G":[[0,112,0],[0,118,1]]}
2020-06-21 22:21:29.253 [TRACE] [elly.internal.coap.ShellyCoapHandler] - shelly1-68ab8b: Serial 42753 was already processed, ignore update
2020-06-21 22:21:29.261 [DEBUG] [elly.internal.coap.ShellyCoapHandler] - shellydimmer-f36afb: CoIoT Message from /192.168.0.103:5683 (MID=53696): {"G":[[0,111, 100],[0,121, 0],[0,131, 0],[0,141, 0],[0,211,0.000],[0,212,0.000],[0,213,0.000],[0,214,0],[0,311,54.22],[0,312,129.60],[0,313,0]]}
2020-06-21 22:21:32.574 [vent.ItemStateChangedEvent] - Server_Watts changed from 5.1 to 5.2
2020-06-21 22:21:35.797 [ome.event.ItemCommandEvent] - Item 'Server_Power' received command 0.022608696
2020-06-21 22:21:45.585 [WARN ] [me.core.internal.events.EventHandler] - Dispatching event to subscriber 'org.eclipse.smarthome.core.thing.internal.CommunicationManager@69cb04' takes more than 5000ms.
2020-06-21 22:21:45.585 [DEBUG] [lly.internal.util.ShellyChannelCache] - shellyplugs-267098: Channel meter#totalKWH updated with 2.848 kWh (type class org.eclipse.smarthome.core.library.types.QuantityType).
2020-06-21 22:21:45.585 [DEBUG] [pdb.internal.MapDBPersistenceService] - store called for My_Home_Watts
2020-06-21 22:21:45.585 [TRACE] [ng.shelly.internal.api.ShellyHttpApi] - shellyplugs-51cd9c: HTTP Response 200: {"wifi_sta":{"connected":true,"ssid":"My Home ","ip":"192.168.0.162","rssi":-61},"cloud":{"enabled":true,"connected":true},"mqtt":{"connected":false},"time":"22:21","unixtime":1592778079,"serial":26960,"has_update":false,"mac":"D8BFC051CD9C","relays":[{"ison":true,"has_timer":false,"timer_started":0,"timer_duration":0,"timer_remaining":0,"overpower":false}],"meters":[{"power":0.65,"is_valid":true,"timestamp":1592778079,"counters":[0.611, 0.596, 0.633],"total":25665}],"temperature":39.56,"overtemperature":false,"tmp":{"tC":39.56,"tF":103.21, "is_valid":true},"update":{"status":"idle","has_update":false,"new_version":"20200601-123307/v1.7.0@d7961837","old_version":"20200601-123307/v1.7.0@d7961837"},"ram_total":50240,"ram_free":39452,"ram_lwm":29216,"fs_size":233681,"fs_free":167668,"uptime":1633252}
2020-06-21 22:21:45.602 [DEBUG] [pdb.internal.MapDBPersistenceService] - Stored 'My_Home_Watts' with state '620.4' in mapdb database
2020-06-21 22:21:59.126 [DEBUG] [lly.internal.util.ShellyChannelCache] - shellyplugs-51cd9c: Channel device#uptime updated with 1633108 s (type class org.eclipse.smarthome.core.library.types.QuantityType).
2020-06-21 22:21:59.129 [TRACE] [y.internal.handler.ShellyBaseHandler] - shellyplugs-51cd9c: Updating 1 standard meter(s)
2020-06-21 22:21:55.894 [INFO ] [pse.smarthome.model.script.POWER_DEH] - DEH Is ... OFF
2020-06-21 22:21:59.129 [TRACE] [elly.internal.coap.ShellyCoapHandler] - shellydimmer-f36afb: Serial 31289 was already processed, ignore update
2020-06-21 22:21:48.840 [DEBUG] [pdb.internal.MapDBPersistenceService] - store called for Microwave_Watts
2020-06-21 22:22:15.905 [DEBUG] [lly.internal.util.ShellyChannelCache] - shellyplugs-267098: Channel meter#lastPower3 updated with 20.3 W (type class org.eclipse.smarthome.core.library.types.QuantityType).
2020-06-21 22:22:19.777 [DEBUG] [lly.internal.util.ShellyChannelCache] - shellyplugs-267098: Channel meter#lastUpdate updated with 2020-06-21T22:17:02.000+0300 (type class org.eclipse.smarthome.core.library.types.DateTimeType).
2020-06-21 22:22:32.501 [TRACE] [y.internal.handler.ShellyBaseHandler] - shellyplugs-267098: 5 more updates requested
2020-06-21 22:22:35.702 [INFO ] [inding.mail.internal.POP3IMAPHandler] - error when trying to refresh IMAP: Remote host closed connection during handshake
2020-06-21 22:22:35.707 [TRACE] [y.internal.handler.ShellyBaseHandler] - shellyplugs-51d965: Updating status
2020-06-21 22:22:35.708 [TRACE] [ng.shelly.internal.api.ShellyHttpApi] - shellyplugs-51d965: HTTP GET for http://192.168.0.166/status
2020-06-21 22:22:38.909 [TRACE] [ng.shelly.internal.api.ShellyHttpApi] - shellyplugs-51d965: HTTP Response 200: {"wifi_sta":{"connected":true,"ssid":"My Home ","ip":"192.168.0.166","rssi":-33},"cloud":{"enabled":true,"connected":true},"mqtt":{"connected":false},"time":"22:22","unixtime":1592778156,"serial":30694,"has_update":false,"mac":"D8BFC051D965","relays":[{"ison":true,"has_timer":false,"timer_started":0,"timer_duration":0,"timer_remaining":0,"overpower":false}],"meters":[{"power":5.22,"is_valid":true,"timestamp":1592778156,"counters":[5.120, 5.152, 5.158],"total":123468}],"temperature":49.40,"overtemperature":false,"tmp":{"tC":49.40,"tF":120.92, "is_valid":true},"update":{"status":"idle","has_update":false,"new_version":"20200601-123307/v1.7.0@d7961837","old_version":"20200601-123307/v1.7.0@d7961837"},"ram_total":50240,"ram_free":39320,"ram_lwm":31224,"fs_size":233681,"fs_free":167668,"uptime":1633322}
2020-06-21 22:22:38.919 [TRACE] [.internal.handler.ShellyRelayHandler] - shellyplugs-51d965: Updating 1 relay(s)
2020-06-21 22:22:46.034 [TRACE] [ng.shelly.internal.api.ShellyHttpApi] - shellyplugs-51d965: HTTP GET for http://192.168.0.166/status/relay/0
2020-06-21 22:22:49.248 [TRACE] [ng.shelly.internal.api.ShellyHttpApi] - shellyplugs-51d965: HTTP Response 200: {"wifi_sta":{"connected":true,"ssid":"My Home ","ip":"192.168.0.166","rssi":-33},"cloud":{"enabled":true,"connected":true},"mqtt":{"connected":false},"time":"22:22","unixtime":1592778166,"serial":30694,"has_update":false,"mac":"D8BFC051D965","relays":[{"ison":true,"has_timer":false,"timer_started":0,"timer_duration":0,"timer_remaining":0,"overpower":false}],"meters":[{"power":5.30,"is_valid":true,"timestamp":1592778166,"counters":[5.120, 5.152, 5.158],"total":123468}],"temperature":49.30,"overtemperature":false,"tmp":{"tC":49.30,"tF":120.74, "is_valid":true},"update":{"status":"idle","has_update":false,"new_version":"20200601-123307/v1.7.0@d7961837","old_version":"20200601-123307/v1.7.0@d7961837"},"ram_total":50240,"ram_free":39312,"ram_lwm":31224,"fs_size":233681,"fs_free":167668,"uptime":1633332}
2020-06-21 22:22:49.248 [WARN ] [mazonechocontrol.internal.Connection] - Request to url 'https://alexa.amazon.com/api/np/player?deviceSerialNumber=G090LF11832304TK&deviceType=A3S5BH2HU6VAYF&screenWidth=1440' fails with unknown error
javax.net.ssl.SSLHandshakeException: Remote host closed connection during handshake
	at sun.security.ssl.SSLSocketImpl.readRecord(SSLSocketImpl.java:1009) ~[?:1.8.0_252]
	at sun.security.ssl.SSLSocketImpl.performInitialHandshake(SSLSocketImpl.java:1388) ~[?:1.8.0_252]
	at sun.security.ssl.SSLSocketImpl.startHandshake(SSLSocketImpl.java:1416) ~[?:1.8.0_252]
	at sun.security.ssl.SSLSocketImpl.startHandshake(SSLSocketImpl.java:1400) ~[?:1.8.0_252]
	at sun.net.www.protocol.https.HttpsClient.afterConnect(HttpsClient.java:559) ~[?:1.8.0_252]
	at sun.net.www.protocol.https.AbstractDelegateHttpsURLConnection.connect(AbstractDelegateHttpsURLConnection.java:185) ~[?:1.8.0_252]
	at sun.net.www.protocol.http.HttpURLConnection.getInputStream0(HttpURLConnection.java:1573) ~[?:1.8.0_252]
	at sun.net.www.protocol.http.HttpURLConnection.getInputStream(HttpURLConnection.java:1501) ~[?:1.8.0_252]
	at java.net.HttpURLConnection.getResponseCode(HttpURLConnection.java:480) ~[?:1.8.0_252]
	at sun.net.www.protocol.https.HttpsURLConnectionImpl.getResponseCode(HttpsURLConnectionImpl.java:352) ~[?:1.8.0_252]
	at org.openhab.binding.amazonechocontrol.internal.Connection.makeRequest(Connection.java:583) ~[?:?]
	at org.openhab.binding.amazonechocontrol.internal.Connection.makeRequestAndReturnString(Connection.java:499) ~[?:?]
	at org.openhab.binding.amazonechocontrol.internal.Connection.makeRequestAndReturnString(Connection.java:494) ~[?:?]
	at org.openhab.binding.amazonechocontrol.internal.Connection.getPlayer(Connection.java:922) ~[?:?]
	at org.openhab.binding.amazonechocontrol.internal.handler.EchoHandler.updateState(EchoHandler.java:853) ~[?:?]
	at org.openhab.binding.amazonechocontrol.internal.handler.AccountHandler.refreshData(AccountHandler.java:532) ~[?:?]
	at org.openhab.binding.amazonechocontrol.internal.handler.AccountHandler.checkData(AccountHandler.java:406) ~[?:?]
	at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:511) [?:1.8.0_252]
	at java.util.concurrent.FutureTask.runAndReset(FutureTask.java:308) [?:1.8.0_252]
	at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$301(ScheduledThreadPoolExecutor.java:180) [?:1.8.0_252]
	at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:294) [?:1.8.0_252]
	at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149) [?:1.8.0_252]
	at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624) [?:1.8.0_252]
	at java.lang.Thread.run(Thread.java:748) [?:1.8.0_252]
Caused by: java.io.EOFException: SSL peer shut down incorrectly
	at sun.security.ssl.InputRecord.read(InputRecord.java:505) ~[?:1.8.0_252]
	at sun.security.ssl.SSLSocketImpl.readRecord(SSLSocketImpl.java:990) ~[?:1.8.0_252]
	... 23 more
2020-06-21 22:23:09.282 [DEBUG] [lly.internal.util.ShellyChannelCache] - shellyplugs-51d965: Channel device#uptime updated with 1633322 s (type class org.eclipse.smarthome.core.library.types.QuantityType).
2020-06-21 22:22:55.706 [DEBUG] [pdb.internal.MapDBPersistenceService] - Stored 'Microwave_Watts' with state '20.2' in mapdb database
2020-06-21 22:22:55.691 [DEBUG] [elly.internal.coap.ShellyCoapHandler] - shelly1-771988: CoIoT Message from /192.168.0.87:5683 (MID=46115): {"G":[[0,112,0],[0,118,1]]}
2020-06-21 22:22:52.463 [vent.ItemStateChangedEvent] - LocalComputerMemoryUsed changed from 1447 to 1448
2020-06-21 22:23:36.483 [TRACE] [y.internal.handler.ShellyBaseHandler] - shellyplugs-51d965: Updating 1 standard meter(s)
2020-06-21 22:23:36.483 [TRACE] [elly.internal.coap.ShellyCoapHandler] - shelly1-771988: Serial 11008 was already processed, ignore update
2020-06-21 22:22:52.461 [WARN ] [me.core.internal.events.EventHandler] - Dispatching event to subscriber 'org.eclipse.smarthome.io.monitor.internal.EventLogger@10fc375' takes more than 5000ms.
2020-06-21 22:22:52.462 [ERROR] [y.mdns.internal.MDNSDiscoveryService] - Participant 'org.openhab.binding.enigma2.internal.discovery.Enigma2DiscoveryParticipant' threw an exception
java.lang.IllegalArgumentException: The validated object is null
	at org.apache.commons.lang.Validate.notNull(Validate.java:192) ~[?:?]
	at org.apache.commons.lang.Validate.notNull(Validate.java:178) ~[?:?]
	at org.openhab.binding.enigma2.internal.discovery.Enigma2DiscoveryParticipant.getThingUID(Enigma2DiscoveryParticipant.java:82) ~[?:?]
	at org.eclipse.smarthome.config.discovery.mdns.internal.MDNSDiscoveryService.serviceRemoved(MDNSDiscoveryService.java:241) [bundleFile:?]
	at javax.jmdns.impl.ListenerStatus$ServiceListenerStatus.serviceRemoved(ListenerStatus.java:81) [bundleFile:3.5.5]
	at javax.jmdns.impl.JmDNSImpl$5.run(JmDNSImpl.java:1322) [bundleFile:3.5.5]
	at java.util.concurrent.FutureTask.run(FutureTask.java:266) [?:1.8.0_252]
2020-06-21 22:23:36.482 [INFO ] [control.internal.handler.EchoHandler] - getPlayer fails
	... 23 more
2020-06-21 22:23:46.809 [DEBUG] [pdb.internal.MapDBPersistenceService] - store called for home_Total
2020-06-21 22:23:36.485 [DEBUG] [elly.internal.coap.ShellyCoapHandler] - shellyplugs-51cc2c: CoIoT Message from /192.168.0.163:5683 (MID=26425): {"G":[[0,111,0.00],[0,112,1],[0,113,39.79],[0,114,103.61],[0,115,0],[0,211,0.000],[0,212,0.000],[0,213,0.000],[0,214,301816]]}
2020-06-21 22:24:47.783 [ERROR] [io.gcal.internal.GCalEventDownloader] - Event fetch failed: Remote host closed connection during handshake
2020-06-21 22:25:01.261 [DEBUG] [elly.internal.coap.ShellyCoapHandler] - shellyplugs-51cc2c: CoIoT Sensor data {"G":[[0,111,0.00],[0,112,1],[0,113,39.79],[0,114,103.61],[0,115,0],[0,211,0.000],[0,212,0.000],[0,213,0.000],[0,214,301816]]}
2020-06-21 22:25:01.263 [DEBUG] [elly.internal.coap.ShellyCoapHandler] - shellyplugs-51cc2c: 9 CoAP sensor updates received
2020-06-21 22:23:50.011 [INFO ] [.reconnect.PeriodicReconnectStrategy] - Try to restore connection to '192.168.0.222'. Next attempt in 60000ms
2020-06-21 22:25:21.186 [vent.ItemStateChangedEvent] - Server_MeterCurrentWatts changed from 5.1 W to 5.2 W
2020-06-21 22:25:40.397 [vent.ItemStateChangedEvent] - NESPRESSODeviceUptime changed from 1632149 s to 1632166 s
2020-06-21 22:25:53.156 [vent.ItemStateChangedEvent] - LocalComputerSensorsCpuTemp changed from 55.0 to 56.0
2020-06-21 22:25:01.264 [TRACE] [elly.internal.coap.ShellyCoapHandler] - shellyplugs-51cc2c:  Sensor value[0]: id=111, Value=0.0 (Power, Type=P, Range=0/2500, Link=0: Relay0)
2020-06-21 22:25:59.604 [TRACE] [y.internal.handler.ShellyBaseHandler] - shelly25-roller-c4d140: Updating status
2020-06-21 22:25:59.604 [DEBUG] [discovery.ShellyDiscoveryParticipant] - ServiceInfo [ServiceInfoImpl@29280353 name: 'shelly1-771743._http._tcp.local.' address: '(null):80' status: 'DNS: JmDNS-/192.168.0.222 [/192.168.0.222] state: probing 1 task: null', has NO data, empty]
2020-06-21 22:25:59.604 [DEBUG] [lly.internal.util.ShellyChannelCache] - shellyplugs-51d965: Channel meter#currentWatts updated with 5.2 W (type class org.eclipse.smarthome.core.library.types.QuantityType).
2020-06-21 22:25:59.604 [WARN ] [me.core.internal.events.EventHandler] - Dispatching event to subscriber 'org.eclipse.smarthome.core.internal.items.ItemUpdater@1979d94' takes more than 5000ms.
2020-06-21 22:25:59.604 [DEBUG] [lly.internal.util.ShellyChannelCache] - shellyplugs-51cd9c: Channel meter#lastUpdate updated with 2020-06-21T22:18:55.000+0300 (type class org.eclipse.smarthome.core.library.types.DateTimeType).
2020-06-21 22:25:59.605 [TRACE] [elly.internal.coap.ShellyCoapHandler] - shellyplugs-51cc2c:  Sensor value[1]: id=112, Value=1.0 (State, Type=S, Range=0/1, Link=0: Relay0)
2020-06-21 22:26:54.980 [TRACE] [y.internal.handler.ShellyBaseHandler] - shellyplugs-51cd9c: 3 more updates requested
2020-06-21 22:26:54.981 [TRACE] [ng.shelly.internal.api.ShellyHttpApi] - shelly25-roller-c4d140: HTTP GET for http://192.168.0.97/status
2020-06-21 22:26:54.979 [WARN ] [me.core.internal.events.EventHandler] - Dispatching event to subscriber 'org.eclipse.smarthome.io.monitor.internal.EventLogger@10fc375' takes more than 5000ms.
2020-06-21 22:31:39.471 [TRACE] [elly.internal.coap.ShellyCoapHandler] - shellyplugs-51cc2c:  Sensor value[2]: id=113, Value=39.79 (Temperature C, Type=T, Range=-40/300, Link=0: Relay0)
2020-06-21 22:31:39.471 [DEBUG] [pdb.internal.MapDBPersistenceService] - Stored 'home_Total' with state '0.22582607' in mapdb database
2020-06-21 22:31:39.471 [DEBUG] [ng.shelly.internal.api.ShellyHttpApi] - shelly25-roller-c4d140: API Timeout, retry #1 (Device unreachable or API Timeout (GET http://192.168.0.97/status))
2020-06-21 22:31:39.471 [TRACE] [y.internal.handler.ShellyBaseHandler] - shelly1-771988: Updating status
2020-06-21 22:31:39.471 [WARN ] [me.core.internal.events.EventHandler] - Dispatching event to subscriber 'org.eclipse.smarthome.core.internal.items.ItemUpdater@1979d94' takes more than 5000ms.
2020-06-21 23:08:12.144 [TRACE] [ng.shelly.internal.api.ShellyHttpApi] - shelly1-771988: HTTP GET for http://192.168.0.87/status
2020-06-21 23:08:12.144 [TRACE] [ng.shelly.internal.api.ShellyHttpApi] - shelly25-roller-c4d140: HTTP GET for http://192.168.0.97/status
2020-06-21 23:08:08.227 [TRACE] [elly.internal.coap.ShellyCoapHandler] - shellyplugs-51cc2c:  Sensor value[3]: id=114, Value=103.61 (Temperature F, Type=T, Range=-40/300, Link=0: Relay0)
2020-06-21 23:08:18.589 [TRACE] [elly.internal.coap.ShellyCoapHandler] - shellyplugs-51cc2c:  Sensor value[4]: id=115, Value=0.0 (Overtemp, Type=S, Range=0/1, Link=0: Relay0)
2020-06-21 22:31:39.471 [WARN ] [mazonechocontrol.internal.Connection] - Request to url 'https://alexa.amazon.com/api/notification/sounds?deviceSerialNumber=ff1e1872d52f420581578d5cb1d28d50&deviceType=A3C9PE6TNYLTCH&softwareVersion=0' fails with unknown error
	at org.openhab.binding.amazonechocontrol.internal.Connection.getNotificationSounds(Connection.java:1324) ~[?:?]
	at org.openhab.binding.amazonechocontrol.internal.handler.AccountHandler.refreshData(AccountHandler.java:495) ~[?:?]
	... 22 more
2020-06-21 23:08:38.471 [TRACE] [elly.internal.coap.ShellyCoapHandler] - shellyplugs-51cc2c:  Sensor value[5]: id=211, Value=0.0 (Energy counter 0 [W-min], Type=S, Range=null, Link=0: Relay0)
2020-06-21 22:57:09.432 [ERROR] [se.californium.elements.UDPConnector] - Exception in network stage thread [UDP-Receiver-0.0.0.0/0.0.0.0:5683[0]]:
java.lang.OutOfMemoryError: Java heap space
2020-06-21 22:26:02.797 [ERROR] [y.mdns.internal.MDNSDiscoveryService] - Participant 'org.openhab.binding.enigma2.internal.discovery.Enigma2DiscoveryParticipant' threw an exception
2020-06-21 23:08:54.974 [DEBUG] [discovery.ShellyDiscoveryParticipant] - ServiceInfo [ServiceInfoImpl@32163371 name: 'shellyem-062017._http._tcp.local.' address: '(null):80' status: 'DNS: JmDNS-/192.168.0.222 [/192.168.0.222] state: probing 1 task: null', has NO data, empty]
2020-06-21 23:09:17.292 [WARN ] [mmon.WrappedScheduledExecutorService] - Scheduled runnable ended with an exception:
2020-06-21 23:11:10.943 [DEBUG] [lly.internal.util.ShellyChannelCache] - shellyplugs-51d965: Channel meter#totalKWH updated with 2.058 kWh (type class org.eclipse.smarthome.core.library.types.QuantityType).
2020-06-21 23:12:53.954 [vent.ItemStateChangedEvent] - Server_MeterLastUpdate changed from 2020-06-21T22:03:09.000+0300 to 2020-06-21T22:03:12.000+0300
2020-06-21 23:13:04.319 [WARN ] [mmon.WrappedScheduledExecutorService] - Scheduled runnable ended with an exception:
2020-06-21 23:08:38.473 [TRACE] [elly.internal.coap.ShellyCoapHandler] - shellyplugs-51cc2c:  Sensor value[6]: id=212, Value=0.0 (Energy counter 1 [W-min], Type=S, Range=null, Link=0: Relay0)
2020-06-21 23:08:21.804 [DEBUG] [ng.shelly.internal.api.ShellyHttpApi] - shelly1-771988: API Timeout, retry #1 (Device unreachable or API Timeout (GET http://192.168.0.87/status))
2020-06-21 23:08:21.804 [DEBUG] [lly.internal.util.ShellyChannelCache] - shellyplugs-51d965: Channel meter#lastPower1 updated with 5.1 W (type class org.eclipse.smarthome.core.library.types.QuantityType).
2020-06-21 23:08:21.804 [DEBUG] [ng.shelly.internal.api.ShellyHttpApi] - shelly25-roller-c4d140: API Timeout, retry #2 (Device unreachable or API Timeout (GET http://192.168.0.97/status))
2020-06-21 23:08:21.804 [WARN ] [me.core.internal.events.EventHandler] - Dispatching event to subscriber 'org.eclipse.smarthome.core.internal.items.ItemUpdater@1979d94' takes more than 5000ms.
2020-06-21 23:14:11.907 [WARN ] [mmon.WrappedScheduledExecutorService] - Scheduled runnable ended with an exception:
2020-06-21 23:16:27.426 [TRACE] [ng.shelly.internal.api.ShellyHttpApi] - shelly1-771988: HTTP GET for http://192.168.0.87/status
2020-06-21 23:16:27.426 [TRACE] [ng.shelly.internal.api.ShellyHttpApi] - shelly25-roller-c4d140: HTTP GET for http://192.168.0.97/status
2020-06-21 23:19:14.504 [vent.ItemStateChangedEvent] - My_Home_DeviceUptime changed from 1632121 s to 1632131 s
2020-06-21 23:22:29.873 [vent.ItemStateChangedEvent] - My_Home_Watts changed from 583.3 to 556.1
2020-06-21 23:22:29.875 [vent.ItemStateChangedEvent] - My_Home_CurrentWatts changed from 583.3 W to 556.1 W
2020-06-21 23:17:54.053 [WARN ] [oviders.netty.NettyAsyncHttpProvider] - onError [id: 0x4e13907a, /192.168.0.222:43798 => 192-168-0-250.c0670f2243f34ad3b0c556d784c5cb19.plex.direct/192.168.0.250:32400] EXCEPTION: java.lang.OutOfMemoryError: Java heap space
2020-06-21 23:22:33.132 [ome.event.ItemCommandEvent] - Item 'My_Home_Amber' received command 2.417826
2020-06-21 23:27:59.462 [DEBUG] [ng.shelly.internal.api.ShellyHttpApi] - shelly1-771988: API Timeout, retry #2 (Device unreachable or API Timeout (GET http://192.168.0.87/status))
2020-06-21 23:28:29.666 [DEBUG] [ng.shelly.internal.api.ShellyHttpApi] - shelly25-roller-c4d140: API Timeout, retry #3 (Device unreachable or API Timeout (GET http://192.168.0.97/status))
2020-06-21 23:28:29.667 [TRACE] [ng.shelly.internal.api.ShellyHttpApi] - shelly1-771988: HTTP GET for http://192.168.0.87/status
2020-06-21 23:28:29.667 [WARN ] [.binding.plex.internal.PlexConnector] - [192-168-0-250.c0670f2243f34ad3b0c556d784c5cb19.plex.direct]: Websocket closed
2020-06-21 23:27:20.257 [DEBUG] [pdb.internal.MapDBPersistenceService] - store called for Shellyem1TodayBoilerDryer
2020-06-21 23:27:20.257 [TRACE] [elly.internal.coap.ShellyCoapHandler] - shellyplugs-51cc2c:  Sensor value[7]: id=213, Value=0.0 (Energy counter 2 [W-min], Type=S, Range=null, Link=0: Relay0)
2020-06-21 23:27:20.257 [WARN ] [me.core.internal.events.EventHandler] - Dispatching event to subscriber 'org.eclipse.smarthome.io.monitor.internal.EventLogger@10fc375' takes more than 5000ms.
2020-06-21 23:28:48.892 [WARN ] [me.core.internal.events.EventHandler] - Dispatching event to subscriber 'org.eclipse.smarthome.core.thing.internal.CommunicationManager@69cb04' takes more than 5000ms.
2020-06-21 23:28:48.892 [WARN ] [.binding.plex.internal.PlexConnector] - [192-168-0-250.c0670f2243f34ad3b0c556d784c5cb19.plex.direct]: Websocket closed
2020-06-21 23:28:48.892 [TRACE] [elly.internal.coap.ShellyCoapHandler] - shellyplugs-51cc2c:  Sensor value[8]: id=214, Value=301816.0 (Energy counter total [W-min], Type=S, Range=null, Link=0: Relay0)
2020-06-21 23:29:06.290 [DEBUG] [pdb.internal.MapDBPersistenceService] - Stored 'Shellyem1TodayBoilerDryer' with state '5.45' in mapdb database
2020-06-21 23:29:06.295 [DEBUG] [pdb.internal.MapDBPersistenceService] - store called for Shellyem1TotalBoilerDryer
2020-06-21 23:29:06.298 [DEBUG] [pdb.internal.MapDBPersistenceService] - Stored 'Shellyem1TotalBoilerDryer' with state '633.37' in mapdb database
2020-06-21 23:29:57.890 [WARN ] [me.core.internal.events.EventHandler] - Dispatching event to subscriber 'org.openhab.core.events.internal.EventBridge@167f0e8' takes more than 5000ms.
2020-06-21 23:28:32.883 [DEBUG] [y.internal.handler.ShellyBaseHandler] - shelly25-roller-c4d140: Ignore API Timeout, retry later
2020-06-21 23:32:58.270 [WARN ] [me.core.internal.events.EventHandler] - Dispatching event to subscriber 'org.eclipse.smarthome.core.internal.items.ItemUpdater@1979d94' takes more than 5000ms.
2020-06-21 23:32:58.273 [WARN ] [me.core.internal.events.EventHandler] - Dispatching event to subscriber 'org.openhab.core.events.internal.EventBridge@167f0e8' takes more than 5000ms.
2020-06-21 23:34:11.736 [DEBUG] [lly.internal.util.ShellyChannelCache] - shellyplugs-51d965: Channel meter#lastPower2 updated with 5.2 W (type class org.eclipse.smarthome.core.library.types.QuantityType).
2020-06-21 23:34:18.195 [TRACE] [y.internal.handler.ShellyBaseHandler] - shelly25-roller-c4d140: 0 more updates requested
2020-06-21 23:36:43.427 [TRACE] [y.internal.handler.ShellyBaseHandler] - shelly1pm-f27abb: Updating status
2020-06-21 23:36:46.622 [TRACE] [ng.shelly.internal.api.ShellyHttpApi] - shelly1pm-f27abb: HTTP GET for http://192.168.0.110/status
2020-06-21 23:36:49.810 [DEBUG] [pdb.internal.MapDBPersistenceService] - store called for Microwave_Watts
2020-06-21 23:36:49.810 [DEBUG] [lly.internal.util.ShellyChannelCache] - shellyplugs-51cc2c: Channel meter#lastUpdate updated with 2020-06-21T22:25:59.000+0300 (type class org.eclipse.smarthome.core.library.types.DateTimeType).
2020-06-21 23:36:56.536 [DEBUG] [pdb.internal.MapDBPersistenceService] - Stored 'Microwave_Watts' with state '20.3' in mapdb database
From your log
thanks @rossko57
i did the last update and everything works ok
